Question about Samsung Microwave Ovens
Samsung microwave display is dim
How do I fix the display? It is very dim on my microwave. The display is in the door.
The display on our Sharp Microwave oven went very dim. Everything else on it is still functioning perfectly. Will replacing part FPNLCB666WRKZ fix it? Is this something we can safely do ourselves?
not familiar with that exact model .if the display went gradually dim and has a green vacuum florescent display ,these suffer 3 problems ,worn out display ;glass on display and filter window dirty ;and failed capacitors,suggest before replacing module ,unplug and put plug iside door ,then safely remove the back then take photo of display panel wireing then remove it clean inside the plastic eindow of display and display tube glass window .visual look at pcb you will see several round blue capacitors .note the values and voltage of these i.e 470u/25v. go to maplin and obtain replacements ,yhen get a friend who can solder to replace them all making sure to mark pcb with black marker ajacent black negative line on capacitors to ensure correct polarity then refit pannel and test .if no improcement replace complete panell
Dec 28, 2015 | Sharp R-314FS Microwave Oven
The light is dim with the door open or closed running.whats wrong?
Lights lowering in the kitchen when turning on microwave ...
diy.stackexchange.com/.../lights-lowering-in-the-kitchen-when-turning-o...
Nov 4, 2012 - Lights lowering in the kitchen when turning on microwave oven: symptom of an ... In the best case, this may be normal if the dimming is minor.
Possible causes of dim Microwave Oven display ' All About Circuits
forum.allaboutcircuits.com > ... > Electronics > General Electronics Chat
Jun 13, 2013 - I've seen some Microwave ovens that will not display a backlight anymore. They still work, but the display is so dim, you have to be inches away to. ...Monitoring the output of a light-dependent resistor, or photoresistor, allows ...
What Is Causing My House Lights To Dim?
blog.1000bulbs.com/what-is-causing-my-house-lights-to-dim/
Dec 21, 2015 | Microwave Ovens
Samsung microwave runs when door is closed
1.check fuse
2.check relay (microwave oven magnetron)
May 11, 2014 | Samsung SMH7178STD Microwave Oven
Samsung microwave disorienteted
It may juts be a bad door switch or mount. See our help fil on door switches here:
http://031d26d.namesecurehost.com/mwd/doorsw.txt
If you still need help, please post a new help request with the full model number from the tag in the cooking cavity or elsewhere on the microwave, such as the door frame, controller frame, etc.
May 02, 2013 | Microwave Ovens
Microwave displaying SE in the display panel, it is only 5 months old.
An SE error on a Samsung microwave means you have a shorted membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
Jan 22, 2011 | Samsung MW1080STA Microwave Oven
I have an nn2505c microwave that powers up but displays door open
Took it to a repair shop ,cannot be fixed ,no parts discontinued microwave.
Jan 19, 2010 | Panasonic NN-2505A Microwave Oven
LCD display is working but very dim and hard to see
This is a common failure of the control panel assemblies of these and similar microwaves. We repair these control panbel assemblies nationwide for only $32.50. If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Feb 18, 2007 | Sharp R-326FS 1100 Watts Microwave Oven
Microwave Ovens Logo
273 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
