Question about Stanley Air Tools & Compressors
How much oil do i put in my stanley bostitch cwc 156 1.5 hp air compressoe
  • 21 Answers
you probably have a trigger valve that is green. if so then it will have to be replaced, the valve runs about $ 20 but you can put it in your self.
Posted on Dec 26, 2008
  • 1388 Answers
SOURCE: dont know what kind of oil to put in my makita mac2400r compresso
If your compressor is used all day purchase synthetic blend compressor oil sold at lowes and other stores. It will increase the life of your machine. Sells for about $7. for 16oz. For normal use use standard air compressor oil sold at lowes, home depot and even at wal mart. Wal mart's Super Tech Air Compressor oil sells for less than $3. and works well. Do not use motor oil with detergent as this type of oil causes carbon deposits to build-up in the head and discharge hose which will eventually clog the check valve and lower efficiency. If you remove the plastic sight glass, use caution, because this part easily cracks. Purchase a spare sight glass and keep in your tool box. Good luck
Posted on Jan 19, 2009
  • 3 Answers
SOURCE: Stanley bostitch coil nailer gun
check the safty shaft and see if something could be under trigger safty causeing it to fire.
Posted on Feb 20, 2009
  • 79 Answers
SOURCE: air coming out the trigger of a stanley air gun
Go to the Stanley Bostitch website. Click on schematics & parts. Find your model number in the drop down list. There is a list of parts and pricing. Just above the parts is a link for the schematic. Honestly, I worked on these things for years. It is best to replace the entire trigger valve. It comes as a kit with instructions grease, and a little tool to hammer your pins out. Lemme know if this helps. Please rate me
Posted on Jun 18, 2009
  • 4234 Answers
SOURCE: air is coming out by the trigger of my stanley
Usually when this happens, a new trigger assembly is needed. See the link below for more information about diagrams and parts. Typical trigger kits will cost about $25. Please note that the exact model number of the gun is required.
Posted on Feb 02, 2011
I have a Stanley Bostitch CAP2000P-OF Air Compressor. It runs constantly and won't reach the shutoff pressure. It will build some pressure. When I turn it off, I dont hear any leaks.
There is a leak somewhere... Use a soapy solution at the air tube from the compressor head to the tank (both ends) and at all air hose connections. The bubbles will tell you where the leak is and you can repair the connections from there...
Aug 17, 2013 | Stanley Bostitch CAP2000P-OF 2 HP Peak 6...
I just bought the Bostitch SB1850BN 18 gauge brad nailer with the Bostitch CAP2000P-OF air compressor. When I hook the hose up and start the compressor, I cannot get the nailer to fire a nail. Only air...
Check the position of the switches and selectors. It sounds like you are in between settings. Also, put in a few drops of oil, and try your gun out on scrap wood, so oil doesn't come out on your good work.
Jan 21, 2011 | Stanley Bostitch SB1850BN 18Gauge Brad...
Bostitch n88rh, driver won't retract, does so after disconnecting air, shoots 2-3 nails then same problem, thanks
Have you put oil in the air chuck inlet lately to lubricate? Let me know if this helps or we can investigate further
Jan 20, 2011 | Stanley Bostitch Nail Gun
Type of oil used in pancake stanley compressor
An air compressor should have 30 weight non-detergent oil only, or it will foam up and not oil the bearings.
Sep 20, 2010 | Stanley NEW Bostitch 2 HP 6 Gallon...
Looking for a piston kit stanley/bostitch model cwc200wt
Try these guys. If you can't find it listed on their site e-mail them and they should be able to help.
Good luck.
Jun 09, 2010 | Stanley NEW Bostitch 2 HP 6 Gallon...
I purchased a Stanley Bostitch N80 framing nailer from Ebay and would like to have a manual for it. How can I get one? It has a plug out of the back of it and wondered what the plug is for. Also how to...
last things first, give it about 6 drops of oil before use in the morning and again after lunch. then try going to and downloading a manual. the plug might be the air fitting that you need to connect it to a hose. Let me know if you need more help.
Dec 04, 2009 | Stanley Bostitch N80CB Coil Framing Nailer
were is the leak, all air tools need some TLC occasionally . Try putting some air tool oil in it and try it again, if this doesn't work you probably have to change a few o-ring, they break down after awhile especially if it hasn't been used in awhile .
Aug 13, 2009 | Stanley Bostitch HP118K 23 Gauge Headless...
We have a Bostitch nailer that leak out of the end
there are o rings inside the nail gun, remove the allen head screws and get replacements.
Apr 10, 2009 | Stanley Bostitch FN16250K - 2 16 - Gauge...
Air Tools & Compressors Logo
69 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
