Question about Inverter Electronics - Others
We are at a campground and our Trace inverter has 2 red light on the panel inside the coach. Bedroom electric plug is not working? Any ideas?
    Novelist:
  • 217 Answers
It sounds like you have a blown fuse or an open breaker on the inverter. Another possibility is that the batteries are not charged sufficiently, or are not connected. Some have a disconnect switch associated with them, and others have a disconnect plug. You might want to check that out.
Posted on Jan 09, 2018
5 Suggested Answers
SOURCE: I just purchased a slightly
i know it programs through the fm radio.
Posted on Jun 09, 2009
SOURCE: Inverter not working
Inverter is charging battery but if I switch on load button , It starts making noise loudly. can you suggest solution
Posted on Jul 01, 2010
motor1258
  • 6674 Answers
SOURCE: I have a 2000 Fleetwood Bounder 34T motorhome -
Check under the bed. May be some panels that need to come off to access from there. Check distance of bottom panel under bed, to floor. Likely under there. What adjustment is it that your trying to make? What's the initial problem your having? Is there any lower compartment space below bedroom? Sometimes they have an access panel under there as well.
Posted on Apr 13, 2011
  • 25 Answers
SOURCE: Trace, no power from line one from either gen set or shore power. Have rebooted, and when I invert the coach works normal. Charge system to house and coach batts perfec
If a normal install, the shore power and generator will go through a transfer switch then to the inverter. If when inverting 120 VAC circuits are OK, then the problem must be before the inverter. I would suspect that it is the transfer switch.
Disconnect shore power, make sure generator in NOT running then take a look at the transfer switch these are in a boat or RV but either can lead to vibration problems which can lead to loosening wire connections which can lead to heating and burning. It may be something as simple as a wire coming loose. (Which could be dangerous!)
Whether or not the contacts in the relays are OK, check and/or tighten all electrical connections. It's a good idea to check and tighten all electrical connections regularly.
Some transfer switches can be repaired by replacing just the relays. Other units (like mine this year!) will need to be replaced entirely.
Posted on Nov 11, 2013
How do I diagnose this lighting electrical problem?
Lighting cables have a tendency to run through the roof space linked on from one room to another. You need to access the roof space try and see where the supply from the fuse box comes in and trace the cables around the system. If you are not happy with household electrics then have someone who is take a look. I'm sure it can be traced to a junction box and probably a loose screw or damage from vermin or general deterioration. If the cabling is 1920's vintage then a lot were rubber coated long before PVC came along and the rubber rots away and problems occur. If the whole house has been rewired to modern standards then an insecure wire in a connector block is the most likely. Go careful and work safely.
May 22, 2015 | Dryers
UndefinedHi I have a Dk smith HD LCD TV model GE-6824,approx 2 years old,display doesnt work now,just black,will turn on ok turn off,green light-red light,but no picture,any idea.And yes its just out of...
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should be troubles hooted. Contact any service technician. The circuit will differ with models and versions.
Mar 13, 2015 | Televison & Video
I need a Control Board for my TR2424.
why do you need control aboard where are you fitting it and to what i have one on my coach its wired straight from my batteries
Nov 18, 2014 | Xantrex Trace Series TR2424-120-60...
No electricity while using battery power
You will not have electricity while on battery power. Two different systems. Electric is 110VAC and battery is 12VDC. If on battery power the lights will work, the furnace will work (LP gas and 12v blower motor), the refrigerator will work (LP gas and 12v power for circuit boards) and the water heater will work (LP gas and 12v power for circuit board). The only way to have electricity while on battery is to install an inverter but you will need extra batterys and still will not have enough power to run the AC for any extended length of time.
Feb 07, 2014 | Heartland 2013 Prowler 29P RKS
Nov 11, 2013 | Xantrex Technology Trace Series Inverter /...
The output(w) is indicating o.oo and it's indicator light is red .I only have a couple of floor model fans plugged. Should it be showing something and should the light be green?
inverters run on a square voltage unlike normal 110 runs on a round voltage, the only 2 things that won't run on the inverter is fans and electric blankets
Jul 22, 2011 | Cobra 2500w Power Inverter
I have a 2000 Fleetwood Bounder 34T motorhome - the bedroom slide does not operate correctly. I want to see about adjusting the motor / slide mechanics but cannot find how to access it. I cannot fin an...
Apr 10, 2011 | Rv Motorhome Dual Co & Lp Gas Alarm...
Hello I have 40 foot 2006 fleetwood revolution and my problem the batterys would not go into chargeing mode and the red fault stayed lit. And then a electrical smell and shorting noise came out of the...
Your Freedom 458 has died. At this point, you need to isolate the batteries from the inverter / charger unit to prevent further risk of fire.
It is normal, with the fried charger, for the battery voltage to plummet even while plugged in. There is no converter to maintain them. When you start your rig, the alternator on the engine is charging the batteries. With the rapid drop in battery voltage, your inverter likely is shorted.
Remove the main battery fuse between the inverter and batteries, as well as unplug / turn off the breaker to the inverter /charger. Take your coach to the nearet service center, as it may still be under (partial?) warranty.
Aug 30, 2010 | Xantrex Technology Electronics - Others
No 12v house battery power
The coach has a box Circuit Breaker that includes a manual switch or it may be next to it. I do not know if your coach setup for auto but I believe it is manual.. The way it works is one side for 12v the other side for AC and the middle for Off…They are all different so do not worry. They work the same…
When you get the AC working and shut the gen switch the breaker to the other side and see if you get electric… reset all your breakers and put them ON one by one and see if that work if not let me know and I will post step by step of how to test the inverter…If that works for you please do not forget to rate the service so we can improve on it, Hope this work for you
Sep 15, 2009 | Electrical Supplies
Electronics - Others Logo
387 people viewed this question
Top Inverter Electronics - Others Experts
ray gallant
Tom Chichester
George Scott
George Scott
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
