Question about GE Kitchen Ranges
How do I instal an anti-tip bracket on a GE range model # JCB630DKWW
mikedem7
  • 25 Answers
SOURCE: Removing an old old microwave oven
look in the cabinet above the microwave, there should be 2 bolts which go through the bottom of the cabinet and screw into the microwave. remove these 2 bolts holding the unit steady then tilt the unit down and away from the wall.
Posted on Aug 19, 2008
SOURCE: anti-tip bracket for Amana ACF422GAW
thats the stupidist thing ive ever heard.
Get a propowe bracket, which goes around teh foot of the stove.
Posted on Oct 02, 2008
SolutionGuy
  • 331 Answers
SOURCE: oven anti-tip bracket
Hi Jodie,
The anti-tip kits are installed on the floor behind the oven. They're installed BEFORE the oven is moved into place. They are "U"-shaped and when the oven is slid into place, the "U" locks into the back legs of the oven to lock it down.
You can tell if yours is so equipped by simply sliding the oven out away from the wall about 10 inches then looking behind it on the floor. Slide the oven out by opening the door about 5" and place your hands inside... then lift and pull toward you at the same time.
Here is the anti-tip kit for yours... If you see this down there, then you're good to go. If not, order both of those parts (in the previous link) 'cause you'll need them.
Hope this helps!
SG
Posted on Apr 22, 2009
jsrock516
  • 5911 Answers
SOURCE: Where and how to install
The anti tip bracket is installed along the baseboard area BEHIND the range, so that one of the rear feet on the appliance will slide into it when pushed against the wall. Once installed, the rear foot of the range is slid into the bracket, holding the rear foot to the floor. This effectively prevents the range from tipping forward.
Installation instructions are included on page 3 of the Installation Manual that came with the appliance. If you no longer have a copy, you can obtain a replacement at managemylife.com. Just enter your model number under their "Manuals" link and you will find it listed in .pdf (Adobe) format. You can download or print a copy for FREE. For your convenience, here's a direct link:
http://www.managemylife.com/mmh/installation_guides/3001/MAYTAG-Free-Standing-Electric-L0502644?brand_name_search=mer5775q
Figure 3 shows an excellent illustration of how the bracket is to be installed.
If you have any questions, please post back and let me know. I hope this helps you.
Posted on Oct 21, 2010
  • 5370 Answers
SOURCE: I need a mounting bracket
The mounting bracket for your oven unit. See the fig:--The mounting bracket:--- helpmech_7.jpg
to get this mounting bracket click on the link below:----- http://www.repairclinic.com/PartDetail/Mounting-Bracket/1472896 ---------- Thanks.Helpmech.
Posted on Dec 06, 2010
CRACKED GLASS GE - JB968
1 Unplug cooktop or disconnect power.
2. Remove the cooktop from its mounting
location, (see “Installation Instructions” in
Section 2). Position the cooktop so that
you can access the bracket screws below
the cooktop glass
3. Remove the fourteen flat-head screws
from the front, rear, and side ceramic glass
brackets.
4. Remove the two small side brackets from
the cooktop base.
5. Lift and remove the ceramic glass from the
Oct 13, 2008 | GE Profile JB968 Electric Kitchen Range
1 of 2 bulbs in upper unit stopped working. I replaced the bulb 10W, 12v & both bulbs worked. Later, both bulbs stopped working. Both bulbs have continuity. New bulbs don't fix issue. Ideas??
Thermador Appliances ' Frequently Asked Questions ' Use ...
www.thermador.com/faq/categories.php?categoryid=53
ThermadorContact us for help with service & repair needs. ... The anti-tip bracket is not needed for 48" Harmony units. However, the anti-tip ... Oven light is not working properly. Replace ... Buy a replacement bulb. View the ... The rack positions that you would use when baking 3 racks in the convection mode would be racks 1,2 and 4.
Thermador Range/Stove/Oven Parts - RepairClinic.com
www.repairclinic.com/Shop...Parts/.../Thermador-Range-Stove-Oven-Par...
Huge selection of Thermador Range/Stove/Oven parts in stock. Same day ... Stove top potentiometer Kit that contains 2 potentiometer's and 1 simmer controller.
[PDF]for Thermador Professional Series Built-in Wall Ovens
www.msaworld.com/.../Service-Manual-Therm-Pro-BIWO_RevA3.pdf
Dec 19, 2015 | Thermador C272 Electric Double Oven
Heating element disconnected
Make sure to keep breaker to oven off because wire could short against back of oven and start a fire. You need to disconnect the tilt bracket and pull the oven out. Replace the clip on the wire if needed. Make sure to reattach tightly. Put it back in the wall, reattaching anti-tip bracket. It should work.
Jun 02, 2014 | GE JRP24 Electric Double Oven
Jvm230wl I want to replace my over the range GE JVM230WL model but I'm not sure the exact dimensions. It appears to be a snug fit in the bracket so the measurements need to be manufacture specific. Also,...
GE Customer Service is here. They may be able to tell you if there is a "drop-in" replacement available for your model.
Otherwise, you'll have to take down the old bracket then mount another model in the space.
Jan 15, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
GE PROFILE MICROWAVE MODEL JEB1095SB002 Making
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Aug 05, 2011 | GE Profile Over-the-Range Microwave
Where and how to install anti tip bracket
Oct 21, 2010 | Maytag MER5775Q Electric Kitchen Range
Oven anti-tip bracket
Hi Jodie,
Hope this helps!
SG
Apr 22, 2009 | Ovens
Anti-tip bracket for Amana ACF422GAW
screw in a piece of wood or metal that stickes out a little ways horizontally across the back of the stove. Screw another piece of wood or metal onto the wall a tad bit higher then the one on the stove. Now the stove can't tip over and it'll be easier to manuver into place.
Aug 11, 2008 | Kitchen Ranges
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
