Can a cracked BBC/fibreglass bathtub be repaired?
The crack is about400 mmlong through the width of the tub and it leaks
  • 3,497 Answers
Beautiful new bathtub and wall right over your old one
or contact a good fiberglass repair shop (boat repair place might be able to help)...
Posted on Aug 10, 2017
huuum
  • 750 Answers
SOURCE: Dishwasher Leaking
Hello jferguson29.
Welcome to fixya.
You said, water splashing over tub into door panel. It leaks with or without being loaded with dishes.
You checked the lower wash arm but found no visible cracks or breaks. The leaking water is clear not soapy.
What is the brand and model number?
And how old is it???
There are a couple reasons water may be leaking out the door of a dishwasher.
1. The water is most likely coming out the bottom of the door where there is no rubber seal.
2. The rubber seal is around the door jam on top and both sides and not on the bottom. This means if the dishwasher has to much detergent in it the soap suds push only the water higher than the front edge of the wash basin and out the bottom of the door where there is no seal!
3. Fill only the soap cup that can close for the secondary wash. The open cup is a pre-wash and mostly not needed unless the food is baked on.This just wastes money to fill both of them every time.
4. And if you are using liquid detergent you only need half the amount from the powdered soap!
try less soap. Remember to much soap too can cause the water overflow.
5. And the last would be that the drain is clogged and caused a back up large or small and then the overflow!
is there water in the bottom when the wash is done?
Soap is usually the culprit, not that there can't be a leak in an old drain or water supply hose!
Go with the soap idea first!
Let me know how you are!
How old is the washer ?
Please remember to leave a rating before you go!
Thank You ,Huuum
**************************************************************************8
Here is an interesting report I just read!!!!!!!!!!
Repair or replace?
When to pull the plug on your old washer
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your washer,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your washer is under warranty or less than four years old ,
paying for a repair makes sense.
Note that washers under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your washer is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new washer.
Data also shows that it doesn't pay to fix a less-expensive washer
eight or more years old.
Thanks to better recycling programs, less than 10 percent
of washers you replace are likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not forget to give a rating before you sign off!
Posted on Oct 03, 2008
gamerfixer07
  • 344 Answers
SOURCE: Dishwasher tub leaks underneath
Hello. Anything is worth trying! But I would recommend epoxy. It works alot better with plastic and rubber items. Most of the leaks I have found in Kenmore machines are at the water pump. You may want to take a peek while it's running, just stay away from the wires!! Thanks!
Posted on Jan 18, 2009
  • 152 Answers
SOURCE: Can a hairline crack in a porcelain bathtub be repaired?
If your tub is porcelain over cast iron and the cast is not cracked your ok. If the cast is cracked then the chances of the crack continuing are great, more so with any vibrations and changes in weight distribution.
Posted on Feb 20, 2009
  • 240 Answers
SOURCE: kenmore 80 series leaking....plastic tub cracked on the bottom
if you removed the large nut (round with four notches cut in it ) then tub should be free. sometimes these "rust together" on the hub. wd40 and a hammer to knock it free. try rocking the basket to break free. you did remove the tub ring(white plastic part on top), right?
Posted on Apr 28, 2009
  • 62 Answers
SOURCE: Lasco whirlpool tub leaks. Water runs out on
Sorry, the tub will have to pulled out to find out what is leaking so it can be fixed. There is just no other way UNLESS you can open up the wall on the blind side of the tube. (but its probably and exterior wall...if the house is vinyl sided, it can be done. If brick, you'll have to pull the tub). If you just wanted to convert to a tub only, maybe Bathfitters has an insert solution...
Posted on Jul 11, 2009
Replacing jet
When you installed the new jet, did you install a new gasket on the wall fitting or use 100% RTF type silicone?
In order to seal a wall fitting that is cracked an leaking, the replacement must have either the gasket or silicone to seal the wall fitting against the wall of the tub or it will leak when filled with water.
Rod
U S Parts Center
Jan 03, 2014 | Jacuzzi Home
Jets breaking lose from tub
Call a repair man.
