Question about Husqvarna Weed Trimmer 224 L 4-stroke Line Edger Trimmer Honda Engine Husky
Engine oil capacity honda hhh25 trimmer - Husqvarna Weed Trimmer 224 L 4-stroke Line Edger Trimmer Honda Engine Husky
Fuel mix for 25cc trimmer
For two stroke engines of this capacity the ratio of fuel to two stroke oil is (25:1) 25 fuel to 1 (two stroke) oil. Eg 200 ml of two stroke oil to 5 litres of fuel.
Jan 27, 2012 | Craftsman 25cc Gas Line Trimmer
I want to know, what is the engine oil capacity of Honda XL 125r (manufactured year may be 1986)
the capacity is cast into the caseing near the oil filler will look something like 800cc or 1000cc
1000 cc =1 litre
Aug 13, 2011 | 1986 Honda XL 125 R
How much oil does an 8hp honda engine take ?
Honda gx240 oil capacity
1 .I6 US qt
Use Honda 4-stroke oil, or an equivalent
high-detergent, premiumquality
motor oil certified to meet or
exceed U.S. automobile manufacturer's
requirements for Service Classification
SE or SF. (Motor oils classified
SE or SF will show this designation
on the container.)
SAE low-40 is recommended for
general, all-temperature use.
Feb 10, 2011 | Honda 8 HP Engine
Oil capacity with filter and what type?
Straight out of the manual!
RECOMENDED ENGINE OIL FOR HONDA VTX1300S
Pro Honda GN4 or HP4 (Without molybdenum additives)
4-stroke or equivalent motor oil
API service classification: SG or higher
JASO T 903 Standard: MA
Viscosity: SAE 10W - 40
OIL CAPACITY
3,5 Litre 3.1 Imp. Qts 3.7 US Qts at draining
3.7 Litre 3.3 Imp. Qts 3.3 US Qts at filter change
4.3 Litre 3.8 Imp Qts 4.5 US Qts at dissassembly
Jan 06, 2011 | 2004 Honda VTX 1300
How much engine oil does my 2005 crf 450 R need when changing oil and filter?
Engine oil:
Fill the crankcase with the recommended oil. Capacity: 0.73 US qt (0.69L) at oil and filter change Tansmision oil: Fill the crankcase with recommended oil. Capacity: 0.62 US qt (0.59L) at oil change.
Dec 07, 2010 | 2005 Honda CRF 450 R
Crf 100f workshop manual engine oil type and capacity
For temperatures 50 degrees fahrenheit or less, use 4 stroke motorcycle oil 10w-30. For temps 50 and above use 10w-40. Pro Honda GN4, Honda 4-stroke Oil, or other equivalent motorcycle oils. Capacity is about 1 quart.
Oct 17, 2010 | Honda CRF 100 F Motorcycles
What type of oil is best for a 2006 honda odyssey??? Tks
2006 HONDA ODYSSEY 3.5L 6-cyl Engine Code J35A7 2006 HONDA ODYSSEY 3.5L 6-cyl Engine Code J35A6
Engine Oil Grade 1......API* All TEMPS......5W-20 synthetic oil or conventional. Brand name you preference. Fram oil filter Part #PH7317 Honda oil filter part #15400-PLC-003 or 004
CAPACITIES: Engine, with filter..........4.3 liters After refill check oil level. Torque Oil Drain Plug.....29 ft/lbs
Jan 24, 2010 | 2007 Suzuki XL-7
Oil spec
1995 HONDA ACCORD 2.7L 6-cyl Engine Code C27A4 C27A1
Engine Oil Grade 1......API All TEMPS......5W-30
Manual Transmission,......SJ All TEMPS......10W-30, optional 10W-40
Automatic Transmission,MPZA......AF2
CAPACITIES:
Engine, with filter..........4.4 liters
Automatic Transmission, MPZA Initial Fill..........2.7 liters
Automatic Transmission, Total Fill
4 speed MPZA..........6 liters
Manual Transmission, ..........1.9 liters
1995 HONDA ACCORD 2.2L 4-cyl Engine Code F22B1 VTEC
Automatic Transmission,A0YA......AF2
CAPACITIES:
Automatic Transmission, A0YA Initial Fill..........2.4 liters
Automatic Transmission, MP0A Initial Fill..........2.4 liters
4 speed A0YA..........6 liters
4 speed MP0A..........6 liters
Jan 07, 2010 | 1995 Honda Accord
Oil capacity of engine crankcase on 2007 Honda VTX 1800 C
The factory fill is 4.3 litres. Thats new empty lines...etc.
3.75 to 3.9 quarts is a normal drain.
Heres a link for the complete service manual on the VTX 1800C
It's a big download about 50MB in PDF format
Hope this helps...ride safe and ride smart.
May 29, 2009 | 2007 Honda VTX 1800 C
Husqvarna Weed Trimmer 224 L 4-stroke Line Edger Trimmer Honda Engine Husky Logo
27 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
