Question about GE Refrigerators
I have a GE refrigerator (PSS26SSTA SS) Something is happening that is causing items in our freezer to thaw and then refreeze. We keep losing food in what appears to be a normally functioning fridge.
I have a GE refrigerator (PSS26SSTA SS) that has a temperature fluctuation problem. Most times when I go out to it, the temp is 34 degrees and the freezer temp is 1 degree, but sometimes the temp is way high and food in the freezer is all melted and food in the fridge is bad. Something is happening that is causing items in our freezer to thaw and then refreeze. We keep losing food in what appears to be a normally functioning fridge. Sorry. I had to edit the original question because I couldn't figure out how to respond such that we could have a conversation. I up-voted and down-voted responses based on those who listened and offered advice based on my particular problem, and those who knee-jerked an answer as if my question was, "My refrigerator is not working". Again... The refrigerator and freezer keeps perfect temperature. 95% of the time, when I check on it the temps are perfect. However, there is evidence that the freezer has warmed such that things had melted, then re-froze sometime in the recent past. Also I am noticing that things like milk are going bad in the refrigerator side way too soon, again indicating that it is getting warm sometimes, then re-cooling. Ocassionally I do catch it at much too warm of a temp, but me catching it in that state is rare. I do believe that it is an issue with a runaway defrost cycle. Does anyone have an idea of how to test/repair a runaway defrost cycle? And apparently I can't put line breaks in my content to make it look right.
  • 1524 Answers
SOURCE: fridge not holding correct temp. fridge is 55 and freezer is 25
Sounds like a defrost problem.
Posted on May 07, 2009
  • 262 Answers
SOURCE: will freezer work in low ambient temperature (i.e.
The compressors are rated for ambient temp. and most refrigerator compressors are rated for abour 50 degrees F
to answere your question yes the ambient temp is a problem.
And as for the Thawing, the refrigerator will go into defrost every 8 to 10 hrs and turn on the heater inside the freezer for about 30 min.
You can also cause damage to the seal system and the compressor because the oil will become slugish inside the compressor.
In other resarch I found that because of the ambient temp the freon gas (mostly the newer freon's) won't work corectly because they stay in liqued form.
Posted on Jan 11, 2010
  • 531 Answers
SOURCE: 16 month old GE Profile
see if the back wall inside of freezer have ice if so you have to change tiker board or check your doors if closing
Posted on Mar 31, 2009
  • 1606 Answers
SOURCE: Ge Profile fridge
Pull the refrig out from the wall , and remove the rear panel . Touch the compressor and feel if its hot or running . If the compressor is cool , then the main control board is bad ( since the compressor isn't running ) . If you can solder , you can repair the board (another paragraph ) . If the compressor is warm , then you could have a thermistor or 2 bad . This would have to be checked by a technician , unless you know how to get into the diagnostics procedure . Also , see if the compressor cooling fan is working and the black squirl cage is clean of dust .
Posted on Sep 06, 2009
Testimonial: "Quick, professional response."
  • 43501 Answers
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Posted on Aug 12, 2010
My freezer is icing over and thawing food somewhat then refreezing
If the self defrosting circuit is not working properly the freezer will ice up and internal temps will go up and thaw food. U indicate that it refreezes so whst could be the problem is the timer that controls the frequency and timing of the defrost cycle.
Jan 18, 2015 | Refrigerators
GE profile side by side fridge freezing and thawing randomly
Defrost entire unit, put food in coolers with ice and unplug. Wait 24 hours with doors open. Any clogs in freon lines should be gone, plug unit back in and see how it works.
Jan 24, 2014 | GE GSS22SGM Side by Side Refrigerator
Freezer thaws and refreezes
Jul 09, 2012 | GE GSH25JFR Side by Side Refrigerator
Is it safe to refreeze meat, such as venison steak after it has completely thawed?
Once food is thawed in the refrigerator, it is safe to refreeze it without cooking, although there may be a loss of quality due to the moisture lost through thawing. After cooking raw foods which were previously frozen, it is safe to freeze the cooked foods. If previously cooked foods are thawed in the refrigerator, you may refreeze the unused portion. Freeze leftovers within 3-4 days. Do not refreeze any foods left outside the refrigerator longer than 2 hours; 1 hour in temperatures above 90 °F.
Sep 04, 2011 | Refrigerators
Hotpoint HSS25GFP freezer side keeps thawing completely and refreezing causing freezer burnt food. what would cause this
Defrost timer/control is sticking...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
Oct 15, 2010 | Hotpoint HSS25GFP Side by Side...
Model #PSS26PSSA SS Freezer frequently defrosts and refreezes. When this occurs, the entire ice bin melts into the freezer compartment and refreezes in puddles. Is this a common issue with this model and...
Absolutely not ! There are two types of defrost systems - timer (which relies on compressor run time) and adaptive (newer models) which relies on sensors and an electronic control and will defrost as needed...... During a defrost cycle your comrpessor and evap fan should be off, everything off - and no, a defrost cycle will NOT thaw your food in the freezer, not even your ice should melt ! To me this sounds like a defrost control problem - First thing service should check is your defrost timer and its components (control board, limiter, defrost thermostat, etc.) something is definately wrong.
Now with the advice above I am assuming that before the defrost cycle kicks in your freezer temp was in the normal range 10F and colder (0F is optimal) and refrigerator section cooler than 40F (optimal 34F). If so, then you should not have melting ICE in your freezer.
Aug 24, 2009 | GE Refrigerators
Refrigerator Making cold air, but not keeping food cold/frozen
Either defrost timer or Refrigerator thermostat, both located in the ceiling of the refrigerator, can give you long enough off times to actually cause thawing and then refreezing. Feel the rear wall of the freezer, half way down to see if a layer of frost has formed on it. This can indicate a problem in the defrost system which has three components.
The only way to be sure which of the two components is the cause would be to catch it in the thawing phase (not running). Tapping hard on the refrigerator temperature control knob can make it come on if it is the source of your problem. Good Luck
Aug 22, 2009 | Whirlpool ED2GHEXN Side by Side...
Freezer thawing and refreezing
The freezer is supposed to thaw at least everyday. Only, you usually kant tell because it doesn't do it long enough to melt the food so you don't notice it. You have a couple of components to check here. 1 is the defrost timer, which unless it has been changed recently, has the same pre determined defrost time. So you would have noticed by now. Next is the defrost termination switch. If you have excess ice on the evaporator, this will make the defrost longer than before. Unless the switch is going bad causing the defrost to go extra long, there is an excess amount of ice that is more than usual. Bad door seal will cause this. A slightly low freon charge. And a thermostat that is malfunctioning, causing the freezer to run continuously, will make excess ice buildup in the freezer. I would make sure the kids aren't leaving the door open and the gaskets are good. If not the case, call a repairman.
Jan 09, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
