Question about Garden
How adjust the speed of lx310? - Garden
I'm loading 10x12inch paper on my LX310 printer but the print out result is the size of A4 pliz help
Go to your computers settings under devices. Click on printer and change the settings for the paper size.
May 06, 2017 | The Office Equipment & Supplies
When your Snapper 21" walk mower has no adjustment for engine speed and runs at high speed all the time how do adjust it manually. DannyMarshall23@yahoo.com
there is a spring that is hook to the throttle through a lever if you bend the lever you can adjust speed
Sep 23, 2014 | Garden
Adjust idle
Hi Sean
Before you remove or try to adjust your low and high speed jets you should always count the number of turns it takes to lightly seat the idle mixture screw and high speed needle adjusting screws.
Be sure to write the number of turns down on a piece of paper so you will know how many turns from the seated position to open the jets when you go to reinstall them, or if you remove them for cleaning or replacement.
If you have aready tried to adjust them then the adjustments below should get it running for you for final adjustment when warm.
Normally you will adjust your idle jet to 1/2-3/4 turn open from the bottom seated position.
Then you will re-adjust the low speed of the engine when the engine is warm by turning the idle screw in or out till the engine runs smoothly at idle speed, around 1200 RPM.
The high speed jet is adjusted to 1 1/2- 1 3/4 open from the bottom seated position, after the engine is warm.
Then re-adjusted by turning the High Speed jet adjustment screw in or out till the motor runs smoothly at high speed.
Alway use the "lightly seated" method if you have not changed the screw settings.
Bud
Oct 11, 2013 | Husqvarna Garden
Husquvarna chainsaw carb adjusting
Hi Mark
Please take time to rate me
Bud
Nov 24, 2012 | Garden
I need the users manual for a Logtech Model320 keyboard/mouse
Copy and paste the below URL into your address bar.
http://www.logitech.com/assets/34477/lx310-installation-guide.pdf
May 31, 2011 | Logitech Computers & Internet
Describe your Nintendo Probleml logitech wireless keyboard lx310 does not link to wii system?
Wireless keyboards will only work with Wii of it has a 'USB Wireless Receiver' (also called a dongle) which plugs into the back of the Wii. So make sure that is plugged into the Wii USB port at the back.
Although the Wii uses bluetooth for the Wii Remotes, you cannot use bluetooth for keyboards.
ALSO... the Wii USB ports are only USB1 (Not USB2). Therefore some fancier keyboards may not work if they require USB2.
Mar 13, 2011 | Nintendo Computers & Internet
How do you adjust the high speed mixture screw? I have a Ryobi RLH1100a MK III 31cc line trimmer, and after changing the fuel lines, it will start but not idle more than about 3 - 5 seconds before it...
Hi montex124, I will try to help. In the past few years carb makers have been making changes. Some carbs have no adjustment at all, the ports are all fixed inside the carb. Other carbs have only the idle speed mixture screw that can be adjusted, like yours seems to have. Is this screw you mention at the top and completely outside of the carb to adjust the throttle? If it is it's probably the idle speed screw which can be adjusted to any idle speed you want and has nothing to do with the air fuel mixture but If it is right next to the idle mixture screw, it might be the high speed mixture screw but is capped so it can't be adjusted. The low and high speed mixture screws should be marked next to each screw H and L.
The 1 1/2 turns suggested is sometimes just right but other times has to be adjusted, so you can try adjusting it to get your idle but maybe adjust the idle speed screw first to get a higher RPM so it doesn't stall on you. Like I said earlier it just adjusts the throttle, and is like when you are using it, and giving it gas as they say. I hope this helps just a bit. Regards and good luck. Get back to me if you need more help or just let me know how you did. Denis.
Feb 28, 2011 | Ryobi Garden
020 stihl stops running after you let up on the trigger
Most likely this is caused by one or both of the following. The low speed jet needs adjusting or the idle speed is adjusted too low. Most saws the user can adjust the idle speed as the adjustment screw is not protected. Adjust the idle speed so that the chain just stops turning. It may be necessary to adjust the speed up till it will stay running for you and then start turning it down till the chain stops. If the low speed jet needs adjusting it may be a better idea to run it by a Stihl service center and have them tune it up for you.
Jun 27, 2010 | Garden
Mouse Pointer Doesn't Move
return that , it isn't your pc
Jul 04, 2009 | Computers & Internet
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
