Question about GE Washing Machines
Have a GE whre5550 washer that won't spin the clothes dry enough
Seems to be spinning but not wringing the clothes as well as it used to.
jsrock516
  • 5911 Answers
SOURCE: kenmore washer
If your washer is not spinning fast enough, or barely spinning at all, this is usually a symptom of any one or all of the following: 1. Bad gearcase (transmission). 2. Bad basket drive, with which the transmission couples to under the agitator. 3. Bad clutch/brake assembly. Which mounts on top of the gearcase under the basket drive. Usually a tell tale sign of a gearcase beginning to fail is the sign of an amber colored oil coated under the washer or inside the casing. I said, "usually". It doesn't always happen, but if you notice any signs of oil, the gearcase is shot. The basket drive and clutch assemblies are harder to diagnose and require some disassembly of the washer and the removal of the gearcase to inspect. Let me know if this helps.
Posted on Aug 02, 2007
vest6
  • 196 Answers
SOURCE: broken washer/dryer
This sounds like a motor control board is faulty. Please load a couple of towels in the machine run it. Watch the machine as it goes through its' cycles.
1. Do the towels tumble when the machine is washing ?
2. When it begins to spin, does it spin one way at a fast pace or does it spin one way and then the other ?
Answering these two questions will help in troubleshooting your problem.
Posted on Jan 08, 2008
SearsTechToo
  • 261 Answers
SOURCE: washer won't spin dry clothes
What model is in reference here? Please post back with model number.
Posted on Oct 16, 2008
  • 20 Answers
SOURCE: Bosch Nexxt 800 series - washer doesn't always spin dry enough
First inspect the water pump then the pressure switch. Soap buildup can cause this too.
Posted on Feb 10, 2009
Just_Bobz
  • 448 Answers
SOURCE: spins fine, but clothes still soaking wet
Clogged water pump. Not draing fast enough. If this is helpful, please post as such.
Posted on Feb 21, 2009
Clothes are not wringing out
Washing Machine Won't Wring Out Clothes Properly - DIY ...
www.diychatroom.com/.../washing-machine-wont-wring-out-clothes-pro...
Apr 16, 2013 - 6 posts - ‎4 authors ... thing - the spin cycle doesn't really seem to do an effective job of wringing out theclothes once. ... Sounds like it's not spinning fast enough.
Washer does not wring out the clothes. Clothes are dripping ...
Nov 23, 2015 | Washing Machines
My Whirlpool spins... It just does not do a very good job
It's very possible that the impeller in the drain pump is striping out and not allowing the pump to get up to high enough spin to completely drain.
Jan 16, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Spin is not going fast enough to dry out clothes
spin is not suppose to dry the clothes, simply wring the most water it can from them.
are you sure you are not set on a gentle cycle? might your washer offer a extra spin cycle?
Dec 14, 2009 | Computers & Internet
My washer doesn't wring the clothes fully.
It's not spinning fast enough because of a loose or worn belt on the motor. Post back with your model number and I may can find a diagram of your washer to help you.
Sep 04, 2009 | Maytag Performa PAV2200
On delicate cycle clothes wringing wet when done
check drain hose kink or belt adjustment...worn clutch...basket drive
Aug 13, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Spinning fast and furious, just doesn't wring clothes dry
It sounds like you need a water pump!
See if it's pumping water next time you do load by looking at the discharge hose going to the drainage pipe and get back to me!
jack
Feb 21, 2009 | Maytag Performa PAV2200
Spins fine, but clothes still soaking wet
Jan 27, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
