Question about Pitney Bowes Office Equipment & Supplies
My pitney bowes c235 copier is still working pretty well but just started getting a 2 in wide blank space on the copies. What is causing this and is there a fix?
SOURCE: how to connect pitney bowes 1630 to PC
you will a usb cable and driver software.should not have any other problems
Posted on May 07, 2008
  • 2794 Answers
SOURCE: Pitney Bowes Copier - C180 - Error E3
Sorry it took so long. Your copier probably is similar to a Toshiba E series. The error code is paper jammed in the bypass section.
Use this link as a lookup to the error codes
Use 4501 under Toshiba to find the error codes.
Posted on Sep 02, 2008
  • 990 Answers
SOURCE: error code E 6
E6 have so many sub codes, but there indicated is duplex unit problem.
Posted on Dec 16, 2008
  • 2120 Answers
SOURCE: Pitney Bowes 1530 Fax Machine
On top of the operating panel is a small removeable tab with a bump on top. (not the Blue ones) Pull it out of the machine This is the battery holder.
The battery is a CR 2032. Most electronic stores sell them.
Posted on Jan 31, 2009
  • 18 Answers
SOURCE: New help getting Pitney Bowes 8050 fax machine to work
The code is the same as the model number 8050, Your battery has failed and will not keep it's settings if it loses power.
Posted on Aug 24, 2009
Why is the text printing on Zebra LP 2844-Z label incorrectly spaced?
Zebra printers are not really made to print PDF files, if the only option is PDF I'd recommend switching to print on a laser. Also open the PDF and see if they are correct in the original doc
Oct 06, 2015 | Zebra Office Equipment & Supplies
Model c235 error code e310
The transfer wire is broken or shorting out when voltage is applied during the copy cycle. This is located beneath the drum area, and you can see it when you lower the blue handle. If it looks clean, the really fine gold wire may be broken, You will have to call for service. Oce is the service provider for these copiers now. 18002435556
Jan 19, 2010 | Pitney Bowes C180 Copier
I have a pitney bowes C180 that won't copy. The
the little wrench means it has shut down because it has exceeded the maintenance count, probably for the cleaner web in the fusing unit. Call service at 1 800 243 5556
Oct 30, 2009 | Pitney Bowes C180 Copier
Pitney Bowes 8000, when I go to Copy it prints BLACK
your thermal print head is bad. This is a very old machine and I do not know where you can get parts. This machine is no longer supported by field repair
Aug 20, 2009 | Pitney Bowes Office Equipment & Supplies
My pitney bowes c180 copier after turning on it started to work but after a while E 340 displays on the top board what will i do to fix it?
There is a sensor by the drum that checks the image on the drum. If the sensor is dirty, or the image on the drum is too dark, it causes this code. 18002435556 for service.
May 11, 2009 | Pitney Bowes C180 Copier
Pitney Bowes Model 9016 Error code E3 01
E3-01 is the toner bottle rotation. for some reason it is not rotating. Take out the toner bottle and be sure it is in coreectly, that the labels are not loose and preventing it from turning.
Jan 19, 2009 | Pitney Bowes C180 Copier
Contact OCE to find a dealer in your area. There the ones handling service on Pitney Bowes copiers.
Jul 29, 2008 | Pitney Bowes C180 Copier
Pitney bowes c180
Try making a copy in Photo mode and see if it makes a difference
Nov 18, 2007 | Sharp AL 1631 Copier
My copier powers on without errors but doesn't copy
hi im jules_09,turn it off first then turn it on for a 5 sec.try using a automatic voltage regulator
Oct 02, 2006 | Pitney Bowes C180 Copier
48 people viewed this question
Top Pitney Bowes Office Equipment & Supplies Experts
Adorjani Laszlo
Are you a Pitney Bowes Office Equipment and Supply Expert? Answer questions, earn points and help others