Nov 06, 2013 | Home
We would like to know if anybody knows how to fix spiderweb cracks and cracks in the outside shell on the bottom of our canoe?
whats it made of?if its fibreglass,you can sand it down[around the cracks]and relay the fibreglass cloth with the special glue,and build it up.follow the repair kits instructions..reasonably cheap to fix
Sep 14, 2010 | Old Town Charles River Canoe -
The bathtub drain pipe [below the tub] is cracked is there any easy fix without removing tub, etc  it maybe could be reached by cutting out part of the adjacent wall otherwise, the water spills onto...
You can do all your fixin underneath where you say it is leaking on the slab if there is room for you to crawl under why remove the tube, more trouble than it is worth.
Jul 18, 2010 | Home
I have a cracked and damaged area on the bottom of my fiberglass tub insert. Can I fix it myself? Where would I find the kit needed? Thanks.
My secondary bathtub is that way. I was told it was just a surface crack and wouldnt leak. It can be fixed with a fiberglass boat repair kit. However, it would not look very good. I took clear caulk and squirted into mine and it seems to be working fine. Once you put the caulk in rub it in with your fingertip and remove the excess.
May 06, 2010 | Home
We have Builders #6032 and it has small hairline cracks in tub bottom. Its starting to leak into our basement. What do we do to fix it?
alot of times if you call the tub builder they have service guys who will come and fix your tub. most tubs have a 3-8 year warrenty against defects so you could get the fix for free. if not you can always try and get fiberglass resin and mix a batch up and seal the cracks yourself
Aug 01, 2009 | Hydro Systems DUO6648GWP Designer Series...
We have a large cultured marble soaker tub with two hairline cracks going out from the drain, 1 about 18'' & 2nd about 24'' resulting in the tub leaking. The Tub is on the 2nd. floor & is sunken...
Hi Garry,
I understand not wanting to cut out the ceiling. Cutting it out is the easy part...Putting it back and making it look good....that's the hard part.
Just a few thoughts: You may be able to apply a coating from your access hole. What comes to mind to me is a 2 part epoxey with a relatively long cure time, to give you time to apply it. This can actually be applied with a small, disposable roller (shur-line makes a small one with a tray, ~$2). I have used this method on projects with success. If additional strength is desired, you can apply fibreglass mesh into the worked area just as you get tacky. Let dry and recoat. This can go as many times as you need to to get adequate coverage.
That was solution #1. Here's another possibility. Since it is a cultured marble tub, you may be able to grind out the cracks, collect the residue, and make a surface patch with resin and ground marble dust. Additional material may come from areas that you can't see, or perhaps you may purchase a damaged piece from a hardware/plumbing supply type store. I'd experiment with this one on some scrap before I went to gluing mama's tub though!
That was #2. One more, and I'll leave you alone. It's possible that you can find a spray coating that will do the trick. Such a coating could be applied laproscopically, via several very small holes in the ceiling, which could be easily repaired after.
Just a few asides While these may fix your immediate problem, be sure to find out why the cracks are showing up. Either the drain was overtightened, the tub was not properly cast, or the drain piping is supporting too much weight. Anything that you can do to spread the load of the weight of the tub, the water and as many kids as you care to put in there will go a long way in preventing the situation from recurring. Well, brother, just some food for thought. Hope that it helps.
Best regards, and good luck! Hopefully a garden tub guru will have a magic bullet they'll share with you!
--W/D-- Please feel free to rate this solution! Thanks!
Jul 29, 2009 | Home
Four inch crack in the bottom of aquaglass tub styren
I would contact Whirlpool directly to even see if it is possible. I tried to repair an acrylic tub one time and it didn't keep because the the constant water on it. If it can be repaired, they will give you the solution and info for a contractor that might be able to do the work if you can't do it yourself.
Mar 17, 2009 | Whirlpool Safety Bath Walk In Bathtub -...
One piece fiberglass tub cracked in the middle of basin (4'' crack
The only sure fix is to drill holes in the bottom of the tub and shoot in a commerical grade low expanding foam to fill in the void. The foam you find a Lowes or Home Depot will not work as it is a high expanding foam and will ruin your tub. Call a reliable tub repair company experienced in this type of repair. It should not exceed 200.00 including rolling in a new floor.
Mar 05, 2009 | Home
Feb 19, 2009 | Home
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
