Question about Cell Phones
Replaced battery. use t-mobile. phone will not boot up
Phone loads up past boot screen, then shuts off.
Is the battery charged? When it detects a critically low battery, it may shut off.
Jan 17, 2014 | Huawei T-Mobile myTouch Q - Black
In case mobile not powering on.
if your phone create problem and not powering on pull out the battery and touch the battery pin from the tongue if it realiesed salty it mean battery is charged and your mobile is dead if battery pin dont realiesed salty it mean battery is deeply discharged then go to the retailer and say him to please boot the battery after this your phone will be powered on and now your mobile will be charged from it charger.MONTI GUPTA +91-9808491757
on Aug 02, 2010 | Cell Phones
Battery full but not get on
Battery full but not get turn on it mean your mobile boot file is dead go to repair shop and he repair your boot file via riff jtage your dead boot file repair and your mobile is turn on thanks
Jun 28, 2011 | Nokia E5 Cell Phone
Battery full but can not switch on
Battery full but can not turn on i think your mobile boot file is dead you go to repair shop to repair your mobile boot file shopkeeper used riff jtage to repair your mobile dead boot file i hope it is helful to you thanks
Nokia 6300 will not power on, its the phone how can i fix it.
Well, before you start troubleshooting with your Nokia 6300, remove the battery and check whether it's working or not, you can try with your tongue, if it has no fault, you'll feel the sour taste of the DC current, if not, then the battery is the problem, it needs a replacement. But before you replace it, check with another battery of same type, (you can use your friends mobile battery), and see how it works with your phone. Clean the battery Terminal Tip (- and +) with rubber (pencil eraser), and clean the battery connector of your mobile as well. If all these don't show any positive results, check whether your phone is hotter as compared to normal temperature, particularly behind the battery case. If it's so, get help from a technician. Sometimes, it can be easily fixed with all these tips, but sometimes, you can never repair it anyhow, when the power IC is dead. You can check using a mobile flashing software (which is available at the mobile repairing shop) if it's booting with it or not. Give it a try and Good luck....and do let me know so that i can help you better next time..
May 06, 2010 | Nokia 6300 Cellular Phone
My Nokia 5800 friezed on white screen with NOKIA logo. Nothing further
Thats not a big deal. Your mobile software has gone crazy. You just need to re-install it. Take it to a mobile repair shop and he will re-install the software. Before that there's a layman's fix. Three seconds magic. Switch off your mobile. Take out the battery. re-insert your battery. switch on your mobile. don't put the back cover on. wait for 3 seconds. with a **** bring out the battery while it is booting. and again restart the mobile. now your mobile should boot properly or else you have to take it to the repair shop.
Apr 18, 2010 | Nokia 5800 XpressMusic Smartphone
Screen has black lines all through it.
T-Mobile walked me through removing the battery for a minute or two then did a master boot. It didn't help, so because the damage indicator (a small sticker under the battery) was white, they are replacing the phone under warranty. If the sticker had been red, it would cost $390 to replace the phone. Thanks. T-Mobile. They were great to work with.
Jan 04, 2010 | Google Android
Incomplete booting
Format your mobile!
To Format your mobile proceed as follow;
Remember the mobile battery should be fully charged!
Take Out the battery & Insert it again! If the mobile is not ON turn it ON then quickly press Ctrl + Shift + F You see a warning msg saying something like! Do you want to format the phone! Press format & your mobile will be restored to its default factory settings.
Jun 02, 2009 | Nokia 9300 Smartphone
Forgot the code to my sidekick 08
okay what your going to do is hold on the r button and dont let it go then take the battery out while your still holding down the r button and replace the battery and wait for it to boot up when boot up the 2nd time let go and it should return to regular setting
Feb 19, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Cell Phones Logo
35 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
