Weight of a cubic yard of road base - Office Equipment & Supplies
2 Suggested Answers
Sub Zero
  • 55 Answers
SOURCE: what weight oil goes in transmission on a 1999
Mostly all motorcycles use the same oil in their Engins and transmission, you do not needs to put a seperate oil into the transmission, as the engin and transmission uses the same oil, you will also see that there is nowhere that you can top up the transmission oil, most motorcycles use 20W50 oils, but it can also depend on what country you are from
Posted on Aug 29, 2010
Dump truck sizes
A dual axle dump truck (ten wheels) is normally rated at 10 cubic yards (270 cubic feet) load capacity.
A single axle dump truck (six wheels) is normally rated at 5 cubic yards (135 cubic feet) load capacity.
These are volume measures not weight measures.
Oct 09, 2017 | Cars & Trucks
What is 0.89cubyds in pouds
Cubic yards is a measure of volume while pounds is a measure of weight. There is no direct conversion between them because it depends on the density of the substance. For example, 0.89 cubic yards will weigh a lot more than 0.89 cubic yards of feathers.
Oct 30, 2016 | Miscellaneous
What weight in pounds is 0.89cub yds
Oct 30, 2016 | Office Equipment & Supplies
How many yards are in one ton?
One is a measurement of length, the other is a measure of weight.
however, you might be referring to 'Cubic Yards'?
depends upon the rock type and how fine it is, but one reference notes that one cubic foot of gravel typically weighs about 100 pounds.
So 1 ton has 2000/100 or 20 cubic feet of gravel. A cubic yard is 3x3x3 = 27 cubic feet to the cubic yard
Answer is 20/27 or 0.74 cu yard. I'd round that to 3/4 cubic yard.
Jan 09, 2016 | Cars & Trucks
I needs to convert 1,361 cubic yards of 3/4" crushed rock to tons
Using the weight info provided in the link - 1 cubic yard could be about 2,780lbs. Depending on water content, density of and type of stones in the mix - 1 cubic yard could approach a weight as great as 4,000lbs.
Let's assume for easy calculations that an average cubic yard weighs 3,000lbs. (or 3,000lbs/2,000lbs = 1.5 tons).
That means 1,361yds x 1.5tons = 2,041.5 tons.
Lighter average cubic yards as mentioned in the link? Then 2780lbs/2000lbs = 1.39tons/yd. - or -
1361yds x 1.39tons = 1891.9 tons
Heavier average cubic yards as mentioned in the link? Then 4000lbs/2000lbs = 2tons/yd - or -
1361yd x 2tons = 2722 tons.
How Many Tons In 1 Cubic Yard Of 3 4
Oct 15, 2015 | Office Equipment & Supplies
Convert tons to yards
something wrong with that question:
because "ton" is for WEIGHT
and "yard" is for DISTANCE!
short ton = 2,000 lb (about 907.18kg).
1 yard = 3feet = 36 inch or 0,9144 Meter
Feb 15, 2015 | Miscellaneous
How many tons are in 941.39 yards
Ton is a unit of mass (or weight), yard is a unit of length. There is no direct conversion between them.
Do you mean 941.39 cubic yards? If so, cubic yards of what? 941.39 cubic yards of water weighs about 720 tons. 941.39 cubic yards of lead weighs about 8160 tons.
Aug 25, 2014 | Cars & Trucks
200 yards to cubic feet than cubic feet to tons for chicken manure that's been composted
You say 200yds do you mean 200 sq yds or cubic yds? There are 9 cubic feet in a square yard 1ft deep and 27 cubic ft in a cubic yard. You will have to know and factor in the weight of 1 cubic ft of manure to get your tonnage. 2,000 lbs in a short ton.
Aug 22, 2014 | Office Equipment & Supplies
How many pounds of soil equal 1 yard and 1/2?
That can vary quite a bit depending on what's in it. And there is no established definition for the stuff you can buy from a landscaper.
Easiest way to get a good estimate is weigh the contents of a 2.5 gallon bucket and multiply that by 81 to get the weight of one cubic yard.
Here are some ballpark figures ---
Cubic yard of dry sand = 3200 lbs. Cubic yard of wet sand about 3600 lbs Cubic yard of dry peat moss = 160 lbs A 50/50 mix of wet sand and (dry peat) organic material = 1900 lbs.
Apr 01, 2010 | McCulloch Lawn Care: Trimmer Plus...
k24674
jasbo
jasbo
