Question about Brother Sewing Machines
Can the clip that you snap the hoops into on Brother pe770 be replaced?
  • Brother Master
  • 9,302 Answers
Most likely. Check with your local Brother dealer.
Posted on Aug 10, 2017
2 Suggested Answers
  • 12 Answers
SOURCE: Brother PE770 Hoop size programming stuck on small hoop option
Your machine would be able to perform 5 X 8 embroideries. The hoop size on this machine is recognized by the machine itself, depending of the embroidery file size. So it the embroidery is small, it will indicate that the small hoop is needed.
But U can use the large hoop, position the embroidery where U want then perform another embroidery on the sams hoop.
TRICK : the embroidery size exceeds the hoop? reduce it in X and or Y using this function on the machine
Posted on Jul 07, 2012
PE770 thread seems to be getting hung up on metal hook behind bobbin assembly
If thread is getting wrapped behind the bobbin assembly, most likely your machine needs service as thread behind the bobbin assembly should not be a normal occurrence.
Aug 25, 2016 | Brother PE770 Embroidery-only Machine with...
My brother pe770 jamming up and i get this error msg that says check and rethread upper thread
I find that most problems for me have been from poorly wound bobbins or very dense designs. With the dense design, when nearing the end the hoop starts catching/jumping up with the needle, breaking thread. I use software to decrease density one or two increments then embroider. Clean out the bobbin shuttle and the upper thread path. Change needle & make sure your stabilizer is appropriate for the fabric. If too lightweight it tends to shred causing issues.
Sep 05, 2014 | Sewing Machines
Sewing machine sews only when the light is on
sounds like there is a short somewhere in the machine and needs to be checked
Jul 16, 2014 | Brother PE770 Embroidery-only Machine with...
Why is the upper thread is bunching under the faberic
Most likely the machine is not threaded correctly or the material is not properly streatched and locked into the hoop.
Jul 08, 2014 | Brother PE770 Computerized Sewing Machine
Handwheel is locked down
Several things to check. Did the needle break and jam in the bottom? Is the needle bent or did it jam in the bobbin area? I had a 'knot' of thread build up on the bottom and it hooked itself into the metal clip on the bobbin so that the needle couldn't raise. If thread jams in the bottom cut the threads until you can free the hoop and material. Check the bobbin for pieces of thread and fuzz. Check to see if the bobbin case or the throat plate is scratched or bent. If you are stitching Free Standing Lace on this machine or a piece with over 20,000 stitches I recommend starting with a new full bobbin and a new needle. As you get toward the bottom of the bobbin, thread seems to have a high likelihood of tangling or looping and will cause a jam which means the handwheel locks.
Sep 23, 2013 | Brother PE770 Computerized Sewing Machine
When using the cutting thread button on the brother pe770, it's pulling the shirt down and wont release
the machine may need to be checked to see if there is something
wrong with the connection between the button & the cutter
Sep 13, 2012 | Brother PE770 Computerized Sewing Machine
Jun 10, 2012 | Brother PE770 Computerized Sewing Machine
Embroidery machine is making grinding noise and carriage doesn't move. Then, screen says malfuntion, turn machine off.
Just because the hoop holder has been moved during transportation. Shut down the machine, manually bring hoop holder in central position in both X and Y, it will restart.
Apr 20, 2012 | Brother PE770 Computerized Sewing Machine
My brother pe770 hoop is not centered. Needs calibrating
I am having the same problem. My brother pe 770 is only 3 weeks old and the hoop is not centered. How is there a need for it to be calibrated already???? If I create something it may be 3 inches from the left side and 33/8 inches from the right side. Any idea what gives? Thanks.
Sep 10, 2011 | Brother PE770 Computerized Sewing Machine
Sewing Machines Logo
24 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
