Will not leave startup screen - Computers & Internet
  • Computers & ... Master
  • 2,131 Answers
Time to reboot and to try to enter safe mode. See if it gets you past the startup screen. If it does, you can try to access a system restore point which preceded the day of your problem. Alternatively, you can try the sfc command or easier yet, download Glary Utilities and go to the section where you can choose to have the computer scan for bad or missing files and fix or add them. Depending upon your operating system, you may have other options at your finger tips. When you reboot, hit F8 repeatedly before a Windows screen appears in order to have the option to enter safe mode. Might as well choose the one with network connections if you intend to download and install Glary Utilities. There are more options available to address this.
Posted on Aug 10, 2017
Will not boot to safe mode imac g4
Starting up in Safe Mode Follow these steps to start up into Safe Mode.
  1. Be sure your Mac is shut down.
  2. Press the power button.
  3. Immediately after you hear the startup sound, press and hold the Shift key. The Shift key should be pressed as soon as possible after startup, but not before the startup sound.
  4. Release the Shift key when you see the Apple logo appear on the screen.
After the Apple logo appears, it may take longer than usual to reach the login screen. This is because your computer is performing a directory check as part of Safe Mode.
To leave Safe Mode, restart your computer without pressing any keys during startup.
Sep 25, 2014 | Apple Computers & Internet
Konica minolta C350 frozen at startup screen
power off the machine using the main switch not the one on the side of the control panel leave that on. turn on the main with the utility/counter button depressed. keep depress should see a trouble reset touch get ok. see if restarts if not power off Wait ten seconds power on. if not might have a firmware issue copier OS maybe difficult o to find atech let along get the Konicaminolta firmware
Nov 24, 2013 | Konica Minolta Office Equipment & Supplies
After startup my PC I got the BIOS screen stating in "Detecting IDE drives...".but it does not detect the drives and also not enter to the further startup configuration.please give a solution of this...
Shut down computer, disconnect from power outlet. disconnect all usb devices on the usb ports and just leave mouse and keyboard connected. disconnect harddrive cable from the motherboard and hard drive and reconnect cable again.
Restart system afterwards to see if the issue was resolved.
Should you have any other questions please just leave a comment.
Cheers~
Jun 26, 2010 | Dell Dimension E310 PC Desktop
Hello my laptop having unable to startup problem.repair program at the startup unable to fix the startup problem.window goes blank.circular window icon don't pop up.even after format.problem still...
if you can see some msg after power on then screen and CMOS BIOS is OK...
try changing the CMOS battery inside....(battery model will be CR2032 i guess so...it will be aprox the size of a dime(US 10 cent coin size)
or
RAM is corrupt...change the RAM cards inside...ensure that the new RAM is compatible...
pls leave a feedback...
reg
May 09, 2010 | HP Pavilion dv6000z 15.4" Notebook Laptop...
Cant get dell c600 svideo to stay on tv screen after initial startup
When you have it hooked up go into the screen resolution settings and make your tv a extra monitor. You can either have it the same as your laptop screen or a extra one. You have to enable the tv first thats probably why its shutting off. If i helped please leave me a rating. If you still need help leave me another comment.
Mar 01, 2010 | Dell Latitude C600 Notebook
Dash freezes on startup screen
Take battery out and leave it out for about a week. It may reset.
And take out your SIM card.
That resets my phone if it works then it works.
Good luck
Jul 24, 2009 | T-Mobile Dash Smartphone
Black screen startup
hello..this is the 1st you need to try..if you have a CRT monitor or LCD Screen try to put the signal Video on the Laptop located at the Back of unit then try to boot your unit...Thanks...
May 10, 2009 | ASUS G1 Notebook
HELP!
Disconnect the a/c power. Leave on until battery drains completely.Then plug in and allow battery to fully charge before starting.Should work then.RICHARDM69
May 01, 2009 | Computers & Internet
If I change the startup screen, what happens to the old startup screen?
Except for the built-in preset startup screen, changing the startup screen causes the previous screen to be deleted from startup screen memory. You will not be able to reuse a replaced startup screen unless you have its image saved somewhere else.
Aug 29, 2005 | Casio Exilim EX-P700 Digital Camera
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
