Question about Stanley Air Tools & Compressors
How much oil do i put in my stanley bostitch cwc 156 1.5 hp air compressor?
4 Suggested Answers
smjdragonfly
  • 79 Answers
SOURCE: air coming out the trigger of a stanley air gun
Go to the Stanley Bostitch website. Click on schematics & parts. Find your model number in the drop down list. There is a list of parts and pricing. Just above the parts is a link for the schematic. Honestly, I worked on these things for years. It is best to replace the entire trigger valve. It comes as a kit with instructions grease, and a little tool to hammer your pins out. Lemme know if this helps. Please rate me
Posted on Jun 18, 2009
  • 885 Answers
SOURCE: I Have a Stanley air compressor Bostitch model
The brown liquid you are getting out of the compressor is water with rust in it from the inside the air tank. Somewhere on the bottom of your air tank there is a valve you need to open from time to time to drain the water from your tank. If you are getting rusty water from the air outlets you probably have a lot of water in the tank. If you can take the compressor outside, with pressure in the tank, where the water won't stain anything and slowly open the valve to drain the tank.
Posted on Feb 02, 2011
  • 1383 Answers
SOURCE: I have a Stanley Bostitch
Some Bostitch compessors are very unique in that they intake air from below the piston. If you cannot find an air filter, then your compessor has reed valve built into the piston that may cause problems. If you have an air filter on the head of the pump, then you have reed valves in the head. When the reed valves fail, there will be very little or no air pressure. Second problem with all compressors is the in-tank check valve. This valve allows air to enter the tank and not back-out into the compressor. Easy to check. Add air into tank with another compressor thru the quick connect and listen for air leaking around the head or pressure switch. If no leaks and pressure holds in the tank then valve ok. Examine the condition of the cylinder and piston ring by rotating the crank by hand so that the piston is at top of cylinder. Look for scratches around upper part of cylinder wall. If scratches, then replace cylinder and piston ring. If top of cylinder looks good, then suspect reed valves. Good luck
Posted on Sep 28, 2011
How to change a regulator on a bostich pancake compressor
Usually they are just threaded into the unit, Empty the air, then remove it,
Oct 11, 2014 | Stanley Bostitch CAP2000P-OF 2 HP Peak 6...
I have a Stanley Bostitch CAP2000P-OF Air Compressor. It runs constantly and won't reach the shutoff pressure. It will build some pressure. When I turn it off, I dont hear any leaks.
Jim:
There is a leak somewhere... Use a soapy solution at the air tube from the compressor head to the tank (both ends) and at all air hose connections. The bubbles will tell you where the leak is and you can repair the connections from there...
Aug 17, 2013 | Stanley Bostitch CAP2000P-OF 2 HP Peak 6...
Any authorized dealers in columbus ohio to repair my bostitch air compressor
A search through the Columbus telephone directory or online might produce results
Dec 26, 2012 | Stanley NEW Bostitch 2 HP 6 Gallon...
I have a Stanley Bostitch Oil Free Air Compressor 6.0 Gal 2.0 Hp Peak, 1.5 Hp Running 135 Psi The problem is it won't blow out air or hold the air.. How can I fix this?
Sep 12, 2011 | Stanley Bostitch 2hp 6gal Air Compressor...
When I plegged the compressor in the motor turned slow, then stopped. I small puff of smoke came from the motor.
If it does not have an external reset switch, it will have a built in thermal overload that trips and should reset itself when it cools down. If this is an oil type, make sure the compressor is full of oil.
Mar 02, 2011 | Stanley NEW Bostitch 2 HP 6 Gallon...
I just bought the Bostitch SB1850BN 18 gauge brad nailer with the Bostitch CAP2000P-OF air compressor. When I hook the hose up and start the compressor, I cannot get the nailer to fire a nail. Only air...
Check the position of the switches and selectors. It sounds like you are in between settings. Also, put in a few drops of oil, and try your gun out on scrap wood, so oil doesn't come out on your good work.
--W/D--
Jan 21, 2011 | Stanley Bostitch SB1850BN 18Gauge Brad...
Type of oil used in pancake stanley compressor
An air compressor should have 30 weight non-detergent oil only, or it will foam up and not oil the bearings.
Sep 20, 2010 | Stanley NEW Bostitch 2 HP 6 Gallon...
Looking for a piston kit stanley/bostitch model cwc200wt
http://www.mastertoolrepair.com/
Try these guys. If you can't find it listed on their site e-mail them and they should be able to help.
Good luck.
Jun 09, 2010 | Stanley NEW Bostitch 2 HP 6 Gallon...
Air Tools & Compressors Logo
Top Stanley Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
River bottom
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
