Question about Golf
2011 ezgo golf cart electric 48 volt intermittingly does move when step on accelerator smell of electrical burning will move after cooling down
weblord
  • 507 Answers
SOURCE: need a club car golf cart service manual
generic suggestion
http://www.blockbustergolfcarts.com/index.asp?Category=260&PageAction=VIEWCATS
http://www.lvssales.com/store/product.php?productid=13300
Posted on Oct 18, 2008
  • 6 Answers
SOURCE: electric golf cart, mash the pedal won't move
you have a broken belt .
Posted on Jun 03, 2009
  • 166 Answers
SOURCE: Electric Golf cart only shutters and inches forward
so many possibilities...
does it roll fairly freely? (checking to see if the brakes or rearend seized up)
Are there any "bad" sounds like things grinding? (Connection between Motor and rearend, axle splines...)
If all that is solid, it is likely in the controller.... (it takes a solid charge right... No bad batteries in there or loose connection? might want to check all the battery connections to make sure none are burnt...)
1997.. does it have the electonic speed control by that year? the other possibilty is that the accelerator is not working corectly. they used a resistor system on old ones that has contactors that would get worn out.... Newer ones control a potentiometer(sp) that controlled the speed.
Only a few real components to check, but if you are not mechanically and electically inclined, could be tough to isolate.
peace,
Posted on Mar 07, 2010
  • 34 Answers
SOURCE: Rear axle fluid for 1983 ez go electric golf cart?
Regular 90 weight gear oil. Fill until it reaches the fill hole.
Hank, The cart man
Posted on Apr 22, 2010
  • 11 Answers
SOURCE: ezgo electric golf cart wiring diagram
Dennis;
Here is a picture of ezgo wiring
Posted on Mar 27, 2012
Have a 48 volt ezgo, cart will run once you stop it might go or it will attempt to go you wait a few minutes and it will go, sometimes it takes several minutes of waiting before it goes. What's wrong?
It is basically an electric motor with a variable speed rheostat. The rheostat is your accelerator, and it sounds like it needs cleaning. Could also be a loose connection anywhere on the electrics.
ezgo Google Search
Oct 15, 2017 | Cars & Trucks
Wheres the ground go on healights on a ezgo 3 wheeler
Never had a ezgo 3 wheeler to work on before but sounds interesting. If this is an electric cart then wire ground to a negative battery that gives 12 volts from where positive is connected. If gas cart wire to frame or neg post of battery.
Mar 28, 2017 | Golf
I CONNECTED MY GOLF CART TO THE CHARGER AND CHARGER IT FOR A COUPLE HOURS NOW IT WONT MOVE FORWARD OR IN REVERSE.
Troubleshooting a golf cart - APLawrence.com
aplawrence.com > Miscellaneous
Mar 29, 2015 - If you need help with a golf cart, I suggest asking at Buggies Unlimited. .... Within a half hour I had everything in place, cinched down, connected and ready. ...it is still getting power to the forward and reverse other words itsworking and ... I let mybatteries completely drain and now the charger won't turn on, ...
Put Spring In Your Electric Golf Cart ' Golf Cart Talk Blog
https://www.golfcarcatalog.com/golf-cart.../put-spring-in-your-electric-g...
Mar 9, 2004 - On a car with 8-volt batteries, connect a 12-volt charger to each individual ... If you do not have a 'Regen' system, then just put the Forward/Reverse(F/R) switch into the .... speed controller stays dormant and will not permit the car tomove. ..... My other question would be did anything "fail" in the cart prior to ...
About Golf Cart Battery Chargers ' Golf Cart Talk Blog
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Apr 1, 2012 - Tutorial on golf cart battery chargers, the basics, what goes wrong, ...BATTERIES ARE DEAD AND CHARGER WON'T COME ON ... This is usually indicated by a car that creeps when the brake is off and the car is in forward orreverse. ... a connected pair of batteries with a 12 volt, auto style battery charger.
Basic EZGO Golf Cart Problems And How To Fix
Feb 09, 2016 | Golf
Solenoid clicks. Why doesn't it go?
Need to know what kind of cart you have. Ezgo, Club Car?
36 volt, 48 volt ? for ezgo look at manuf. code, for club car serial number has the year. Then maybe we can figure out something.
Sep 09, 2015 | Golf
36 volt ezgo
First of all, lift rear axle off the ground and place blocks or jack stands underneath. Check to see if you have 36 volts On your batteries. Now you want to run a jumper across the big cables on the solenoid. Press the accelerator and the motor should engage. Clicking is a pretty sure sign that the solenoid is bad. Please let me know if this is useful. I can further elaborate more troubleshooting if this doesn't solve your problem.
Aug 06, 2014 | Performance Plus Carts EZGO Golf Cart 36...
Golf Logo
317 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
Ronald Prier
Are you a Golf Expert? Answer questions, earn points and help others
