Question about AMP Car Audio & Video
Need Specs. on rockwood X-plore 4040 2 ch. 840 w.
Amp goes into protec mode when trying to install
  • 149 Answers
SOURCE: similar prob.did the 12 steps on how to install
If you are running a set or a single subwoofer with the jensen amp than you will want to hook up the rca cord to the subwoofer rca connection on the back of the stereo unit-the other rca outputs are there in the event that you want to run a 2 or 4 channel amp to power the speakers that are generally located in the doors or back deck-with that set up properly you would still be able to adjust the balance and the fader just as though you were powering the speakers with the deck. Pug the free ends of the RCA cord into the input rca receptacles of the amp- the stereo now will feed a signal to the amplifier that only contains bass - good luck
Posted on May 19, 2009
  • 158 Answers
SOURCE: Rockwood 479X
i would recomend 8gage just to be safe
Posted on Oct 14, 2009
SOURCE: Protec Bytelan KVS/4 Wall Wart specs
12VDC - 700mA - Center Positive...
Posted on Jan 25, 2010
fingaz22
  • 1068 Answers
SOURCE: how to wire for 3 ch mode
this is the manual and you will find all you need in it.
http://www.fixya.com/support/p78783-eclipse_ea3422_car_audio_amplifier/manual-18248#
Posted on Jan 30, 2010
  • 323 Answers
SOURCE: i plug in rockwood detanator VII and it goes to protections mode
Generally if an amp goes straight into protection, the amp is not grounded well enough. Either you should find a new location to ground the amp to or unhook the power wire from the battery, remove the ground wire from the chassis of your vehicle. Strip the paint from the chassis, since it doesn't conduct electricity, and remove any corrosion or copper shielding from the ground connector. reground to a solid metal location Can be grounded to the brace behind the back seat or to the seat belt bolt for best results.
An amp draws a lot of power, there it needs to be grounded well.
Hook back up your power wire to the battery and see if your issue is resolved.
Posted on Jul 28, 2010
How do I install a Rockwood AMP-326 amplifier? I'd like to bridge it.
Rockwood was a very low level brand. Alot of their amps were not brigeable. If bridge able the bridge terminals should be marked (usually the positive of 1 channel and the negative of the other channel). Under no circumstances bridge to less than a 4 ohm load.
Jul 17, 2016 | Rockwood Car Audio & Video
I have two 12' kickers, will a x-plore 1000 watt 4 channel amp work well with it?
It all depends on the wattage of your subs. you need an amp more powerful than the both subs combined. For example. for 2 500 watt subs, you'll need at least a 1200 watt amp. amps should never be truned up to full power, 80% max as they tend to blow more quickly and overheat when on max. ideally you want an amp over the total combined wattage of your both subs so you dont need your amp on max for the best sound for you subs.
Mar 02, 2011 | Rockwood XR-3973 Car Audio Amplifier
I plug in rockwood detanator VII and it goes to protections mode
Jul 18, 2010 | Car Audio & Video
Amp goes to protection mode. if the fuse is too small?
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. . Double check all connections. Good luck.
A thumbs up would be greatly appreciated if this answer is helpful to you. Worth fixing.
Jul 15, 2010 | Autotek MM125.2 Car Amp
Red light comes on then shuts off then nothing
check your fuses and supplies lines (positive supplies)
Jun 04, 2010 | Rockwood X-Plore AMP-4080 Car Audio...
Can an explore 4020 amp be bridged?
Well if it's a multi channel amp it can definately be bridged. Yes, and from what I've read it is actually bridgeable at 2 ohms per 2 channels.
May 31, 2010 | Rockwood X-Plore AMP-4020 Car Audio...
Need repair parts how do i get them
You can't really just replace them unless you open it up and get those parts. But even then, your amp won't be 100%
Mar 06, 2010 | Rockwood X-Plore AMP-4030 Car Audio...
I connected the hot wire of my stereo and ran it to the amp power and same thing as the ground and get NO power
you have to run a seperate power wire from ur battery 2 ur amp and the same 4 ur ground wire
Feb 27, 2010 | Rockwood X-Plore AMP-4030 Car Audio...
My ampli start bot only in protection mode
amp could be blown, i.e. speaker wires crossed up, too much power..............
Jun 07, 2009 | Rockwood X-Plore AMP-4010 Car Audio...
Car Audio & Video Logo
Top AMP Car Audio & Video Experts
Oscar Goldman
JonSnell Electronic
JonSnell Electronic
Are you an AMP Car Audio and Video Expert? Answer questions, earn points and help others
