Question about Health & Beauty
My disabiloity scooter has no braking system - its an old shoprider. Can I fit a braking system ...how?
  • 11 Answers
SOURCE: User manual for shoprider madrid mobility scooter
Go to the Shoprider website and look for the scooter. It might have a different model name than the one you own. Get the name and click on the user manuals for the model that resembles yours (PDF file) and print.
Posted on Apr 02, 2009
  • 945 Answers
SOURCE: shoprider cadiz scooter, batteries show full
I think your batteries haven`t been charged properly,or they have been left standing so the charge has leaked out.At a minimum your batteries need to be charged for 12 hrs a day for the first month if not they will not build the capacity and will dwindle and die for example it is at only 25% capacity,but looks like a fullcharge, it says it fully charged but will die
quickly this happens because it is charged to its full capacity but that is only 25% of the batteries true potential
resulting in short battery life.
Unfortunately majority of scooter batteries like this have to be newly replaced.
Posted on Nov 06, 2009
skaterkid307
  • 86 Answers
SOURCE: scooter stops then jumps forward
mait be problem with moter
Posted on Feb 20, 2010
  • 347 Answers
SOURCE: shoprider delux scooter
check key tubler is not faulty,no connection has been or worked loose,fuses for each battery are not blown press curcuit breaker to reset.get the wiring feed checked from batteries to see you have power by an electrician.
Posted on May 12, 2010
  • 692 Answers
SOURCE: Hi, I have just purchased a
Quasi Go to shoprider.com and the user manual selection should get you the manual you need to download. Hopes this helps you
Posted on Sep 13, 2010
Can you fit a heater to a used shoprider travesco scooter?
probably could but as scooters use batteries and heaters draw a lot of current what would be the point as the distance travelled would be considerably reduced
Sep 07, 2016 | Shoprider Health & Beauty
I have a shoprider echo when I turn it on the power meter works. The horn works. But there is a beep every 3 seconds. Please help
Your Throttle maybe out of neutral when you start the scooter.
Make sure your parking brake lever is on so the scooter is hard to move. If it is easy then it is not on and won't drive. Make sure there are not any cables that are disconnected to the motor and brake. Scooter Doctor App
Apr 28, 2016 | Shoprider Health & Beauty
How do i lift off the chair out of the shoprider cobra scooter
Lift the lever to turn seat and locate the release point. I think the seat is facing to the left of the scooter, then lift off. If not check for lock screw.
Oct 06, 2014 | Shoprider Health & Beauty
Shoprider 4 wheel sooter breaks locking and have a wiring problem
if the wheel lock , then the brake must be faulty, so please clarify does the scooter work okay when you push the forward or reserve lever ?
Remember the brake release when you push the throttle lever by applying 24v to the brake , if the brake does not click then the brake might be faulty or the controller is not outputting24v ,check the wiring and connector from the brake to the controller.
Dec 13, 2012 | Shoprider Health & Beauty
What does the shoprider wispa charger interface board actually do
If you ignore the board, fit a Neutrik socket to the Shoprider with corresponding pins connected where the old jack socket was and the correct way around, you will be able to use a standard scooter charger.
Jul 11, 2017 | Electric Mobility 4 Wheel Power Electric...
I need a new battery and charger and every where I have called either pushes me off to some plaace else that doesn't answer or a place never calls me back. Where can I get these items?
The type of batteries required by your scooter are 12volt 10 Amps, you will need two of them. They can most likely be purchased at any industrial battery store like Interstate Battery or Batteries Plus. For the charger, you will most likely need to contact Shoprider direct OR a licensed distributor of Shoprider products for that to make sure that the charger will fit into your scooter. Shoprider Mobility is 1-800-743-0772. Another company that sells Shoprider products and may be able to assist you is Marc's Mobility at 800-677-6293.
I hope this information is helpful- good luck!
Sep 20, 2010 | Echo 3 TE SL7 3 New Electric Scooter by...
Mobilty scooter fault
i have a shoprider mobility scooter has soon has i turn on it goes about 5 yards and stops and the alarm comes on i think it has something to do with the brake system could anyone advise me on what it could be thanks
Mar 28, 2009 | Health & Beauty
Shoprider delux scooter completly dead but new bateries fitted
Mar 24, 2009 | Shoprider 889XLSN-BGRD-Enclosed Cabin...
Health & Beauty Logo
29 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
