Question about The Computers & Internet
Frozen screen My Netflix is frozen in the exiting mode and I cannot get it to release. How can I get out of the Netflix?
  • The Master
  • 3,498 Answers
Restart in safe mode..(F8)
Posted on Aug 10, 2017
SOURCE: Frozen screen in shut down mode
Hi, this happens to me all the time.
Just leave it alone for a while and the battery will run out completly.(you won't be abal to see it run down)
Then plug it into the PC or charger until it charges up.
P.S. Only do this as a last resort, it takes ages!
Posted on Oct 26, 2007
SOURCE: LOCAL MODE
I had the same exact problem. But once you charge it. Click the ON button JUST ONCE. It you press it too long. it will take you to the "Local Mode" which means it is in service.
Posted on Mar 26, 2008
  • 4 Answers
SOURCE: Cannot change channels in digital mode
Solution that worked for me:
Beware: Although the process should be safe, it technically voids your warranty.
Enter the service menu:
1 - turn of tv with remote
2 - press and release in the following order on the remote: Info, Menu, Mute. Make sure remote is pointing at the tv
3 - turn on the tv from the remote
4 - you will see the service menu. using the down arrow on the remote select the Reset option. Using the right arrow button at this point will do a hard reset.
5 - Wait a few seconds, turn TV on
6 - you will have to rescan analogue and digital channel but it should be working now.
Posted on Jun 10, 2008
SOURCE: Frozen iPod
move the lock button back and forth then hold the center and menu button at the same time for seven seconds. =)
Posted on Oct 24, 2008
  • 41 Answers
SOURCE: Frozen and won't connect to computer
1. Use the supplied USB cable to connect the Walkman to the Computer.
2. Disconnect all other USB devices if you have connected to avoid conflict.
3.Connect the Walkman to the other USB ports on the Computer.
4.Check whether the USB Driver is installed in the Computer or if it is corrupted.
You can check whether the USB Driver is corrupted or not by following steps below(only for Windows Operating System).
Right-click on MyComputer icon and select "Manage".
Then, select Device Manager at the left plane.
Then check whether any "Unknown device" or "?" or "!" is listed under Universal Serial Bus Controllers at the bottom of the right pane.
If there is so, then right-click on it and select uninstall.
This will un-install the USB Driver.
Then, un-plugg the USB cable and plug-it in.
Now, the Walkman should be recognized as a removable device in My Computer.
If the issue persists, then connect the Walkman to a different Computer to check whether the issue is with the Computer or the Walkman.
If the issue persists even with different Computer, then try resetting the Walkman by pressing the RESET button located at its bottom. You can use any pin or any sharp pointed object to reset it.
Then connect back the Walkman to check whether it works.
If the issue persists you may try using a different compatible USB cable.
Posted on Jul 21, 2010
I have a Toshiba TV 40L3400U. When I try to access Netflix, I get a screen that says "a software upgrade is available, it will take more than several minutes, Toshiba strongly recommends that you perform...
Try a reset to this TV and check. If it do not help you, contact the authorized service center. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jan 02, 2015 | Televison & Video
Frozen screen
Back out of net fix unplug roku, modem/router and wait 30 seconds then plug back in. Try to access Netflix again should work sometimes things just lose the link to the internet and when that happens they can act up.
Jan 02, 2014 | Roku 2 XD
Ipod disabled
Like all electronic devices, iPods sometimes freeze and become unresponsive.
Sometimes iPods lock up when they're dropped on the ground or come in contact with water, but less destructive accidents may also cause them to stop working.
All versions of the iPod have a way to reset their hardware should they stop playing music or refuse to turn off.
Check the "Hold" switch on the top case of your iPod to be sure it isn't activated.
An iPod will appear frozen and unresponsive if this feature is activated.
A lock symbol will appear on your iPod's screen if it is in Hold mode.
Switch the "Hold" button on and off once. Place one finger on the "Menu" button and another on the center button.
Press both buttons at the same time and hold them for up to 8 seconds.
Release the "Menu" and center buttons once the Apple logo appears on your iPod's screen.
Try releasing the buttons and pressing and holding them a second time if the logo does not appear, as it can sometimes take several tries to reset a severely frozen iPod.
Press and hold the top button and the center "Home" button on a frozen and unresponsive iPod touch to reset it.
Hold the buttons for at least 10 seconds and wait for the Apple logo to appear on the screen, then release the buttons.
Connect your iPod to its powerblock or a computer if it is still frozen.
Wait 5 minutes and then try to reset it.
Sometimes an iPod can appear frozen when its battery runs out and just needs a few minutes of power to start working again.
May 15, 2013 | Audio Players & Recorders
SECURITY CODE MODEL NO A1137
Like all electronic devices, iPods sometimes freeze and become unresponsive. Sometimes iPods lock up when they're dropped on the ground or come in contact with water, but less destructive accidents may also cause them to stop working. All versions of the iPod have a way to reset their hardware should they stop playing music or refuse to turn off.
Check the "Hold" switch on the top case of your iPod to be sure it isn't activated. An iPod will appear frozen and unresponsive if this feature is activated. A lock symbol will appear on your iPod's screen if it is in Hold mode. Switch the "Hold" button on and off once. Place one finger on the "Menu" button and another on the center button. Press both buttons at the same time and hold them for up to 8 seconds. Release the "Menu" and center buttons once the Apple logo appears on your iPod's screen. Try releasing the buttons and pressing and holding them a second time if the logo does not appear, as it can sometimes take several tries to reset a severely frozen iPod. Press and hold the top button and the center "Home" button on a frozen and unresponsive iPod touch to reset it. Hold the buttons for at least 10 seconds and wait for the Apple logo to appear on the screen, then release the buttons. Connect your iPod to its powerblock or a computer if it is still frozen. Wait 5 minutes and then try to reset it. Sometimes an iPod can appear frozen when its battery runs out and just needs a few minutes of power to start working again. Hope this helps.
Jan 24, 2013 | Apple iPod Audio Players & Recorders
My ipod touch 4th generations says ipod disabled connect to itunes, but screen is locked
Jan 19, 2013 | Apple iPod touch 4th Generation MP3 Player
How do I fix my frozen e reader
Jan 19, 2013 | Apple iPod touch 1st Generation (8 GB) MP3...
Computers & Internet Logo
48 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
