My machine makes a noise but won't see. - Washing Machines
After washing it makes loud noise & won't spin or drain
You shoul inspekt water outlet on the bottom of the drum. There is mabye something inthere.
Dec 02, 2017 | Washing Machines
GE Washing Machine WWSE6260B1WW won't spin out water makes a rattle noise
use a putty knife to remove the front panel , you can remove it by pushing the putty knife into the 2 black tabs between the top and front panel. from there you can get to the drain pump . inspect by taking the hoses off the pump and remove debris. If nothing found replace the pump. hope this helps, let me know
Feb 19, 2013 | Washing Machines
Won't drain and won't spin ,makes a clicking sound
sound as though the drain pump has something hitting the impeller making the clicking noise,and the filter basket next to the pump is blocked by debris and not letting it drain
Sep 01, 2012 | Maytag MAH6700AWW Neptune Front-Load...
Wash machine won't spin all the time and makes a loud banging noise.
Check to make sure that your clothes are not piled to one side causing the load to be off-balance. If that does'nt fix it then, It may be that your machine has a balance stabilizer on it that has worked its way loose or even off.
Jun 11, 2012 | Frigidaire Affinity ATF7000E Front Load...
Whirlpool washer WTW5510VQO will fill, spin and drian but won't agitate, just makes a clicking noise.
If this is just clicking then the agitator bearings stuck or something is jamming it.
Jun 05, 2012 | Whirlpool Washing Machines
Final spin won't go through... makes a squiky noise and no high speed spin
first how old is your machine. second is it under warranty? third have you tried to spin in all selections to see if your timer is working?
Dec 12, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Won't spin out and makes a humming noise
Wait for your handsome husband to come home and have him fix it. jk
Nov 09, 2011 | Maytag MAH6700AWW Neptune Front-Load...
The washer filled up with water but not won't drain spin and is making a funny noise . It's an older magic chef.
The most common issue would be the coupler for the motor transmission. It is a rubber coupling and when it goes bad it makes a grinding, or whirring noise and the machine won't spin or wash. You need to remove the cabinet and look directly under the tub where the motor and tranny connect. This is a reletivly easy and cheap fix. Just google how to replace motor coupling on a top load washer and you may also include your make and model for more direct instructions.
Jun 23, 2011 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
