Question about Maytag Washing Machines
Maytag neptune lt FAV6800AWW.presser swatch is hook up to water pump hoe? is there a hose go from the swatch to to top of the water??
dh1200s
  • 335 Answers
SOURCE: how to get front panel off neptune fav6800aww washing machine
Just a quick search in this forum fot "Front Panel" returned this post which says it better then I could.
http://www.fixya.com/support/t538238-remove_front_panel
Posted on Jan 18, 2009
dh1200s
  • 335 Answers
SOURCE: Maytag Neptune FAV6800AWW Top Loader will not turn
Hi Sandra,
I assume you have no LED’s lit when you raise and lower the washer lid or press a Wash Cycle or Spin Only cycle. This may not be an easy fix but this how I would proceed to troubleshoot.
From the machine schematic I see no fuses or circuit breakers in the machine that could cause loss of 120VAC distribution to the washer Control Board or other relay inputs. This is what I can tell from washer schematic. 120VAC comes into the machine passes thru and EMI filter is then distributed to the Control Board for +12VDC and +3.3VDC generation and 120VAC distribution to the main system relay, motor control board, drain pump, door locks/unlock solenoid and so on. I would start looking with my DVM to see if I had 120VAC at connector P6-1 the L1 (120VAC) input to the control board referenced to P6-3 or 4 the 120VAC neutral connection. If you have 120VAC at those points I would look to see if I had +12VDC power generated by the control board +12VDC power supply.
+12VDC could be measured at the Control Board Conn P3 Pin 3 or 4 referenced to Control Board common Conn P3 Pin 1. If there was no +12VDC generated by the Control Board I would replace the control Board and see if that restores normal operation. What I’m describing is the troubleshooting path I would take as an electronics technician. If you call in a repair service run my suggestion by them and see what they would suggest. I would make sure they bring out a Control Board for your machine. The Control Board has a 5 yr warranty. They will need your model number which you have and the serial number of your machine. The s/n is located on the back right side of the console. I will attach a couple links for reference. The Service Manual link has Maytag warranty contact info.
Let’s also see if another forum member can offer a solution to this issue that I may be overlooking.
The Service Manual for reference. Sears Parts Direct for reference.
Good luck and let us know if you have additional questions.
Rich
Posted on Oct 12, 2009
FAV6800AWDIY
  • 526 Answers
SOURCE: maytag neptune top loader model fav6800aww has an
rlbishop720,
See this post Left Hand Lid Lock Troubleshooting . I discuss Left Hand Lid Lock troubleshooting for error codes OD,OP FL, FO all related to Left Hand Lid Lock issues. I also provide a link to purchase a replacement Left Hand Lid Lock if you don’t want to deal with a DIY fix.
Let me know if I can help…..Rich
Posted on Mar 28, 2010
FAV6800AWDIY
  • 526 Answers
SOURCE: maytag washer top load neptune
See this post for troubleshooting the Lr error code. . http://www.fixya.com/support/t2419091-maytag_neptune_top_load_fav6800aww_tub
Lr is locked rotor. My first thought was that this could be a Motor Controller issue. This owner replaced tried that and it did not resolve the issue. He then replaced the main Control Board and that fixed his machine. Without known good parts (Control Board Motor Controller) this might be difficult for a DIY fix.
If you are going to try to DIY the repair I will see if I can help……Rich
Posted on Apr 28, 2010
FAV6800AWDIY
  • 526 Answers
See if this post http://www.fixya.com/support/t4757262-i_have_a_letter_showing_and_it_say_o_d_w will get you started.
You have lost signaling from the Left Hand Lid Lock. If you want to DIY I will try to help........Rich
Posted on May 17, 2010
Water leaking from my Maytag Neptune model FAV6800AWW Serial number 15646382GA Leaks during wash cycle imediately and during complete cycle. Enough water to saturate 2-3 towels and clothes come out...
Could be a Tub Seal leak my 1st choice. Could also be a leak caused by a cracked outer tub, issues from the hoses from the drain line connections to the drain pump, drain pump and or drain line.
Are you going to try to DIY the fix?
Sep 07, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Washer want pump out all the water and it will not go in the spin cycle, and it cut off display UC Code
Google this Neptune TL Washer FAV6800AWW
5th post down in the sticky you will find my service notes to get you back in service.
Mar 10, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My MAytag will not spin the water outta my clothes on spin cycle
If you machine is a FAV6800A or FAV9800A don't worry about the last two letters of the model number.
Google this; Neptune TL Washer FAV6800AWW
This is a DIY Appliance repair forum and you can get the Service Manual and repair support at that site..
In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues that I have helped owners with. I'm an owner of a FAV6800AWW top load machine.
If you need help post in the Maytag/Magic Chef/Admiral/Jenn-Air forum with your issue and we will try to help.
Feb 28, 2011 | Maytag Neptune FAV6800AW Top Load Washer
ND error, pump runs, but sounds rough, took pump apart and found nothing in the pump or pipe.
If the motor is running but there is no water coming through, it would suggest the pump impellor blades are compromised. It's quite posible that the shaft that drives the blades has snapped. Is it possible to open the pump housing and rotate the blades manually whilst watching the motor to see if it moves? If one moves without the other, then its a new pump I'm afraid. WARNING! Do NOT attempt to do this with the motor connected to the electricity supply.
Feb 12, 2011 | Maytag Neptune FAV6800AW Top Load Washer
We have a maytag neptune TL. Usually when you hit start to run a load a little water comes out of the discharge hose. It is not doing that. It runs in the wash cycle for about 8 minutes the it pauses...
If the machine is a FAV6800A or FAV9800A google ""Sticky: Neptune TL Washer FAV6800AWW""" Post your problem at this Forum. You will find the FAVA9800A/FAV6800A Service Manual at that site.
If the machine is a FAV6800A or FAV9800A you can go into Service Mode and tes the Drain Pump. Then we can start to troubleshoot the issue if the above model is your machine type.
This site is not really geared up for DIY folks.
Jan 09, 2011 | Maytag Neptune FAV6800AW Top Load Washer
How do i get to the drainage hose in back of neptune FAV6800AWW?
You have to remove the front cover from the machine.
Do you have the FAV6800A/FAV9800A Service Manual?
I'll see if this site can let me post a pic of the wash tub removed. In this pic you can see the Drain Pump/Pressure Switch and drain line on the right side of the machine. There is no side or rear panel access.
What is the issue? Won't drain?
I would suggest you Google "Maytag neptune FAV6800aww wont spin" this forum has a Sticky for Maytag FAV6800A and FAV9800A machines and you can get the Service Manual from this site. I feel it's a better DIY site.
OK let me see if I can attach a pic;
Jan 04, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My maytag neptune tl leaks from the bottom while it washes MODEL #FAV6800AWW it leak about two to three cups of water for each load,about one drop per second.
Possible Tub Seal leak, leak from Outer Tub, Sump Cap, Drain Pump, Drain Line.
You need to pull the front cover off the machine and ID the leak source. If there wash water over the Clutch Pulley I would suspect a Tub Seal issue.
You can't link to the Service Manual form this site.
Google Maytag Neptune load unbalance and see if you can find support for the Service Manual.
Oct 08, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune top loader model fav6800aww has an error code od
May 15, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune TL FAV6800AWW Overflows
Check the pump, pressure switch and related hose for small obsctructions. For reasons unknown they moved the pressure switch location to above the pump. d60f89f.jpg
Oct 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
23 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
