Question about Xerox Office Equipment & Supplies
Xerox 5755 is having problem it prints few copies and give message please check the output bin for blank and partialy imaged sheets and discard them. and laser error
SOURCE: jam in output bin
Make absolutely sure there actually is no paper jammed in there.
I came to this page with the same warning, convinced I had a software glitch. Turned out there was a page accordion-folded down to the size of a pencil lead. I didn't know paper could be folded that small.
Of course, everyone here may be a lot brighter than I am, in which case sorry to waste your time. But for me, the obvious first fix needed to be thoroughly explored before cursing HP and their machine.
Posted on Sep 03, 2008
SOURCE: Printing labels
You have to feed the labels through the manual feeder.
Posted on Oct 30, 2008
futureloginn
  • 734 Answers
SOURCE: paper jam 11
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Turn off the printer.
Step
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step
5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step
9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Posted on Dec 04, 2008
  • 110 Answers
SOURCE: i have a xerox 7750, error code 9-913
This problem occurs when you buy the wrong image unit.
The contact chip that is located at the bottom of the orange plastic is not for the machine. Replace it with 7750 image unit and that should fix your problem. Black is fault 9-910 cyan fault : 9-911 magenta fault: 9-912 yellor 9-913.
Posted on Oct 22, 2009
app_3rp22205
  • 3 Answers
SOURCE: Vacuum stops every few minutes
If you have made sure all of the sensors are clear, and the moving parts (wheels, beater brush, etc) are free, then it could be a software issue.
You can update your on-board Neato software here:http://neatoroboticsupdates.com/
Joewww.joeramsay.ca
Posted on Feb 26, 2012
Xerox 5755 prinnt quality low i mean print is light very tryng but print is a not set
That is a business quality, network, workstation. You would be advised to have it professionally serviced once a year.
If you want to try and do some work your self, all the documentation on it is here. The only thing I would suggest is taking the toner cartridge out and tapping it sharply whilst rotating it laterally. Sometimes the toner can cake and not fall down to the developer roller. There is software on the site too.
http://www.support.xerox.com/support/workcentre-5735-5740-5745-5755/documentation/enus.html?operatingSystem=win8x64&fileLanguage=en
Apr 26, 2016 | Xerox Office Equipment & Supplies
Xerox 5765 display does not work still on green color
Needs an 'altboot' software reload. http://www.support.xerox.com/support/workcentre-5735-5740-5745-5755/file-download/enus.html?operatingSystem=win81x64&fileLanguage=en&contentId=122791&from=downloads&viewArchived=false
1) On a USB drive create a folder named "altboot"
2) copy unzipped file from above link (.dlm) into folder
3)insert USB into rear port and power on machine
4) remove USB when prompted and press '0'
5) S/W load is complete when config page and upgrade sheet prints.
You will lose any scan to file and email settings and will need to reconfigure. You may also need to change TCP/IP.
Jul 26, 2015 | Xerox Office Equipment & Supplies
Xerox printing all black pages
You have no light output. The system places a charge, the image will remove charge (without image processing, the system leaves full charge ) (removes charge where no image is if negative processing)
EX: a copier has platen closed makes a copy because the cover has a white surface the light is reflected and removes charge from Drum. If you make a copy with platen open out put will appear black. Charge was not erased, toner is attracted to charged area.
Most systems use a small wire to place charge, depending on what development (pos or neg) with broken wire will also result in either a black or blank output. I would look for a broken charge wire.
Mar 05, 2014 | Xerox Corporation Xerox ColorQube 8900X...
Panasonic kx-ft981 ,no print out and copy.
Panasonic kx-ft981 ,dark print out and copy.
Jun 23, 2012 | Office Equipment & Supplies
First print job, first page jams on output area
Please note that paper absorve humidity, try to keep you equipment in a dry place.
When the paper is that condition, and while passing thru the hot image drum, the sheet hedges sometimes curves and jams...
Sorry for my bad english !
Jun 23, 2009 | Xerox 4150V_P Printer
No image on copies
Hello sir; The problem in the cartridge which you just replace, get the receipt with cartridge go back to the store wherever you bought make a exchange.
Jun 08, 2009 | Xerox DocuColor 12 Color Copier
41 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
