Question about Microwave Ovens
I have euromaid oven 1505 TIWH the display doesn't come on and there is power on the oven but nothing works
I have an euromaid BMWH8 and it just stopped heating up, I heard a pop sound and I'm guessing it is a fuse.. Where is the fuse located on this oven ?
I don't know exactly on Euromaid but I would suggest that the fuse would be either under the top or the back near where the main power supply is. If a fuse blows , it is likely that one of the heating elements has failed.
Nov 22, 2017 | Microwave Ovens
Fuse blown in the back of Euromaid oven, What can cause this??
Hard to say what blew the fuse, suggest you replace the fuse and if it blows again take it in for service
Jan 30, 2015 | In Microwave Ovens
Sharp r-1505 microwave. several segments in digital display do not illuminate.
Sharp had "issues" with that board (connector cable fail). That was back in 2002. Give them a call and see if they will send you a new control board (part # CPWBF070MRU0) All of the 0's are zeros.
If not, look at that ribbon connector where it's kinked, and you'll see a spot that should be repaired, ie broken wire.
Good luck with the phone call. Refer them to bulletin # MW-166.
Mar 01, 2011 | Sharp R-1505 Microwave Oven
My Sharp R1505 Microwave's LED display is malfunctioning, with only minimal lighting of digital/number segments. Do I need to replace the entire control board with a new LED attached or can I just replace...
You can order a new control unit (part number CPWBFB075MRU0 which comes with a display) from Encompass here.
Or you can get yours repaired for $39.95. Details here.
Feb 10, 2011 | Sharp R-1505 Microwave Oven
I have a sharp carousel over the range microwave oven R-1505LK no power the outlet is ok did lose power to the house and the microwave didnt come back on where is the fuse located
The fuse is usually located inside the cover near where the power cord enters...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
Nov 16, 2010 | Sharp R-1505 Microwave Oven
I heard a pretty loud pop on my Sharp R-1505 yesterday and the microwave stopped heating. Any ideas?
get rid of it your transformer blew out they are to costly to replace and potintialy dangerous to work on unless you are trained technican
Oct 08, 2009 | Sharp R-1505 Microwave Oven
Sharp 1505 Microwave Display Failure
There are two options for this model:
- You can order our exclusive modified control unit (CU150) with our proprietary upgrades for $95, then if you return your defective control unit in repairable, good cosmetic condition, we'll give you a core refund of $40. Details are here.
- Or we can repair your existing control unit for $39.95 in about a week with a one year guarantee.
We have the service manual for this model and have uploaded it to our site here to help you.
Repair service details are here.
Jan 17, 2009 | Sharp R-1505 Microwave Oven
Sharp R-1505 microwave
The power fuse open , if open replace it don't make jumper it b
cause fire .
the power transformer builtin fuse open/
The door micro switch open /need to replace.
Jan 03, 2008 | Sharp R-1505 Microwave Oven
I would first suggest that you be sure every single wire got reconnected where it belongs.
Here is a diagram:
If you still have toruble, see
Nov 28, 2007 | Sharp R-1505 Microwave Oven
Microwave Ovens Logo
32 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
