Will not leave startup screen and all I hear is voice telling me what I have my mouse on
Will not boot to safe mode imac g4
Starting up in Safe Mode Follow these steps to start up into Safe Mode.
  1. Be sure your Mac is shut down.
  2. Press the power button.
  3. Immediately after you hear the startup sound, press and hold the Shift key. The Shift key should be pressed as soon as possible after startup, but not before the startup sound.
  4. Release the Shift key when you see the Apple logo appear on the screen.
After the Apple logo appears, it may take longer than usual to reach the login screen. This is because your computer is performing a directory check as part of Safe Mode.
To leave Safe Mode, restart your computer without pressing any keys during startup.
Sep 25, 2014 | Apple Computers & Internet
I cannot hear callers voice yet caller can hear me
Sounds as if you have gotten it a bit wet, do you have a red strip on your phone to tell if you have gotten it wet?
Jan 03, 2014 | Nokia E71 Smartphone
I have samsung N120 Laptop.display has gone blanks but I can hear windows startup voice
Hook a spare monitor to the video output usually on the back, if picture okay! the inverter board is defective, " just below the LCD screen" or the backlight has failed, "just behind the display" but if both show the same symptoms it is the video graphics card normally built into the motherboard.
Apr 07, 2012 | Samsung Computers & Internet
Gateway dx4840-11e. During video can hear music but not actor voices. What to do?
do you have the sound set to surrond sound? What it sounds like is that it is trying to play through surrond speakers but you dont have them, which is why you can hear the music and not the actors voices. click with the right mouse button on the speaker in the bottom right of your screen, then click on sounds , now click on the playback tab in the sound window, click on the sound device shown and then click configure, choose stereo and choose two speakers. Continue to the end then try to play the video and see if you can now hear the voices. If you cant then you maybe missing codecs needed to play the audio correctly. Please state if this is a movie you have downloaded or a dvd film on disc etc
Apr 02, 2011 | Gateway Desktop / Intel Core i3 Processor...
I turned off the touchpad on My Toshiba Satellite m55-s329 laptop which disable the mouse and keys to function. So I had to hard start my laptop. When it turned back on my screen was blank (black). The...
Please connect a USB Mouse and keyboard then power on your laptop it will boot your win xp then re enable your touchpad by going to device manager. It will work.
Sep 13, 2017 | Toshiba Satellite M55-S329 Notebook
After startup my PC I got the BIOS screen stating in "Detecting IDE drives...".but it does not detect the drives and also not enter to the further startup configuration.please give a solution of this...
Shut down computer, disconnect from power outlet. disconnect all usb devices on the usb ports and just leave mouse and keyboard connected. disconnect harddrive cable from the motherboard and hard drive and reconnect cable again.
Restart system afterwards to see if the issue was resolved.
Should you have any other questions please just leave a comment.
Cheers~
Jun 26, 2010 | Dell Dimension E310 PC Desktop
Rattling sound with any significant base output
You either ripped your voice coil, or you have something jumping around inside (Screw, nail, etc.). You can tell of a blown speaker by pressing straight in, and if you hear a rubbing noise, then your speaker has disconnected from your voice coil. Mickey mouse jobs include Krazy Glue, but It's touch and go
Sep 02, 2009 | Sunfire True Sub Signature Subwoofer
The voice on my tomtomone is very low and you can't hear it when driving
Assuming you have a TOMTOM Go.
The volume is on the touch screen. You have to tap about 1/8 of the way up the screen from the botton.
A slide volume should come on the screen.
Regards and hope this helps...
James
May 28, 2009 | Tomtom ONE 3rd Edition GPS
Black screen startup
hello..this is the 1st you need to try..if you have a CRT monitor or LCD Screen try to put the signal Video on the Laptop located at the Back of unit then try to boot your unit...Thanks...
May 10, 2009 | ASUS G1 Notebook
Monitor problem
i have the same problem , so after the p.c. is turned on and gone through it;s startup procedure, i wiggle my mouse and press the last button to my right on my monitor , and there you go, hope this helps?
Jun 08, 2008 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
