Question about Konka Cell Phones
How do I adjust th cal volume on a Konka U3 mobile phone?
Konka u3 is asking insert sim card. sim card in. taken sim card out and cleaned with metho. worked ok but playing up again
Ensure internal contacts are clean, and try again. If this does not solve your problem, replace SIM Card.
Dec 19, 2017 | Konka Cell Phones
Hi, it's Karin again from South Australia =SA Thanx for this free Service, is this open 24/7? But where can I get a free User Guide showing me all about Konka U3 Flip Phone please? Karin
in your browser search bar type in --user manual for konka u3 flip phone --- and if there are manuals available free ones will show up as pdf version for download
Dec 17, 2017 | Konka Cell Phones
My searching leads me to believe this is the instructions written in text based format.
User manual
The Specs are here
Konka U3 3G Next Dual Display Flip Phone with FM radio
And this is the Konka Website page on your phone and there is a link to the manual at the bottom.
Konka Telecommunications
Dec 17, 2017 | Nokia Cell Phones
Where is the volume button? on the konka 3 mobile phone
Try the up and down arrows to adjust volume during the call.
Mar 18, 2017 | Konka Cell Phones
I need to unlock my Konka W105 mobile.
How do I unlock my w105 konka cell phone entered pin number wrong to many times
Oct 06, 2013 | Cell Phones
What to do?
hi friend,
Look at these service phone codes of Motorola mobile, may be it will help you in your mobile phone settings
*#06# imei
in permanent test mode
(* hold 2 sec)
***113*1*[OK] net monitor
T205/T19x (ACER)
*#300# OK List the Software and Hardware version
*#301#­ OK ­ Full Keypads functional Test
*#303# OK Set Default Language to English
*#304# OK Set OFF engineering mode
#304*19980722# OK Set ON engineering mode
*#305# OK Location: 1 OK
*#307# OK Engineering Test Mode
*#311# OK Phone code changed to default code
*#400# OK ADC, Cal val*
*#402# OK Adjust Display Intensity / Contrast
*#403# OK List the Manufacturing Information's
19980722 OK Master Unlock code for Phone and Sim Lock
*#302# OK Acoustic test*
7.1 Greeting
7.2 Main VlmGain
7.3 Input Cal
7.4 Output Cal
7.5 Side In Gain
7.6 Vox Gain
7.7 Min Mic Engy 7.8 More
(a) In Vlm Gain
(b) Aux Vlm Gain
(c) Silence Prd
(d) Supp Prd
(e) In Volume
(f) Out Volume
(g) Icon
(h) Image
(i) Animation
*3370# EFR ON (enhanced full rate)
#3370# ERF OFF
*#72837726# OK Confirm ?, Data saver
1234 OK Phone code default
*#0000# OK Setting saved, restore set phone do default language
*#0048# OK Fast change polish langpack
*#0007# OK Fast change russian langpack
*#06# and quick 'menu-key' and 048263* (Push the key quickly!)
and entering at field "OPTCODE" you must try several times.
If not working try with MOTO TEST CARD inserted.
Security code - 32*118*1*0*0
Model - 32*279*1*0*8
Flex ver - 32*383*1*0*0
Master Reset - 18*0
Master Clear - 18*1
Set band GSM 900 - 10*0*3
Set band DCS 1800 - 10*0*4
Set band PCS 1900 - 10*0*5
Set dual band GSM 900/1800 - 10*0*6
Read band - 10*1*0 => 3-GSM, 4-DCS, 5-PCS, 6-GSM/DCS
User code - 32*116*1*0*0 /coded:00310032003300340000 - 1234/
Read imei - 32*4*1*0*0 "OK" /coded:083a05092700247709 - 350907200427799/
47*4*1*0*9*081A32547698103254 => IMEI=123456789012345
it is possible to change phone's imei
or u can even try last 4 digits of ur mobile number
hope this helps u
thank u for using fixya
Nov 26, 2009 | Motorola Mobility RAZR V3
Volume too low
Chances are there a limit on the volume to keep it from going to loud. If the MP3 has a screen, use it to navigate to a menu and go into it's sound settings. From there, you should be able to raise the max volume to the REAL max.
Jul 07, 2009 | Samsung YP-U3JQB MP3 Player
Nokia 2630 volume adjustment
while making a call press th left navigator key twice anf start decreasing th volume
pldo rate this post as good as u can
Oct 24, 2008 | Nokia 2630 Cell Phone (Unlocked) - Black
Konka D163
where do i buy a display screen for a konka d163
Mar 25, 2008 | Cell Phones
Cell Phones Logo
148 people viewed this question
Top Konka Cell Phones Experts
Andrew Taylor
Andrew Taylor
da surgen
Bill Boyd
Are you a Konka Cell Phone Expert? Answer questions, earn points and help others
