How can we fix an EC? - Computers & Internet
Hw to fix ec 2188 crt tv 21" comin out wth blck n white pics
Hw to fix ec 2188 crt tv 21" comin out wth blck n white pics ...
www.fixya.com/.../t26080626-hw_fix_ec_2188_crt_tv_21_comin_out_...
3 hours ago - Check its fuse. Check the rectifier diodes. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic'
Feb 03, 2016 | Televison & Video
EC error code meaning
Hello friend, thank you for your inquiry!
I understand that you are getting an "EC" error code on your Frigidaire air conditioner. However, it appears "EC" is an invalid error code. It is possible that the error code is missing characters? I show that the error code "ES" or "CS" is valid. In the meantime, I suggest resetting your air conditioner. You can do this by flipping the household circuit breaker for roughly ten minutes. If resetting the power does not correct the issue, could you please inform me of the new error code or if your air conditioner continues to display "EC". I look forward to assisting you. -Matt
Aug 28, 2014 | Frigidaire Heating & Cooling
Msi gt70 2OC touch panel isnt working anymore,
I found how to fix it, rather easy to be fair. If you are upgrading the bios and then the EC, make sure that you are getting the right one. Go there for the EC ; https://www.msi.com/Laptop/support/GT70-2OC.html#down-firmware&Win8.1 .
To know what version to use, DL the MSI Help desk.
Then after flashing the new EC, the key point is to shut down the PC, remove the battery and power cord, press 15 sec on the start button, so the EC memory will erase. Re plug all and restart, everything should work now.
Sep 28, 2013 | MSI Computers & Internet
MY LCD HAS AN EC ERROR MESSAGE. HOW TO I FIX THAT?
EC Problem for brother copier?
Please call 0909-2755078
Dec 27, 2010 | Brother MFC-7340 All-In-One Laser Printer
My oven is showing F6 EC TEMP on the screen how do I fix it? Please let me know.
F6: EC (Electrical Compartment) Temperature High
Fault is displayed when the EC thermocouple
exceeds 158?F (70?C). It is monitored once per
minute.
The electrical compartment is overheating. Remove the panel on the right side and clean out all the dust. Check the fan at the back and see if its blowing alot of air. Sometimes this fan can get so clogged up with dirt, it slows down the air flow.
Sep 04, 2010 | TurboChef TORNADO Electric Oven
Sub zero ref 690 s model with error code ec 50 what is that
EC code is on with a flashing service light . Is this a problem that I can fix on my own?
May 26, 2010 | Sub-Zero 690 Side by Side Refrigerator
Sharp ec-14twt6 won't start
if the motor spindle spins easily when turned by hand, the motor brushes need replacing. if it doesn't, either something is stuck in the turbine, or the motor is siezed. if the motor is siezed, it needs to be replaced.
Jul 22, 2009 | Sharp EC-S2365 Upright Vacuum
Can someone tell me the values of the capacitors ?
EC18, EC19, EC20 are 1000uf/16v 105c
never had to replace EC9 and EC10 but should by the same value look at the size if the same as EC18 - EC20 I would go with the same value. It should be printed on the caps. If that did not fix your dead unit replace the power supply board and same time.
Check for the parts here:
http://www.mcmelectronics.com
# NOTE - If this info was helpful to anyone please click on yes!
Jun 23, 2009 | Akai LCT2721AD 27 in. LCD Television
How will I go to the bios and fix the EC/KBC update diskette problem?
Hold the "Esc"key when you power on the laptop until you get the BIOS setup screen coming up.
But I don't think you can fix the Ec/KEB problem by change any thing in BIOS or you just want find USB drive and make it boot-able from BIOs?
Nov 13, 2008 | Toshiba Satellite A135-S4527 Notebook
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
