Question about Building Materials
My door opens and closes without any input from my remote. What is causing this?
I have been experiencing this problem for a couple of months. I don't have the manual for this Wayne Dalton model 1145KC to try and reset the unit to purge all the old codes and learn new
SOURCE: Garage Door issue
Posted on May 26, 2008
SOURCE: Garage Door Remote Not Working Consistently
Lift Master Security Plus remote works only intermitenly, It seems to lock after a few tries, Works from inside garage, Seems to lock up after few tries, Wall opener fine. Changed batteries several times. Can't understand why it works and then doesn't. Tried cleaning sensors and wires,
Posted on Oct 29, 2008
SOURCE: My Wayne Dalton garage door will open with remote but not close
your infrared sensor is either misaligned, faulty, or you have a broken wire from your sensor to your door opener. (Flashing light indicates infrared light path is broken). both sensors should indicate green led. door wil not come down is safty feature to prevent door from closing when light path is broken.
Posted on Jan 16, 2009
SOURCE: Wayne Dalton DoorMaster Model BDOR-2000/BIRW-2000
Check the contact at the bottom of the socket and (with the unit unplugged) lift (or pull) it up to make contact with the bulb easier or tighten the bulb a bit more than normal.
Does the light ever come on?
Posted on Jul 28, 2009
SOURCE: Can't get the Wayne Dalton 3016 remote to work and the new univer
I am having the same problem. Bought universal remote from Lowes and won't work with the Wayne Dalton. Not sure what else to do but keep looking for a system that uses the 303 Mhz not the 372.5 as suggested in the "Clicker" manual. If anyone figures it out post it. Thanks.
Posted on Mar 07, 2010
My garage door is opening without my activating it w/my remote.
Hi Gregory.
Look in the user manual for your garage door opener to see if there is a solution for the problem you are experiencing. You may have an issue with your remote. Try removing the battery and see if the problem continues. If the door does not open your remote is bad. If the problem continues your garage door opener will more than likely need to be replaced. Hope this helps.
May 23, 2017 | Building Materials
Trunk will not close
check that latch is releasing when using remote. remote uses a cable to pull latch and cable may need to be lubed causing the latch to stick open. Let me guess if you slam a couple times it will latch, lube the actuator cable and latch well. hope this helps
Jul 17, 2014 | 2007 Toyota Camry
Lift master formula I will not close, only goes half way down, but fully opens. Worked fine until my wife closed the door on the car, after that it would fully close
I had this problem as well with the door opening just fine but was not closing when using the remotes or when breifly pressing the wall mounted control. The door would close only when using the wired wall mount control. I have experienced this problem with other garage door openers I've had in my previous homes and it was always caused by sensors at the bottom of the door tracks being either misaligned or the lenses were dirty. In this case, and it was just a moment ago today, I simply cleaned the sensor lenses and then the door began to function properly. Give it a try.
Jan 28, 2013 | liftmaster Chamberlain Garage Door Opener...
I have a Sears craftsman model 139.53637SRT garage door opener. My remote has not worked in a long time. I use the wall control button and have to hold the button in order to open or close the garage door....
It sounds like your door sensors may be bad or misaligned. Make sure the small light on each sensor is lit and not flickering. That could be the cause of your having to hold the wall button down until the door is closed. You can buy a universal remote but if you only had one remote before it could be the receiver that has quit. A new remote would not fix that but the only way to find out is to try.
Aug 15, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have remote starter about year ago,after a few days i found there is some electrical problem,i was answered that it is ok.Then i noticed that my car started without activating remote,i just opened the...
i am a 25yr toyota man and all of this aftermarket stuff just causes headaches. if the people that installed the system can not fix it i would take it all off and i will bet that the problems will be gone.i have also seen wiring harness problems in the drivers side door between door and body where it is flexing when door opens and closes all the time cause only the door looks on windows not to work.
Jun 16, 2011 | 1999 Toyota Camry
I have a Sears Model 139.53879 (3-Function Remote Control) garage door opener. It's about 12 years old. The remote controls open the door fine but the remotes do not close the door; it has to be closed...
Sounds like a problem with the safety photocells, to confirm locate the where the safety input is on the opener and bridge out the terminals ( not the supply voltage terminals) if the door then closes the photocells are the problem.
Mar 31, 2011 | Sears Genie Garage Door Gpwk12 Wireless...
My garage door opener opens fine from the wall unit and the remote, however closing is a problem, when closing the door from the wall unit I have to press and hold until the door is fully closed, if I...
You have a door sensor problem. The IR sensors found at the bottom of the door rails will need some attention.
Both have an LED visible. Is one on or none? If none are on, check the wiring. Older models had a plug in the rear of the sensor that corroded due to moisture, causing intermittent or no operation.
If 1 is on, check to be sure that they are aligned with each other. If they are crooked, the door will not close without holding the wall button (as you described). They are easily knocked out of alignment.
Check for cobwebs and debris blocking the sensors.
Replacement sensors are around $50 and are easily installed with just wire cutters and pliers. Remember to unplug the unit before replacing the sensors.
Dec 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
Motor wont run on craftsman opener
You need to remove the cover and look at the drive gear. It is probably stripped. I really recommend a technician to repair your door.
May 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Partial opening/closing
Mar 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Master 1/3 HP 1997 Door Working, not responding to Remote
I have the exact same situation, except my model (139.53607) is older than yours and does not even have an LED. Remotes only works after after shop light goes off (5 minutes or so), but wall button works fine. Did call Sears Service and the tech told me the logic board is probably shot. Don't want to waste money on service call so I'll probably have to buy a completely new unit in the Spring and go through the winter without the use of a remote.
Jan 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
111 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
