How to turn on rockola nostaliga jukebox. location of on of switch? 1985 model.
MechMusicSF
  • 16 Answers
SOURCE: i have a rockola mystic jukebox & one side of the
Either a bad connection somewhere, or one channel in your amplifier is out.
Before you try anything else, switch the amp from 'stereo' to 'mono.' If the speakers come on, your amp is good and you simply have a bad connection somewhere between the amplifier and cartridge (thing that holds the stylus"needle"). Or, possible, but not probable, a bad cartridge.
For a quick fix, switch the amplifier to "mono" and then run all the speakers to the working channel.
In the meantime, if you're handy, try switching the speaker leads and such and see if you can isolate the problem.
Kyle~
Posted on Apr 18, 2009
  • 1138 Answers
SOURCE: I have a Rockola jukebox model 456.It worked well
You might want to try this forum:http://www.antiqueradios.com/forums/viewtopic.php?t=104054&highlight=&sid=231c6e27ef15ccbe83c7a412bb9c8b86 The part in the post about lubrication is important but might not be the solution to your problem. I would suggest joining and posting as there is probably other owners who are members.
Posted on Mar 27, 2010
  • 94 Answers
NEED TO FIX YOUR EJECT BUTTON
Posted on Oct 21, 2010
  • 6771 Answers
SOURCE: Rockola 464 jukebox. arm that holds needle will
The turntable will need to be removed, the pladder should be taken off with the c clip to inspect the gears, I would not be surprised if the grease has gone hard and is interfering with the cycle. Flip the turntable over to check for any restrictions. If it is a grease issue the old must be removed before applying new. Please keep me posted on your progress and if I can be of further service don't hesitate to ask.
Posted on Jan 12, 2011
jimfresso
  • 236 Answers
SOURCE: how to change a needle on a model 460 rockola jukebox
turn it off and look for a set screw holding the needle. loosen the screw and the old one should come out.
Posted on Jan 18, 2015
Need stylus type for 463 rockola jukebox.
hi Stephen.
if you go to this link you will see on the right hand side of the page where you might be able to get one from.or you could try ebay.
where to buy stylus for 463 rockola jukebox Google Search
Dec 01, 2017 | Audio Players & Recorders
Where can I hire a repairman to fix my Whirlitzer juke box?
go google and type in--- service agents for wurlitzer juke box ---
find and agent closest to you and call him on the phone
Dec 23, 2016 | Audio Players & Recorders
I have a 1968 Seeburg Ls2 jukebox,and I think the main fuse in the junction box is blown.I can push down on top of the fuse holder but cannot get the fuse out.Is anyone familiar with this jukebox?
In addition to pushing down on the fuse cap, you will need to also twist IE unscrew the cap about one quarter turn. the cap will then pull out and have the fuse stuck in the end of the cap. Check it with a meter set for continuity.
If the fuse remains in the the hole and not in the cap, you can use a magnet to help extract the fuse.
Yes, I'm familiar with Seeburg's, but nothing is a very big symptom. if the main fuse is blown, try another fuse of the CORRECT value. if it blows again, you have a short, (Capacitor, transformer perhaps)
Oct 11, 2015 | Collectibles Jukeboxes Book Rockola...
Jukebox manual
Many on eBay
http://www.ebay.com/itm/Original-Rockola-Jukebox-Model-488-Service-Manual-w-wiring-diagrams-/231244858100?pt=LH_DefaultDomain_0&hash=item35d74482f4 Original Rockola Jukebox Model 488 Service Manual wiring diagrams
Aug 05, 2014 | Collectibles Jukeboxes Book Rockola...
What causes a Rockola jukebox not to index?
I might be wrong about this but check inside for a switch marked Scan/off/play inside at the front of the mech. It should be in play position. Also check any circuit breakers and reset them on the upper back of the machine (inside). They look like the clicky end of a ball point pen.
After that I am stuck.
May 16, 2014 | Neonetics Rockola Jukebox Neon Clock
Rockola jukebox keypad doesnt work
If the whole panel is out it sounds like a missing or bad ribbon cable. start there and tell us what happens.
Nov 21, 2013 | Neonetics Rockola Jukebox Neon Clock
Been given a grade 5 Rockola 160 433, need a copy of the service manual
Contact the folks at www.victoryglass.com and tell them the make and model of your jukebox. They will have the manual set for around $50. Also, they bought out the entire Rockola factory parts inventory. So if by chance you needed Rockola parts, they would have it.
Aug 05, 2013 | Wurlitzer Rock-ola Jukebox
 Grubhead
Grubhead
