WHAT IS ERROR 54 FOR PRIMUS RS27 WASHING MAVHINE
3 Suggested Answers
govinda123
  • 2263 Answers
SOURCE: How set up the Linksys WRT 54 g router with primus
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Posted on Mar 14, 2010
SOURCE: primus washing machine error 11?
Error 11 is definitely a water issue. Usually it's because there is not enough pressure. Error 5 is an overload or mis-balance in the drum
Posted on Jan 07, 2011
I have a samsung front loader WF7700N6W1 WHICH KEEPS COMING UPWITH THE ERROR CODE 3E IVE checked the drainage plug and cleared that but mavhine still not working.
The 3E error code to indicate a drive motor tach fault.
Here's a good website that discusses how to troubleshoot and possibly repair. (Could be as simple as unplugging the machine for a few minutes).
How To Fix 3E Error Code On Samsung Washing Machine
Here's an EXCELLENT YouTube video on removing the motor and replacing the brushes (if equipped).
Samsung Washing Machine 3E Error Code not spinning or turning
Jun 15, 2017 | Samsung Washing Machines
Tip
Samsung RS24 through RS27 Repair Manual
Here is the Link for the Repair Manual for Samsung Side by Side Refrigerators with the model numbers that start with RS24 through RS27
Thanks
on Jan 10, 2009 | Samsung RS2630SH Side by Side Refrigerator
How to unlock washer door with wet clothes inside
Pl ensure that the wash cycle is completed. Alternately pump out all the water using rinse mode. When this is done you can switch off the power to the washing mavhine, close the tap for water inlet. Then you should be able to open the door of the washing machine. Hope this works.
Apr 10, 2013 | Splendide 2000S Front Load Washer / Dryer
Hi. i have modem wireless model 2wire 2701 to use wth primus, i can connect to net but the probleme everytime i go to surf in net the page goes to bell, asking name user nd passeword to continue to surf....
I assume bell is your old ISP, and primus is your new ISP.
Also i assume your wireless modem is not provided by bell.
If you are getting the login page of your old ISP (bell) it seems your bell LAN cable is still connected to your modem. If you are 100% that only primus is the only connected to your modem.
Try to run disk cleanup and remove all the temporary files in your computer.
Jan 05, 2018 | 2wire (1000-000057-000) Modem
Primus washing machine error 11? Is this a inlet water issue?
Sep 15, 2010 | Washing Machines
Error code 11 on primus rs16
Error 11 is a water pressure or inlet problem. Check the 1st stage filters in the cold water hoses at the back of the machine.
Mar 03, 2010 | Washing Machines
How set up the Linksys WRT 54 g router with primus communication
hi,
login to admin page, go to WAN connection setting.
before that , please be ready your primus username and password.
after that save the changes.
Sep 11, 2009 | Linksys Wireless-G WRT54G Router
Doesnot stop filling water
To javed_iqb904, does the drum actually fill or does it seem like that water is draining out as it's filling?
To neonllama19, if it fills with the tap on and the machine off, it sounds like a defective water valve. If it never stopped filling it sounds like a defective pressure switch or hose to the pressure switch is loose or diconnected.
Jan 08, 2009 | Frigidaire GLTF1670A Front Load Washer
Error 54 comes up when you switch it on
all error 50 messages relate to the motor.
Feb 13, 2008 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
