What do you do when the HDMI slots are occupied? Is there a splitter device that can be used?
    New Friend:
  • 19 Answers
NO U DO SHT IT OFF
Posted on Aug 10, 2017
SOURCE: Help HDMI Splitter Doesn't Work!
The HDMI splitter is intended to take one source to two displays. You need an HDMI switch to take two sources to one display, a device you can tell which input to select.
Posted on Jul 08, 2009
  • 191 Answers
SOURCE: Gateway Foxconn C51GU01 (105552) Problem: blue
Possible a memory socket is bad. Make sure you are using the correct type of memory including parity and compatible speeds. It is recommended to use like memory sticks in each slot. Some PCs even require the sticks to be equal memory capacity. User's guide should tell you what the compatible capacities and speeds should be. If you don't have the manual, you can get by looking up your PC model number on Gateway.com.
Bret
1-2-1ComputerServices
Posted on Oct 05, 2009
rickbrashear
  • 176 Answers
SOURCE: Projector powers up as normal, bulb comes on,
There is a source lock and source button I would unlock source lock button and the push source button until you get to your hdmi input you are using. You also may just plug in one input first and once you get the input right play with the multiple hdmis
Posted on Aug 11, 2011
ercupa190
  • 12223 Answers
SOURCE: I have a Samsung PS-42C7HD 42 inch plasma TV. I have one HDMI Slot and want to connect two or three using a splitter but can't find one that works. I have tried one but it just said not supported on s
see the diagram attached and use the converter with one input +3 output HDMI. God bless you
Posted on Jul 19, 2013
dnsnakdndjws
  • 708 Answers
SOURCE: I bought a brilliant, highly useful hdmi splitter from kvmstuff.
hdmi splitter and hdmi switcher is differet,pls check details :https://www.amazon.com/MALLCROWN-Splitter-adapter-Converter-Switcher/dp/B01I4WJV5U/ref=sr_1_1?ie=UTF8&qid=1479625360&sr=8-1&keywords=mallcrown+hdmi+splitter
Posted on Nov 20, 2016
HDMI&DVI ports already used on LG HDTV.I have X BOX 360 S,has a HDMI plug, can I use a HDMI splitter to plug in the X BOX in the DVI port ?receiving computer via HDMI now
You will not be able to split them, but they do make a HDMI Switcher, allowing you to use your Xbox 360 as number one and your PC as number 2, w you cannot mix both at the same time.
May 02, 2016 | LG Televison & Video
How do I replace hdmi connectors in tv
If your television is under warranty, have the manufacturer repair or replace it for you. If your TV has more than one HDMI port, you can use an HDMI splitter to connect multiple inputs to the one port. However, if you are confident in your soldering skills, you can repair broken HDMI port, so long as the damage is only to the connector and not to the printed circuit board to which the port is soldered.
Jan 18, 2015 | Hitachi 42PD9700 42 in. Plasma Television
How do I cable this connection please?
It depends what input connection the second TV has available. You cannot directly daisy chain HDMI cable from Apple TV to the two TVs assuming both have HDMI input. But you can purchase an HDMI 1x2 splitter and connect the 3 up provided the 2nd TV also has HDMI. The challenge maybe the distance you can have between the two TVs. Max is 15 meter but you could cascade 2 units to create longer distances.
http://www.ebay.com/itm/HDMI-Splitter-Box-High-Speed-Full-HD-1X4-4-Port-Hub-Audio-Video-1080p-Amplifier-/191120909726#ht_2675wt_1337
Apr 28, 2014 | Televison & Video
Cintiq 13hd out of range
pls check hd mi splitter and hdmi switch is different,pls check details
Amazon com MALLCROWN 4 Port 1080p HDMI Splitter with Ac Power adapter...
Jan 18, 2014 | Computers & Internet
Switch to hdmi
http://lsm-video.en.alibaba.com/
3DHDMI Splitter, 4k HDTV SPLITTER
3DHDMI Switcher, 4k HDTV SPLITTER
3DHDMI Converter,Audio
Splitter,Audio Converter,Audio
Matrix and others AV Products.
You are welcome to contact us today.
Duke Chu
Jan 02, 2014 | Televison & Video
Projector powers up as normal, bulb comes on, displays Optoma logo on screen and menu will show on screen. The issue is that although I have 3 devices plugged into the HDMI port of the device using a HDMI...
Aug 11, 2011 | Optoma HD20 DLP Projector
Just to let you know you could have bought it for 80.00 on this link. http://www.directron.com/hdmimx32.html?gsear=1
Also I have not heard anything good about the HDMI spliters.
Good Luck
Apr 16, 2010 | Computers & Internet
Jun 06, 2009 | Toshiba 26HF85 26 in. Television
Televison & Video Logo
Top Televison & Video Experts
