Question about Hoover Vacuums
How can i remove the hose from my Hoover SteamVac LS edition F5894-900
SOURCE: attach upholstery hose
Go to www.Hoover.com. Click on Carpet Cleaners. Click on Steam Vac All Terrain. Click on Learn more. Then click on Download the manual in pdf. The manual explains all.
Posted on Feb 07, 2009
  • 3 Answers
SOURCE: We need the OPERRATING MANUAL for Hoover Steamvac 6020-900
download the manual for hoover F5810 at hoover.com. it's the same for your model.
Posted on Feb 11, 2009
CorvetteKing
  • 108 Answers
SOURCE: How do you remove the brushes on a hoover steamvac
Hoover makes running changes on these style steamvacs without changing the model numbers. One of the following or both.
Four tabs (opaque/white in color) about a 1/4 of the way in from each corner of the plastic brush block that need to be depressed to release the block. (most common) Slide the brush as far out as you can with out putting much tension on them and simply depress them. These are often brittle take great care not to bust them. Gently wiggle the brush block to release the drive spindle.
Two large tabs at either end of the brush block. Slide the brush out as far as you can (release previously mentioned tabs) and then wiggle gently towards the front and the back of the machine. The top tabs (generally black) will catch on the outer eges and be very easily seen and pressed with your finger.
To clean them simply drop the assembly in a bucket of soapy water overnight (no metal to rust nothing to corrode) then clean with hose. I carefully use a pressure washer on mine.
To reinstall brushblock make sure drive spindal is on correct side by lining up hole with spindle, and gently push the block into place while making sure the guides on either end are correctly aligned. All done, go clean some carpets.
Best of Luck
Posted on Jun 05, 2009
AV Nerd
  • 4 Answers
SOURCE: Hoover SteamVac Agility
Press the handle release kick-button with your foot, extend the handle all of the way back, and take a look at the gap between the base of the unit and the handle/reseviour assembly. You should see several black hoses attached to the base and running up into the handle assembly. One of them (the dirty water return hose) might be cracked. Turns out that might be a common problem with this model. We had the same problem.
Judging by the interference between the vacuum hose and the "dirty water return" hose, there is NO WAY those two hoses can exist together in that housing without causing the dirty water return hose can last for many full bends of the handle. We opted to not repair our unit, but you might be able to do it yourself for the cost of the part and several hours of your time. Otherwise, seek out your certified Hoover repair center for more info.
Posted on Jun 18, 2009
  • 430 Answers
SOURCE: Hoover steamvac lower hose replacement instruction
Try 1800 Customer service
Posted on Sep 06, 2009
How doI hook up furniture/stairs attachment
Hoover Steamvac Spinscrub - How To Attach Hose and ...
? 2:54
https://www.youtube.com/watch?v=XTgoEezUlRs
Mar 13, 2011 - Uploaded by Doug Weeks
... spin tool. Used for stairs and stains etc. hand held. ... Hoover Steamvac Spinscrub - How To Attach Hose and Spin Tool ...Every time I attach the upholstery and then turn the vacuum on, water begins to leak from the bottom.
Hoover SteamVac Connecting Hose & Tools F5915900 ...
? 1:41
https://www.youtube.com/watch?v=heAeez1YlFc
Nov 23, 2011 - Uploaded by HooverVideoGuides
How to properly connect the hose and tools ... Hoover VacuumVideo Guides ... I cant get the water to come out the water isnt coming out the spray part to scrub my furniture ... Get Best Price for Hoover SteamVac Carpet Cleaner here ... for the love of god when not using the hand tool where on the machine ...
Hoover SteamVac Connecting Hose & Tools F5912900 ...
? 1:41
https://www.youtube.com/watch?v=fPU9pXgNo98
How to properly connect the hose and tools ... Hoover SteamVac Connecting Hose & Tools F5912900 F5914900 F591... ... Hoover Vacuum Video Guides .... Hoover Steamvac Spinscrub - How ToAttach Hose and Spin Tool ...
Jan 09, 2016 | HOOVER COMPANY Steamvac Deluxe
LS 3500 instruction manual
Hi there! Follow the link to view the instruction manual for the Hoover Steamvac. http://hoover.com/file/610/
Hope this helps!
Sep 22, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Www.hoover.com
Having never used a steamvac I can only only offer this....pump
and nozzles dispense solution....Is the pump on and working?
Are the nozzles clear? This is all I have...hope it helps.
Regards,
Dennis
Aug 18, 2014 | Hoover F6055-900 SteamVac Maxextract LS...
Replacing hose on SteamVac LS 3000
if you take it into guarantee vacuum and sewing center they will fix it for you at little to no cost to you if you already have the new hose if not it will not be cheap with labor and the cost of the hose
Mar 26, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
I need to replace my hose to my steamvac model F5842 can you help? Ordered a hose but I don't think it's the right one
Hi Chris,
Your Hoover SteamVac model F5842 needs the Hoover SteamVac replacement hose part number 40309007. You may find a link to the correct hose for your model below on our website:
Hoover SteamVac F5842 Replacement Hose Assembly
In terms of replacing the hose, this is an older style SteamVac, which attaches the hose to the front of the Dirty Water Solution Tank.
Here is are instructions on how to attach the hose to your machine:
http://www.fixya.com/support/t4699742-dont_manual_u_connect_hose
Hopefully this was helpful, and answered your question. Please don't hesitate to request a clarification, or add a comment if you have any further questions or concerns.
Thanks,
Chris Jones
Oct 07, 2011 | Vacuums
My Hoover Steamvac Widepath will NOT pickup the water after dispensing. I checked the hose inside the cleaner, there was a cut in the hose so I put electrical tape and completely sealed the cut. Still...
Hi, empty the recovery tank of the Hoover SteamVac if the cleaner fails to pick up dirt. Once the tank is full, many Hoover models have an automatic shutoff that stops the cleaner. If the does not resolve the pickup issue, check the hose of the machine and remove any blockage.
Examine the water tank if water does not dispense from the SteamVac. It could be empty and need of a refill, or you may not have locked the dispenser firmly in place. The detergent tank should also be looked at and filled if empty.
Take care
Apr 12, 2010 | Hoover F6213-900 SteamVac Agility...
The tool attachment won't spray water-
you almost have to open up the unit and follow the hoses from the handle into the base.fill it with solution and turn on pull triger.hold the triger in and turn off the unit keeping the triger pulled.turn off and start it up and try again.if it don't spray you might have a bad pump.open up the unit and see if all the hoses are hooke up.there should be a plug on the handle .is it plugged in.please leave feedback.i hope i was some help to you...pet
Apr 26, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steam Vac LS F5897-900
get a copy of the manual at this site
http://www.vacuums-cleaners-bags.com/
Aug 07, 2008 | Hoover F6055-900 SteamVac Maxextract LS...
My vacuum will not extract shampoo from the carpret
we found that there was a small slit in the hose assy and had to replace it.
Oct 09, 2007 | Hoover F5807 SteamVac Wet/Dry Vacuum
Vacuums Logo
64 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
