HP Printer C5550 all in one powers on then shuts down immediately giving error code 07564DD6 with a blue screen with a power button logo
SOURCE: Blue screen error code
Shaking during switching is the right thing to solve the problem..... I The gear mechanism of the camera lens are out of phase and when you shake the camera the gears goes in the right position and it work.
I just fix my mju-700 right now with shaking it.
I think this is a problem with all MJUs.
SOURCE: error code 0x0000004E PFN LIST_LIST_CORRUPT
Did you check the CD you used when you installed Windows XP or Vista? A cause of a PFN_LIST_CORRUPT error is a badly copied or scratched installation CD.To work around this, install Windows XP or Vista again - this time using a clean CD and preferably, a genuine Windows CD.Annoying you with a pfn_list_corrupt error is one reason why Windows installation CDs cost quite a sum - its because they see to it that their CDs are free from errors.
PFN_LIST_CORRUPT error and a bad case of memory
If you are done installing Windows XP or Vista again, and a PFN_LIST_CORRUPT error shows up when you start up your PC, the problem might lie on bad memory module.
Here’s what you’d do… Try re-seating your memory stick to another slot on your motherboard and restart your computer. If a PFN_LIST_CORRUPT error is still there, then try swapping a memory stick that you know is OK.
When all else fails…
If a PFN_LIST_CORRUPT error still keeps on showing up after trying the solutions I mentioned, I’m sorry, those are the two solutions I know that you can do for free. The other choices would be either to buy a new memory module to try out or buy a third party software that tried to fix the problem for you.
SOURCE: Printer Hp Laserjet 3055 giving error message 5
If you scanner error 5 or printer hangs at scanner bulb warming up than the issue is with Scanning Assembly inside the printer and it is hardware issue.
SOURCE: E000000-0001
Okay, to be of real help you have to reset the error in service mode as the officetech1 said. To do this you need to press the head key (the head with the star inside) then 2+8 together and then the head key again. This will get you into service mode. Then select 'COPIER' then 'FUNCTION' then 'CLEAR' then select 'ERROR' or 'ERR' press 'OK' then switch the machine off and on again. This may get it working for a while or a long time. But if not, you will need a fixing film unit to remedy the problem.
SOURCE: HP C6150 error 0xc19a0035 - ink system failure
the problem is your printhead. Contact HP support to obtain a replacement printhead.
Sergio
