Rockola 449 no power to band A? Will not read side 1 on read out side
Need stylus type for 463 rockola jukebox.
hi Stephen.
if you go to this link you will see on the right hand side of the page where you might be able to get one from.or you could try ebay.
where to buy stylus for 463 rockola jukebox Google Search
Dec 01, 2017 | Audio Players & Recorders
Cam specs on a 1967 Pontiac 400, 335 hp
Firebird App. Pontiac Part # Duration @ .050 Degrees Int/Exh Adv Duration Degrees Int/Exh Lobe Center Degrees Int/Exh Lobe Separation Angle Overlap Cam Lift Int/Exh Gross Lift Int/Exh
(1.5:1 Ratio Rocker) Gross Lift Int/Exh
(1.65:1 Ratio Rocker) 1977 TA6.6 549431 274/289 62 .249/.270 .374/.406 .411/.446 1978 TA6.6 10003402 273/289 54 .270/.271 .406/.407 .446/.448 1979 TA6.6 10003402 274/298 55 .249/.270 .374/.406 .411/.446 1967 400, 1968 350, 1973-76 400 w/ AT 9779066(E) OEM 200/210 273/282 106/116 111.25 55 .272/.271 .408/.407 .449/.448 1967-68 400HO w/ MT 9779067(P) OEM 200/213 273/289 113.5 54 .272/.271 .408/.407 .449/.448 1968 400 HO MT & RA-I AT, 1969 350 HO MT, 1969 400 MT, 1970
RA-III MT/AT, 1971-72 455 HO MT 9779068(S)
OEM 212/225 288/302 113/118 116 63 .272/.271 .408/.407 .449/.448 1967 RA MT/AT, 1968 RA-I MT,
(Some 1969 GTO RA-III MT) 9785744 (H)
OEM 224/236 301/313 112/119 115 76 .272/.271 .408/.407 .449/.448 1968-70 RA-II & RA-IV MT/AT 9794041
(T) OEM 230/240 308/320 112/115 114 87 .313/.313 .470/.470 .516/.516 (Stock in RAIV)
Sep 20, 2017 | Pontiac Cars & Trucks
Jukebox manual
Many on eBay
http://www.ebay.com/itm/Original-Rockola-Jukebox-Model-488-Service-Manual-w-wiring-diagrams-/231244858100?pt=LH_DefaultDomain_0&hash=item35d74482f4 Original Rockola Jukebox Model 488 Service Manual wiring diagrams
Aug 05, 2014 | Collectibles Jukeboxes Book Rockola...
Rockola jukebox keypad doesnt work
If the whole panel is out it sounds like a missing or bad ribbon cable. start there and tell us what happens.
Nov 21, 2013 | Neonetics Rockola Jukebox Neon Clock
Rockola Model 490 2 Super Sound Juke Box wont power on
(1) Make sure the wall outlet has power. (2)Make sure the power switch is "on" (3) check the fuses. If you discover a blown fuse, be sure to replace the fuse with the correct value. If it blows again, you may have a more serious problem.
May 26, 2013 | Audio Players & Recorders
I need a watch band for Model CY 2085 Callaway Watch.
customer service at Fossil, 1-800-449-3056, good luck, Michael
Jan 28, 2011 | Callaway Golf Unisex CY2085 Collection...
Remote code
1. programed RCVR with code 0314
2. then assigned a key (such as the TV/VCR key) with the EFC number of 300
3. then reprogramed RCVR w/ code 0027
498 "surround mode"
568 "+10"
578 "band"
370 "stereo"
702 "6"
444 "4"
447 "2"
317 "8"
701 "0" (zero)
450 "7"
704 "5"
707 "3"
449 "1"
577 "9"
384 "tape 2"
252 "mute"
255 "vol down"
512 "power"
515 "vol up"
572 "channel down"
257 "channel up"
Try This an see if works
Oct 19, 2008 | Kenwood VR-209 Receiver
My mp3 player
Read the manual. Call a neighbor. Call RCA, 1-866-449-7112
Your question is way too general for this forum.
Apr 29, 2008 | RCA OPAL M4001 MP3 Player
23 people viewed this question
 Grubhead
Grubhead
