Question about Power Computers & Internet
Operating a nostalgia retro series ice machine that shoots water out the back when turned on
Green light slowly flashes as soon as machine is plugged up to power outlet
    Top Expert:
  • Power Master
  • 79,847 Answers
It should be obvious that a seal has failed, pull the back off and id the failed seal.
Posted on Aug 09, 2017
  • 1153 Answers
SOURCE: My TV won't turn on. The Green light just keeps on flashing
1. Check for no 8.4 volts DC at pin 3 of PC9A10 on the Power PCB, if low or missing replace PC9A10 part # 268P058020. 2. LED does not blink at plug in. Check for 3.3-volts DC at connector RF pin 3 (system reset) if low or missing suspect the reset switch S7L20 part # 432P109010 on the Control PCB. 3. LED does not stop blinking after plug in. Verify the standby supplies, 12-volts at connector KA pin 17, 6-volts at KA pin 18 and the 28-volts at KA pin 19, if the supplies are present suspect the DM PCB part # 934C067002 4. LED does not stop blinking after plug in. Check C9B01, C9B02, C9B10, and C9B11 (1000 UFD 16) on the DM PCB, if they are bad replace them with part # 181P734030 (680 UFD 16 V). 5. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature; this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 6. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector RF pin 4 and 5 on the Signal PCB if low suspect problems with the switches/buttons on the Control PCB part # 935D736001 7. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector RF pin 4 and 5 check good suspect the E2P PCB part # 934C061001
Posted on Sep 05, 2007
  • 1019 Answers
SOURCE: wont turn on
you have one of 3 things wrong here.
1:) the battery is dead, and needs to be replaced ( suggest e-bay china seller for cheapest )
2:) the AC adaptor or dc socket on the motherboard is Faulty.
3:) motherboard fault, regarding charging circuit board.
Go for the most cost effective option First. New Battery. Then AC Adaptor. Finally would be motherboard replacement.
Mike @ compurepair.
Posted on Dec 18, 2008
thegoshem
  • 61 Answers
SOURCE: Green light flashing on back of unit near power cord also green light flashing on motherboard near power supply plug in.
I would suggest trying to replace the power supply. If that does not fix the issue, i would need to hear more about the computer.
Posted on May 06, 2009
  • 30 Answers
SOURCE: My popcorn machine is not working. How will i solve the problem?
We are under new management.
Please contact us at 1-920-347-9122 and we can help you with your Nostalgia Electrics product.
Also, please visit our new website at www.nostalgiaelectrics.com
We are more than happy to assist you.
Posted on Jun 17, 2009
heatman101
  • 43501 Answers
SOURCE: ice maker not working flashing green
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
dfdf
Posted on Sep 30, 2010
My Nostalgia Electrics RIC-100 Retro Series Portable Ice Maker is not pumping water to the ice tray. Can this be fixed?
Water line may be frozen, heat it with a hair dryer, see if water then flows.This can happen if aair flow to bottom of frig is blocked.
May 13, 2017 | Nostalgia Electrics Kitchen Appliances -...
What can i use to clean my portable ice maker. It smells like mildew.
I have cleaned Manitowoc ice makers and their company specifically made an ice maker cleaner and sanitizer. Try a google search for this product.
Dec 13, 2014 | Nostalgia Electrics RIC-100 Retro Series...
How do I repair nostalgia ice maker?
Don't know if this will help: http://nostalgiaelectrics.com/product/ric100-retro-series-50s-style-automatic-ice-maker/
Jul 19, 2014 | Nostalgia Electrics RIC-100 Retro Series...
Nostalgia Electrics Ice Maker Troubleshooting
My Nostalgia Ice maker shows low water, but there is water up to the fill line.
Mar 10, 2014 | Nostalgia Electrics RIC-100 Retro Series...
Ice maker not making ice
Sounds like the intake line at the entrance to the refrigerator is plugged with lime residue. It has a needle valve in the center and will clog with foreign material, this can be cleaned out by forcing compressed air pressure backwards thru this connection to remove tiny particles inside.
Dec 28, 2013 | Nostalgia Electrics RIC-100 Retro Series...
Need directions for nostalgia electrics PCM-805RETRORED Retro
The Instruction Manual for the Nostalgia PCN-805 Hard and Sugar Free Candy Cotton Candy Maker can be downloaded in PDF from the following link:
http://nostalgiaelectrics.com/manuals/PCM-805.pdf
Jun 20, 2012 | Nostalgia Electrics Pcm-805retrored Retro...
Nostalgia Electrics RHP-625 Retro Series Hot Air Popcorn Popper manuel
The User Manual for your Nostalgia Electrics RHP-625 Retro Series Hot Air Popcorn Popper can be found online here:
http://nostalgiaelectrics.com/manuals/RHP-625.pdf
Dec 27, 2011 | Nostalgia Electrics CCP-509 Popcorn Maker
Green "ice size" light is
try to reset your unit to unplug the unit then after a several minutes plug it on then observe the unit.
Mar 06, 2011 | Refrigerators
Saeco Italia SUP021 YR green lights and red water light flashing
You can't manually reset. The machine will have to do it. I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
Sep 14, 2009 | Starbucks Saeco Italia Digital Barista...
Computers & Internet Logo
Top Power Computers & Internet Experts
waruna
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Power Computer and Internet Expert? Answer questions, earn points and help others
