Question about HP Air Tools & Compressors
How much oil do i put in my cwc 156 1.5 hp air compressor?
4 Suggested Answers
SOURCE: I have a 2 hp
30 weight Non Detergent Air Compressor Oil is what you should use, although any 30W Non-Detergent Oil would work. Quantity wouldn't be much since it's only 2 HP. As far as the breather plug/oil cap, you caould try FD & Sons Hardware @ 866-612-5454. They showed as being a Mincraft Distributor.
Posted on Aug 18, 2010
J-Chris Ward
  • 731 Answers
SOURCE: hello...a friend gave me a Husky air compressor,
Sounds like to much oil is there a oil glass window for the oil level as long as you can see half the window covered it is enough oil.Check the owners manual.
Posted on Feb 15, 2011
  • 1702 Answers
SOURCE: US General 2 Hp air
Hi. You need compressor oil. But if you can't find any try using motor oil. 5w 20 will do fine.
Good luck.
Posted on Jun 12, 2011
What oil do I use for a G Force 2 HP air compressor, model 50622
  • www.air-compressor-guide.com/.../air-compressor-oil Keep your compressor in top condition by using the right air compressor oil. Make your compressor run nice and smooth. Using the right air compressor oil for your ...
  • Oil - Air Compressor Oil ' RONA www.rona.ca > ... > Parts and Accessories - Compressors Compressor oil. 473 ml. For all oil lubricated air compressors.
  • Husky 16 oz. Air Compressor Oil-HDA10700AV - The Home Depot www.homedepot.com/p/Husky-16-oz-Air-Compressor-Oil-HDA10700AV/...
    • 5/5
    • 1 REVIEW
    • $2.49
    • IN STOCK
    Air Compressor Oil from Husky is designed to reduce carbon buildup in compressor valves to ensure a longer compressor life.
  • Air Compressor Oil & Lubricant www.ecompressedair.com/compressor-oils.aspx eCompressedair is your source for Air Compressor Oil & Lubricants for major air compressors and synthetic compressor oil brands in 5 gallon air compressor oil ...
  • Oil-free air compressors - Atlas Copco Canada www.atlascopco.ca/caus/products/air-and-gas-compressors/1472896 Oil-free centrifugal compressors. Oil-free reciprocating piston compressors. Oil-free rotary tooth compressors. Oil-free screw compressors. Oil-free scroll compressors
  • Air Compressor - Oil-Free Air Compressor ' RONA www.rona.ca > ... > Products > Tools > Pneumatic Tools > Compressors Air Compressor - Oil-Free Air Compressor. Oil-free air compressor. 26 gal. Vertical, saves 50% more space. 1.7 running HP. 120 V. 15 A. Easy to operate controls with ...
  • May 17, 2016 | Air Tools & Compressors
    What type of oil i have to put in the oil chaimber
    The UMC Series units do not take oil. These units are oil free.
    Jan 03, 2011 | Craftsman 15 gal Air Compressor 3 hp UMC...
    I am changing the belt on a oil less 33 Gallon vertical 1.6 hp Craftsman Compressor and want to know if the bolt that holds the piston rod on is left hand or right hand threads?
    This is standard thread, right to tighten and left to loosen.
    Make sure to put a small amout of loctite on the threads when you put it back together.
    Oct 12, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
    I have a 2 hp 4 gallon twin stack mint craft air compressor. I need the oil cap/ breather plug and also need to no how much and what kind if oil to put in the compressor
    Aug 18, 2010 | Garden
    Oil fill cup is busted
    hi buddy does the plug screw in on the threads nicely or is it tight also if it is leaking oil you may have put too much oil inside get back to me bud
    Sep 13, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
    Over service craftsman air compressor with oil
    Just find the drain plug and drain out some of the oil and put the plug back at the right time to get about the correct oil level.
    The drain plug may be the sight window itself, if you can't find one.
    If you need more help, post a comment.
    Thanks,
    Tim
    Mar 27, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
    Air Tools & Compressors Logo
    Top HP Air Tools & Compressors Experts
    x-ray man
    Level 1 Expert
    elunsford
    Are you a HP Air Tool and Compressor Expert? Answer questions, earn points and help others
