Question about Canon Office Equipment & Supplies
I have a Canon MG 5620 and I'm trying to print some photos and it keeps telling me the paper output treat is closed. But it's not.
SOURCE: wont print
The problem occurs when the paper tray is pushed down too far and 2 flimsy stop tangs on the backside of the tray hinge break off. The one on the left side contacts a microswitch, pushing it forward , signaling the printer tray is open. When the left tang breaks off, there is nothing to press the switch. You can try bending a paper clip in a fashion that hold the switch forward.
OR (the following will probably void your warranty)
Unplug the printer
Pull out the envelope tray on the bottom.
Set the printer on its back
Look just behind the bottom of the tray door from the underside
There are 2 wells on the underside. The front most wells are more square-shaped.
The 2 wells behind the are irregular-shaped. These 2 have the cover release tangs. Take a long, thin #1 flat blade screwdriver and push them outward toward the sides of the printer to release the 2 inside catches.
Next, push the screwdriver into the 2 rectangular release holes on the bottom sides of printer (beneath little arrows) to release the side tangs.
Next, release the rear tangs in similar slots in the back of the printer.
Gently lift up the cover. Lift up the electronic module on the left side.
The output tray wicroswitch is the black one on the bottom of the electronics module fix it in the upper position with either a small zip-tie or good electrical tape (the top one signals that the top cover is open to expose the ink cartridges, leave it alone).
Carefully reassemble the printer, hopefully it will work.
Remember to open the tray when you print as the preventing switch is no longer functional.
Good Luck.
Posted on Nov 05, 2007
  • 5 Answers
SOURCE: printer door open message
Apparently a solution has already been posted here: http://www.fixya.com/support/t345435-ip4300canon_printer
The author provides instructions on opening the printer and gluing the sensor into the "open" position (assuming that the sensor still works).
Posted on Apr 04, 2008
SOURCE: Canon MP470 keeps saying "paper jammed"
I had the same problem for DAYS and there was no paper jammed at all. I went to the cannon site as a last ditch effort & the solution below fixed it. Just clean the rollers and the link tells you how. Good luck!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15403
Posted on Feb 01, 2010
nadirsalim
  • 185 Answers
SOURCE: my mp470 canon printer keeps telling me the the
paper sensor is clogged; blow some air into both input and output paper slots.
Posted on Nov 07, 2010
hattinghbr
  • 214 Answers
SOURCE: error 1250
look for a small sensor on you right hand side. it tell the m/c if it is open or close. it migit be stuck.
Posted on Nov 04, 2011
Can i print onto Transparency film from my Canon MG 6150 as there is no setting for transparencies, what paper setting would i use
Try the setting for glossy photo media. You want a minimum of ink. Also use the transparency media intended for ink jet AND observe the correct side to be printed on.
Jun 08, 2011 | Canon MG6150 Printer
Hi...I have a problem with my HP Photosmart C7280...can you help ? the error message "Photo tray problem" keeps coming up, telling me to "lift the output tray, push the photo tray all the...
Photo tray problem
' Lift the output tray up and verify that the photo tray
' is pushed in until it stops, then lower output all the
' way down. Press OK button on the printer to
'continue printing
HP Photosmart C7280 All-in-One Printer
1. Turn off printer.
2. Pull out paper tray and photo tray
3. Remove output duplexer (on back of printer)
4. Open input sheet feeder (on top of printer)
5. Open cartridge access door. (Basically lift up control panel and scanner section of the printer)
6. Turn on printer (Power button on now raised control panel)
7. Printer may display message "Performing printer alignment - Do not interrupt"
8. Wait for a few minutes until printer stops making all setup noises.
9. Close cartridge access door, close input sheet feeder, replace output duplexer, insert paper trays
10. Do a test print. All should be fine.
Mar 11, 2011 | Office Equipment & Supplies
Error e03, but there is no jammed paper
E, 0, 3
Paper Output Tray is closed / Paper jam
Summary
If the Paper Output Tray is closed, open it. The machine resumes printing.
If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
E, 0, 3
Summary
E, 0, 3
Summary
Techbelkin
Nov 03, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
Error code while trying to print
Slap the printer with your right hand from the right side of the printer.This process always solves the problem. I did, it worked
Apr 01, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Canon ip4300 printer says paper output tray is closed. wont prin
Its a defective printer you have that cant get out of paper output tray is close or that the paper output tray is not properly placed into the printer.
Try to reseat the output tray and let me know. If it does not work, you may need to send printer to repairs.
Mar 19, 2010 | Canon PIXMA™ iP4300 InkJet Photo Printer
PIXMA ip8500 not printing
i have a pixma ip4300 i keep getting the error number 1250 "paper output try is closed" but infact its is open i have tried opening and closing and restarting and everything else i can think of. any ideas of what to do?
Jun 23, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
Printer will not print
Try Closing and opening the paper output tray then press resume button on the printer while the printer is powered on,check the paper feeder ensure that there is nothing jamming up,if this doesn't work then let a canon technician have a look at it, the problem is minor.Hope you succeed
Nov 27, 2007 | Canon Pixma iP6000D InkJet Photo Printer
20 people viewed this question
old marine
old marine
