I have swann 720p 3. Camaras are in black and white and 4. Camaras in color how I fix the three in black and white. something on the setting
  • 326 Answers
SOURCE: PS2 in black & white?
Hello Staubs, please look at the back side. There should be a sticker with the model (for example SCPH3XXXX). So please, which model is it? Thank you, Arpad
Posted on Dec 23, 2006
  • 375 Answers
SOURCE: Color Fading
check your menu settings if not there then you may require board level service.or eprom sub menu adjustment.
Posted on Sep 08, 2007
SOURCE: I have the Swann Communications DVR PCI Card + 4
Philips SAA7130 TV Tuner/FM
Posted on Apr 25, 2009
  • 75 Answers
SOURCE: Color code for 4-pin Cobra M75 CB Mic
here is the link that i used
hope it helps
Posted on Jul 03, 2009
SOURCE: hooked up cable box, wii box and dvd player to new
Connect the Wii and the DVD player to different ports on the TV to and any other device to the port in which the Wii and the DVD player were connected to check if the issue is with the port.
If other devices also display in black and white after connecting them to the port to which the Wii and the DVD player were originally connected then the ports require servicing.
Posted on Dec 01, 2009
Is Swann PRO-1080FLD camera compatible with my TECHview 8 CH AHD 720P DVR Model No QV - 3147 DVR. Compatible Recorders: DVR-4575, DVR-4580
No its not. You might get it display an image but will probably be black and white as the resolution on the cam is higher than the supported resolution on the dvr
Dec 13, 2017 | SWANN Home Security
Viewing the Self Check Diagnostic List
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a second of each other:DISPLAY > Channel 5 > Volume - > TV POWER .
Results for all of the following diagnostic items are displayed on screen. No error has occurred if the screen displays a "0".
NOTE: If the Service Menu display text is not completely visible, press the Menu HOME button on the Remote Commander to refresh the display.
3. To exit Self Check display, turn the power off. Press [Menu] Exit.
Clearing the Self Check Diagnostic List
1. In Service Mode, press the Channel 8 Channel 0 .
RESETTING TO FACTORY DEFAULTSUse the following instructions to restore the User Controls and
Channel Memory settings to the preset factory conditions.1. While holding down the UP ARROW on the Remote Commander, press the POWER button on the right side of the set.The set restarts and displays the initial setup screen. This may take several minutes.
White Balance adjustment
1. Allow approximately 30 minutes for the set to warm up before proceeding with the white balance adjustment.
2. Connect the signal source to the 3 terminals of the Component In input (Y/Pb/Pr).
3. Set the Picture Mode to "VIVID" in the user menu.
4. Select the Component In input.
5. Open the Factory Service Menu (see section 3-1.) and select "Service Alignments Menu".
6. Set "White Point Red", "White Point Green", "White Point Blue" and "Black Level Offset Red", "Black Level Offset
Green", "Black Level Offset Blue" to average values .
"Cool " White Balance Adjustment
1. Select "COOL" from Color Tone in Service Alignments Menu.
2. Input 70IRE full white pattern signal into Component In.
3. Adjust "White Point Red", "White Point Green", "White Point Blue" in Service Alignments Menu if needed.
4. Input 25IRE full white pattern signal into Component In.
5. Adjust "Black Level Offset Red", "Black Level Offset Green", "Black Level Offset Blue" in Service Alignments Menu if needed.
6. Repeat steps 2 to 5 to achieve desired White Balance.
on Jun 30, 2015 | Sony Bravia L-series Kdl-32l5000 32-inch...
I have a swann view security system ,,and something not working cause it only says mode not supported ,,,,, how do you fix this
Have you tried a hammer? Kidding!!! Usually this is a conflict in resolution between the DVR and the TV. You may need to lower the resolution of the TV for the particular input you are using. You may have a 1080P TV and a 720P DVR. Once they match, the issue should be resolved.
Aug 30, 2015 | SWANN Pro-Series DVR-4200 4-Channel...
My swann video cameras used to be in color but now they are in black n white
Go to system settings, camera settings, select NTSC instead of PAL.
Oct 19, 2014 | SWANN Home Security
Swann camera stays black and whie,no color
If the camera has IRs and there is not enough light it will go into black and white. Check the settings in the camera menu! If those are correct and you have good voltage it may be the camera is bad. If there is plenty of light and it is still in black and white it's a bad camera and needs to be replace
Aug 30, 2014 | Swann Communications Home Security
I can't get the 3rd input to display color. Video 3 has sound and is in black and white. I'm using a 3 color cable to connect it to a dvd player
Try some different cables to eliminate the possibility of a bad cable. Make sure the equipment you are connecting is set for progressive scan or set to 480p,720p, or 1080i.
Apr 20, 2011 | Sanyo DP46849 46 in. HDTV
I have a 3 prong cord, the outlet is 4, colors in back dont match
Hook the green directly to the metal of the machine anywhere you can, like under a screw that holds something.
Hook the white to the white.
Then the red and black can go on the other two, it does not natter which one is on what they are interchangable. To make it easy, go black on black and red on blue.
Plug it in and
Then you are good to go!!
Jan 20, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
DVD hookup to LCD monitor only appears in black and white!
I have a RCA flat screen television and my dvd player when hooked up is in black and white. How would i fix this and if so plz be more specific then these other people.
Jan 02, 2009 | Insignia 32" 720p Flat-Panel LCD HDTV
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
