Question about Honeywell Heating & Cooling
I have a red light on my honeywell r6660d. it is linked to my hot water timer honeywell ST9100c..I assume the red light is because the link has been lost but I cant find how I resend he binding signal
5 Suggested Answers
  • 3 Answers
SOURCE: red LED on honeywell r6660d
The problem is that the 2 units are "not speaking to each other". this could be caused by low batteries or a loss in signal caused by a powercut or an objection in the way of the 2 units.
first you need to turn the power off to the r666od (or otherwise known as the HC60NG) for 10 secs, then turn back on. then hold the grey button in for 15 secs. release then hold in for a further 5 secs.
go to the honeywell cm61 press the off button. hold temp up. temp down and prog 1 in for 3 secs until the dipslay goes to INST. at this point release all 3 buttons then press the i button until a beacon starts flashing.
this is now the end to your problem.
N.B the reason the green light was on is because the man override button will have been pressed.
hope this helps
Posted on Feb 11, 2009
  • 3077 Answers
SOURCE: WORSTER 550 BOILER TO A HONEYWELL ST9100C TIMER
worcester bosh have there own web site which i think has a technical number you can ring for help
Posted on Jan 21, 2010
djpstunt1
  • 172 Answers
SOURCE: shifter i assume lost the link, the shifter on
you might have hit a bump and the linkage popped out
you need to jack the car up and pop it back in
it is on the side of the transmission on the drivers side
Posted on Dec 05, 2010
  • 182 Answers
SOURCE: how do I bind my
I don't see anything about a t661d in this manual but perhaps it is the same process. hope it helps.
http://www51.honeywell.com/hungary/hirek-details/documents/evohome_alkalmazasi_peldatar.pdf
Posted on Dec 29, 2010
Biasi combi boiler with red light flashing at honeywell r6660d
Here is the biasi site that should have your manual. With no model number, I hope this helps.
Feb 15, 2014 | Honeywell Programmable Thermostat Heater
Diagram honeywell wireless room thermostat system boiler model r6660d
Honeywell web site will have all the information you need.
Jan 02, 2014 | Heating & Cooling
I need instructions for programming Aube TI032-3W/U 7-Day Programmable Timer Switch, White
Open following links to identify timer and download manual:
http://waterheatertimer.org/Aube-T1032-timer.pdf
http://waterheatertimer.org/Aube-timers-and-manuals.html
Honeywell Aube T1032 is made for single-pole or 3-way applications, and works for all types of lighting up to 500Watts.
Timer has internal battery and cannot be exposed to freezing temperatures or extreme hot temperatures.
Sep 28, 2011 | Intermatic HB88RC - 7-Day Programmable...
Cannot set timer on central heating/water system.
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Jul 27, 2010 | Honeywell Heating & Cooling
Jan 18, 2010 | Honeywell Programmable Thermostat Heater
How do I calibrate the temperature for the RTH7500D thermostat? It is 2 degress warmer than the thermostat reflects. Does this thermostat operate on the battery power alone? There are only two wires going...
There is no feature in this thermostat to adujust sensor. You need to make sure you have picked for hot water systems.
Follow blue link for instruction manual
If you need more information, please post back.
If this answers your question please hit accept
Nov 27, 2008 | Honeywell Electronic Programmable...
Red LED on honeywell r6660d
hope this helps
Nov 14, 2008 | Honeywell Programmable Thermostat Heater
Honeywell ST6400C programmer doesn't switch off
Since you have three on/off timing modes could there be an overlap in the times?
The wires in the unit might be crossed. (don't always assume the contractor who wired maintained the correct colors , I have a friend who blew out a heating pipe because when a replacement motor valve was installed it was never wired right and the plumber assumed the colors were correct so no overtemp shutoff created steam in PVC pipes, OPPS)
There fore maybe one is still coming on. Do you have more than one heating zone? IF so see below
I guess the main question is why manually turn it off? why not use the program.
I will assume your heat is know as forced hot water heating. My house is multizoned however when the zone calling for heat turns off (zone valve closes) I installed a bypass valve in the lowest zone in the house, and reduced the circulator low shut off temp to 130 F which means even though the heat isn't on my circulator will continue to run dumping this excess heat in the lowest part of house to rise through house. (the spring loaded water valve allows the heated water to flow into this zone )We do have two thermistats. And even though the lowest one is not calling for heat the radiators are hot when the excess is dumped into this zone. So investigate and see if your system might be similar. (multizone).
Investigate your wiring, reprogram, replace any battery backup.
Dec 18, 2007 | Honeywell Programmable Thermostat Heater
New Timer--New Problem
Sound like you connected the timer up wrong, from my drawing check the following connections to the timer.
terminal 12 & 26 - Black (linked) mains supply
terminal 17 yellow/red (from rinse switch)
terminal 28 grey (from water level switch)
terminal 15 light blue (advance rinse switch water level switch)
terminal 27 brown (door switch)
terminal 25 brown (door switch)
terminal 62 green/black (motor)
terminal 7 red (motor)
terminal 32 yellow (motor)
terminal 9 blue (capacitor /motor)
terminal 8 white/yellow (motor) and white (water solenoids hot and cold)
terminal 71 pink (water selector switch and hot solenoid)
terminla 72 purple (water selector switch and cold solenoid)
terminal 70 white/blue (water selector switch)
Watch the light blue wires as there are several of them!!
Dec 12, 2006 | Admiral AW22 Top Load Washer
Heating & Cooling Logo
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
