Question about Blenders
I need a part - a pitcher base for blender 169169
The black plastic screw on bottom of the pitcher is stuck on the base. We can't seem to get it off. Have any hints
Put the pitcher in the freezer for an hour, boil water in a pan bigger than the base of the pitcher, take the pitcher out of the freezer and stick just the base in the hot water up to the top edge of the base.. Remove it after about 15 seconds and have someone with gloves on screw the base off the pitcher
Aug 20, 2015 | Blenders
Where do I find a replacement pitcher?
Link, Can you tell me what brand your blender is? This is usually found under the blender base or right on the front where the buttons are. Then we can tell you whether there are replacement parts or not.
May 08, 2015 | Blenders
Pitcher stuck on base
You will likely need to replace the beaker anyway, the drive which is now melted to the motor coupling is only supplied as part of the beaker/blade assembly. You will also need a motor coupling.
Aug 01, 2012 | KitchenAid Blenders
How do I fix or replace my kitchenaid blender blade KSB560BF (Polycarb Jar)? It's leaked thru the blade assembly.
Make sure the blade assembly is put together in the correct order. The blade needs to go through the gasket so that the order is pitcher glass, gasket, and metal blade base. Then the final plastic cap threaded onto the pitcher. If the gasket is not between the pitcher and the metal blade assembly, you will have leaks.
Also, check the gasket to be sure it's not cracked and that it doesn't have residue on it.
I hope this helps. If it does, please come back and rate my suggestion!
Jun 15, 2011 | KitchenAid KSB560 5 Speed Blender
KitchenAid Blender Model KSB560GC0. Coupling is ruined. Looks to be a geared part at the base of the unit. [ top of motor ] Also there is a part that is geared at the bottom of the pitcher, attached to...
the older glass jar blenders were sold as a complete ***'y too.
no separate parts were available. i'm sure the stainless jars are sold in the same way...complete.
Jun 24, 2010 | KitchenAid KSB5 Professional Stainless...
The blades stopped turning in the middle of blending a batch of hummus Its is a Kitchen Aid blender about 10 years old
Does the motor still work if you take the pitcher off of the base? If so, the rod that's in the blade assembly is probably corroded. The blades are connected to a metal rod that passes through a brass tube through to the piece that makes contact with the motor when you put the pitcher on the base. The grease wears down eventually and if you don't pulse and run the motor for a long time at once, the heat can corrode the bar and cause the blade to stop spinning. You can either disassemble the blade unit, or buy a new blade unit online. google blender parts and you can get one for $10
Dec 22, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Waring blender BB180
try to soak hot water around the base unplug firts and pour hot water slowly at the base
Dec 28, 2007 | Waring BB180 Work Top Blender
Blenders Logo
114 people viewed this question
Top Blenders Experts
eyecam
Are you a Blender Expert? Answer questions, earn points and help others
