Question about Dishwashers
I'm having a dishwasher that is keep pipping with the code 39 on the screen , please help me, thanks
3 Suggested Answers
ripleymojica
  • 643 Answers
SOURCE: PIP DOES NOT CANCEL FROM LARGE SCREEN.
your cable or dish box may have a pip function.
Posted on Jun 02, 2009
terrydovre
  • 181 Answers
SOURCE: HOW DO YOU TURN OFF PIP ON HP LC3260N
Hello, it's not PiP that's on , it[s a closed caption issue. the CC is in the text mode and is an easy fix. just press the CC button on the remote (it's located above the 1 button) till it says off on the tv screen, or if you use closed caption select CC1. this should take care of your problem......thanks, Terry
Posted on Sep 20, 2012
Testimonial: "Thank you Terry, that fixed it! "
Sep 20, 2012 | HP LC3260N 32 in. LCD HDTV
I have a 1776 Asko model & it doesn't finish its cycle-code mesage f-2 keeps appearing. Can you help me out.
Hi
F2 is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Sep 18, 2011 | Asko 1375 Dishwasher
I have a element flat screen tv and my screen keep splitting in half when we are watch it.
Well, you didn't offer a whole lote of info, so I imagine that is why responses have been slow. It isn't clear at all to me what the symptom is, but perhaps it is a PiP issue, either hardware based, or a setting accessed through menus.
What is the video source? For example a Dish Network HDDVR will most likely have a pip function, which splits the screen. Not knowing what is being split, or how it is very difficult to say.
Sep 10, 2011 | Denon AVR-687
We have a 4 year old dishwasher.It is not washing as good as it should.The machine seems to rinsing the dishes etc in soiled water.I've checked the syphon and it doesn't appear to be blocked.I...
Hi wesalado,
Please follow my Tip below on some hints on how to keep your Dishwasher in tip-top shape:
DISHWASHER NOT CLEANING PROPERLY ANYMORE...
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 08, 2011 | Zanussi Dishwashers
I want to turn off the pip, the square turned up in the right top corner a different channel then the big screen. I forget how to get it off the screen, sony wega 2003 how do i turn the pip off. i have...
try this..press the set up button infront of the TV control... not the remote control.... and try all the menus.... it worked with my TV... or I just get lucky!!!!. It would be nice to know that I will be able to help someone....
Aug 29, 2010 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Jun 02, 2009 | Sony BRAVIA KDL-46V3000 Television
No picture in picture regardless of any way I wire the tv HELP
Thank you for providing the exact brand and model number of your product.
What it is: PIP lets you watch a second program in a little window. More-elaborate versions can resize the window, move it around the screen, create still or multiple still images, or simply divide the screen into two same-size pictures, often called "picture-outside-picture" (POP).
What it isn't: PIP has a dirty little secret, though: If you use an external tuner such as a cable box or a satellite receiver, you can watch only one program at once. If some of your channels are unscrambled, you can watch those on the second window, and you can usually watch other sources such as VHS or DVD on it, as well. But even with two-tuner PIP, a single cable/satellite box will prevent you from watching two live scrambled channels simultaneously unless the box itself has two-tuner PIP.
Thank you for choosing FixYa!
Az.
Sep 20, 2008 | Samsung LNT3242H Television
PIP
this tv does not have 2 tuners. So you will be unable to get 2 different channels on one screen. I have the same tv. The PIP is only good for watching a dvd/video and tv swapping only.
Apr 08, 2008 | Toshiba 50A60 50" Rear Projection...
Magnavox pip
PIP requires either multiple tuners, or another video source. It sounds like your tv lacks another tuner. Does the tv have inputs for, say, a vcr? If so, connect a vcr to it, play a video, and then select PIP. It should display the video and tv simultaneously.
Nov 13, 2007 | Televison & Video
Help with error code AL7
In some cases turning the machine on and off might solve the problem. Good luck !
Aug 06, 2007 | Zanussi 24 in. DE6965 Built-in Dishwasher
Dishwashers Logo
29 people viewed this question
Top Dishwashers Experts
Owen Barnes
