Question about The Office Equipment & Supplies
I have an argus 540 Slide projector, and I am wondering how I can get the new set of slides in the projector to view the photos?
SOURCE: 7" Trutech digital photo frame
I don't have the booklet for this darn thing and I just got it for mothers day.... I have a sandisk in it and I can see the pics just fine, but it doesn't save them??? I can only view when I have something in it??? That's crazy?? Isn't it?? Help
Posted on May 12, 2008
SOURCE: My Kodak Carousel 750H slide projector will not
A common cause for that problem is a broken plastic "link" on the solenoid (Kodak part #217769). There are repair shops who can replace this part. It is very difficult to replace by yourself.
Posted on Nov 11, 2009
SOURCE: the photo slide show is now blank
To fix this issue:
1. Unplug the Unit
2. Unplug the Phone Cord
3. Disconnect the Battery from the Handset
4. Wait 10-15 minutes… and put back together in Reverse Order
5. Connect the Handset Battery
6. Plug-in the Phone Cord
7. Plug-in the Unit
You can do this w/o the phone cord attached.
Posted on Jan 15, 2010
  • 412 Answers
SOURCE: I bought a used kodak
The KODAK Carousel 650 was manufactured approximately between 1964 and 1971.
Try removing the tray and pressing the cycle button(s) on the side of the projector. Watch the levers in the cut-out on the top of the projector. The lever closest to the rear of the projector should move back & forth (as you actuate the cycle buttons). The lever toward the front of the projector should extend and push forward (front of the projector) when you push the "forward" button, & extend and push toward the rear in reverse. If you are not seeing these levers move as described, then the chances of your projector needing a repair are likely. The good news: parts are still available. The bad news: You will have to find a factory-trained repair dealer to make the repairs for you.
Posted on Nov 04, 2010
  • 412 Answers
SOURCE: properly loading the slide tray
If the first slide is visable and consecutive slides are not, the "dark shutter" (a feature that prevents the eye-popping bright white screen when no slide is present) needs adjustment. A fairly easy adjustment for a factory-trained service dealer with the service manual and the correct tools.
Posted on Jan 04, 2011
How do you load slides in the tray and then into the projector?
place the slides upside down and in the way you will see them on the screen place in the tray
then place the end of the tray into the projector to the first click
from on it is a matter of pressing the next button
Feb 22, 2016 | Argus 500 Slide Projector
45 year old Slide projector
Ask around your local photo shops for a guy with a long grey beard to ask.
You could try advertising for an instruction book on your local freecycle and if Hanimex is still in business they might help you.
Some of those slide projectors were intuitive as they were completely manual but there were also magazine load, semi-auto and fully automatic versions that could also have a recorded commentary and backing music synchronised to the slide show.
Best of luck friend, have lots of fun with it.
Sep 04, 2015 | Office Equipment & Supplies
Change a carosul for 35 mm slide projector
Hi Richard, Turn the projector on, press & hold down the "Select" button. While holding the "Select" button down, rotate the slide tray to the "Zero" position. You will then be able to lift the tray from the projector. Good Luck!! Jim
Sep 23, 2014 | Office Equipment & Supplies
My argus 300 projector bulb blew new one won't work
yes could have been a power surge at the time, or fan cooler packed it in, the internal housing inside the Projector would have been too hot with the bulb inside it cooling down without the fan, i would double check all parts near the lamp housing and check to see they have not melted or burnt, also worth checking the fuse as well should be a T-250 Fuse bulb
Apr 23, 2017 | Argus Vintage Cameras Inc Projector Model...
The bulb lights up but it does not drop the photo to view
Hi Faye,
There is a "dark shutter" that blocks the light that probably is not opening.
It can be adjusted, but requires some tools and a bit of patience.
The process to adjust the DARK SHUTTER is:-
[1] Remove for the LOWER HOUSING.
[2] Insert a thin SLIDE into the GATE MECHANISM; the DARK SHUTTER should open.
Hope this helps you and you have the slide projector working again soon.
Mar 10, 2014 | Kodak 4200 Slide Projector
I need to know how to use a argus 500 slide projector
I found several manuals on eBay when I searched on Google using the projector brand & model name.
Aug 17, 2013 | Office Equipment & Supplies
I have a kodak 5600 slide projector. Everything was working great and when I changed the carousel the slides wouldn't fall to be viewed or would fall half way. This projector is almost new even tho it...
It sounds like you need the timing adjusted in the projector. The pressure pads that hold the slide vertical in the projection gate are closing too soon. Check the Kodak website for the service procedure for this adjustment. If you need assistance, contact an authorized warranty repair dealer. Good Luck !!
Jul 14, 2011 | Kodak Office Equipment & Supplies
Rollei slide projector
you need to go to a photo shop (not walmart). but you may need the negatives.
Dec 10, 2008 | Rollei 66 Dual Slide Projector
Top The Office Equipment & Supplies Experts
Ian White
Level 1 Expert
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
