Question about The Computers & Internet
Identifying what the keyboard icons are at the top of the keyboard
  • MarcellusA Aug 11, 2017
    Hi patricia ortli, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? That is normally dependent on the brand. Could you perhaps provide a picture of the icons on the keyboard, and I would be happy to help you decipher them.
Tecra s10 display brightness
look closely at the keys along the top of the keyboard (usually called F keys). one of them should have a tiny sun icon and the key beside it will have a larger sun icon. hold down the "Fn" key elsewhere on the keyboard while pressing the one of the sun icon keys to brighten or darken the picture. the sun icon keys may also be located on the Arrow keys (<-- --> etc.)
Aug 27, 2014 | Toshiba Tecra Computers & Internet
List of all keyboard symbols
Rosemary, Symbols are not specific to keyboards but font sets
I cant paste one in here but on a windows computer open a utility called Charmap (enter 'charmap' in the search box)
Once opened change the font name at the top to Wingdings, 2nd row down 3rd icon in is a keyboard, click it, click select at the bottom and then copy. You can then paste this in to a document and change its size as if it was a normal letter.
2nd row down 3rd icon in a
Nov 21, 2013 | Computers & Internet
Adjusting brightness
To adjust the brightness in your Acer Travelmate, press the [FN] key then press the left or right arrow directional keys which is usually on the lower right-hand side of the keyboard. You will identify the brightness and dim symbol/icon. I hope this is of help. Thank you.
Nov 05, 2013 | Acer TravelMate Computers & Internet
Can't get the wireless to come on
Exterior Wireless Switch
Step 1
Position the laptop so that you're facing the screen and the keyboard is in front of you.
Step 2
Check the front edge of the laptop's casing.
Step 3
Identify the wireless indicator light labeled with a wireless antenna icon. The "On/Off" switch to the left of the indicator light is the wireless switch.
Step 4
Move the switch to the "Off" position to deactivate the wireless adapter or move it to the "On" position if you want to power on the wireless adapter.
On-Screen Wireless Switch
Step 1
Press and hold down the "Fn" function key on the computer's keyboard to display the laptop's hotkey card icons on the screen.
Step 2
Click the "Wireless" icon on the screen or press the corresponding hotkey button on the keyboard, typically the "F8" key on a Toshiba laptop.
Step 3
Click the "Wireless On" or "Wireless Off" icon in the options list below the hotkey card icon to activate or deactivate all wireless connections. If your laptop has Wi-Fi and Bluetooth connections, you can also choose to activate or deactivate these services separately.
if have drives problem you can download using this link
Sep 13, 2013 | Toshiba Satellite L505DS5983 Notebook
This is either the Num Lock or the Scroll Lock. To turn off the Num Lock, look at the top left of your number pad on the right side of the keyboard, and press the Num Lock key. To turn off the Scroll Lock, press that key in the middle of the top row of 3 keys above your arrow keys.
Feb 27, 2011 | Dell 0Y3740 Keyboard
How do I reset the channel for the mouse and keyboard?
Dear Sir,
plzz follow this step to solve your probel
icon on the desktop. Click the "Change a Setting" choice in the left column. In the window that appears, double-click the "Keyboard" icon. This dialog box handles all settings for your current keyboard. Another path to the control panel is to click the "Start" button at the bottom left of the screen. Roll the mouse pointer up to "Settings" and click "Control Panel."
  • Step 2 Reset the character repeat settings. The speed of character repeat and the delay before repeating starts is adjustable with sliding level indicators. Click on the adjuster and hold your finger on the mouse button to drag the adjustment left or right.
  • Step 3 Change the cursor blink rate. A faster blink helps to locate the cursor while moving it with the arrow keys. Change the blink rate by dragging the slide to the left or right for slower or faster.
  • Step 4 Enable the keyboard to accommodate one-handed typing or foreign languages. Click on the "Input Locales" tab near the top of the dialog box. Click the "Add" button for choices of available languages. Click the "Properties" button for choices to include Dr. Dvorak’s keyboard layouts for two-handed typing or single-handed typing with either hand.
  • Step 5 Identify and correct keyboard malfunctions. Click the "Hardware" tab on the dialog box. The current keyboard will be listed under devices. The functioning status of the keyboard is displayed, and a troubleshoot button is active for use anytime. Make a first attempt to resolve keyboard problems by clicking this button.
  • Apr 05, 2010 | Computers & Internet
    How to turn on wireless
    Many laptops have a switch on the case that is for turning on the wireless function. In fact, some even have a light that goes on indicating that the wireless is working. Look for that switch on the front or side of your case,
    Another way wireless is turned on or off is by a combination of keystrokes using the Fn key (lower left side of the keyboard) and one of the special function keys at the top of the keyboard. This key is usually identified by an icon representing a radio tower. By pressing this combination, the wireless function will be turned on or off.
    Hope this helps.
    Oct 19, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
    Toshiba laptop satellite model cuts off screen display when connected to Sharp model XR-10X projector
    Try to check your keyboard if there is an Fn command then press on hold together with F6/F7 or some keyboard only identify with an icon that similar to project or computer screen icon.
    Please rate me solve if you like my solution.
    Best regards,
    Nov 17, 2007 | Toshiba Satellite A105 Notebook
    Computers & Internet Logo
    32 people viewed this question
    Top The Computers & Internet Experts
    Perry Ralston
    Level 1 Expert
    ashu k...........
    Level 1 Expert
    ted dux
    Are you a The Computer and Internet Expert? Answer questions, earn points and help others
