Question about Refrigerators
GE PSC23 Artica refrigerator. A couple of days ago I noticed water on the floor-looked at ge site and went thru tutorial and removed front panel from bottom of frig to look at "water defrost line". Pulled it apart and reattached, not frozen. Looked good. Noticed water again, now it seems the damper door on the ice/water dispenser is intermittently not closing fully when we dispense ice. Could this be contributing to problem. Can I remove the front trim panel from the dispenser to look at the damper. Was told it may also be selonoid-is this a DIY repair. Cheap, unemployed female willing to try and resolve. Help appreciated
  • feyest Jul 27, 2009
    You didn't really address my questions. There is no ice buildup on damper door
    did not answer my question......no ice buildup...
    President:
  • 1,776 Answers
Maam, when you say that you noticed water leaking on the floor, where exactly was the water? On floor in front of fridge? Or elsewhere? In some refridgerators the defrost water is intentionally directed down the back of the unit, where it then flows to the bottom of the fridge and out to a small drain that is usually located under one of the drawers in the refridgerator compartment. If the drain becomes clogged or blocked, the water backs up.
Some refridgerators also have door frame heaters that evaporate any condensation on the cabinet frame. If your refridgerator is equipped with a dial that says "energy saver" mode or something similar, while running in that mode, the door heaters are disabled. If that would be the case, you can turn the dial to the opposite setting and wait 24 hours to see if the condensation problem clears up.
The ice making/dispensing mechanisms are very complex. Aside from the problems of a leaky supply line or a stuck ice cube, most components are not user serviceable and a qualified appliance repair technician should make any repairs to this unit.
Sure hope this helped you, sorry for your problem, and best wishes.
Posted on Jul 27, 2009
  • Refrigerators Master
  • 19,396 Answers
If the door on the ice maker is not closing properly , this can cause water leaks from the ice maker.
Check that the door is not stuck because of ice. Leaving the unit to defrost completely can solve many problems caused by ice formation.
  • Ginko
    Ginko Jul 27, 2009
    Hi, if the damper door is not closing well, it will not keep enough insulation to preserve low temp and you may have leaks from ice maker.
    If leak or condensed water inside the fridge , like the one possibly caused by the non closing door, is too much, water wont be evaporated after going through the drain hole, and you get leaks underneath the fridge.
    If drain lines after panel with drain hole are frozen inside, then you also get a leak underneath.
    Other than this a leak can only be caused by a broken water line, and does not look this the case.
    Hope I addressed the problem.
    Best regards.
    G.
GE Artica no water, no ice, Checked water supply to solenoid OK
did u check water line after solenoids. could be a vaccum or u could have bad solenoids, not opening to allow water to go into box, try ok.
Feb 12, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Temperature in refrigerator will not stay set. It keeps getting colder. I have a GE Artica model PSS27SGMD. It is a side by side with ice through the door. It is +- 9 years old
GE Artica had problems with the "Motherboards" originally installed. They have since switched manufacturers so my educated guess that is the problem.
Jan 08, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
I have a GE Profile refrigerator Model # PSC23MGTC it has an Artica Water & Ice dispenser on the freezer door, the ice will not come out, and noew the water works only when it wants to, I think I need...
Cut and paste this Factory Service manual for your refrigerator.
The troubleshooting guide will help locate the bad part.
http://appliancejunk.com/ge/refrigerator/31-9072.pdf
Aug 08, 2010 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
WR55X10415 on GE None of the panel lights are on. no water no ice
Before you go too far lets check the wiring harness. Your model is a Profile or Artica and model number? I would not buy anything until I traced out the wiring. You may have plulled the pinplug at lower left hand of door near floor and behind kick plate. Sea Breeze
Mar 20, 2010 | GE Refrigerators
GE profile TFHW22R side-by-side fridge compressor issue
Most times replacing the start relay part=> WR07X1001 start capacitor=> WR62X80 and overload=> WR8X97 will resolve the problem. Click here to downlod the Service Manual=>PROFILE ARTICA SERVICE MANUAL CLICK HERE and go to this page to use he Tech Sheet> GE Artica Profile Technical Information If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
Jan 26, 2010 | GE Refrigerators
I have a GE Profile PSC23. Everything works fine
I fixed it myself. After poking around the freezer, I saw that the area around the tube that gets water for ice making was frozen - this is at the top of the freezer. So I used a hot spong to melt the ice and the noise went away. Everything is working fine now.
Jun 17, 2009 | GE Refrigerators
Frost inside and ice on floor of freezer
The water can only come from 2 places, the drain is blocked or the ice maker is over filling.The temps are too good to have any other things going wrong. Let me know, Thanks, Sea Breeze
May 18, 2009 | GE Refrigerators
I have a side by side GE profile Artica refridgerator. The Ice maker is producing, but I cannot get water to come out. When I push the water dispenser, I can hear something happening, but nothing comes...
One of two things. Water solonoid in back defective or water line insideof freezer door is froozen. I just posted a write up about this. Check other response. UJ63
Mar 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire Side-By-Side Refrigerator Leaks Water on Floor
I don't have the same refrigerator, but had a similar issue with a GE. Melt the ice at the bottom of the freezer. I think the water comes from the auto defrost feature. There should be a hole at the back bottom of the freezer that water would go into, and run to an evaporator pan under the refrigerator. The tube may be blocked that allows this water to drain, so it is backing up in the bottom of the freezer, and overflowing through the front bottom of the freezer to your floor.
Sep 28, 2008 | Refrigerators
Ice maker not working
check your owners manual for a water filter, make sure trip arm isn't stuck closed and not letting water in to freeze.
Dec 08, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
131 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
