Question about LG Washing Machines
Replacing outer drum with rear bearing mod lg wm2801ha
  • LG Master
  • 2,131 Answers
Check out videos on repairclinic.com or appliancepartspros.com
Posted on Aug 10, 2017
  • 883 Answers
SOURCE: Rear Axle Removal
rate me solved...this is all I can find...
figure 1
figure 2
Posted on Jun 27, 2008
jsrock516
  • 5911 Answers
SOURCE: rear tub bearing replacement
The shaft on the spinner basket may have worn and formed a groove, or, if the bearing seal was leaking, the shaft may be stuck because of rust. The best way I know how to get the spinner basket out, is to try spraying the shaft with a lubricant like penetrating oil, or WD-40 and letting it sit a while. Allow the lubricant to settle into the area where the shaft seats into the bearing. If this does not provide you with any luck, place the outer drum face down on something to elevate the spin basket up off the floor. I suggest using a couple of saw horses, or blocks of wood. Allow the outer shell to rest on supports, leaving the spin basket free. Place some padding or old towels on the floor underneath the basket. Take a mallet (I prefer a rubber mallet, as it tends to be less abusive) and tap on the end of the drum shaft. The spin basket should pop free and drop from the tub shell. I hope this helps you.
PS You only have to elevate the basket and tub off the floor enough to allow the spin basket to drop free of the tub. About a foot is all I would recommend. Make sure you inspect and clean the spin basket shaft once you get it removed. Some very fine emery paper is what I would recommend to make sure the shaft is not scored or have any rough areas. DO NOT use any electric sanders or dremils for this! It should be clean and smooth before re-installing. If you cannot get the basket free, or if you do, and the shaft is damaged, you may consider replacing it as well. Placing a damaged shaft into a new bearing may not seal properly.
Posted on Aug 28, 2008
  • 1028 Answers
SOURCE: Hotpoint bearing replacement
remove rear pulley and pull like crazy ..usually have to change rear shell bearing and seal are pressed in be sure to ck spindle on basket for scoring before reassembly if scored replace basket
Posted on Sep 27, 2008
MNTECH
  • 1543 Answers
SOURCE: bad bearings on front loading lg washer 1832cw
Sorry, but you are not so lucky. LG should not even offer those parts, as it takes special hydraulic presses to install some of that. For anyone but the manufacturer them self you must replace the back half of the outer drum (I believe it is a 3045ER0008C in your case) which contains the installed seal and bearing, plus I'd recommend replacing the spider asm 4434ER0002A, as the shaft may be a bit worn where it contacted the seal and bearing, and you don't really want to go through all that work (at least 2 hours) only to have to do it again. A FixYa rating would be appreciated. Thanks.
Posted on Nov 13, 2008
stradeteox
  • 88 Answers
SOURCE: replace bearing
You can try a puller but typically it is recommended to replace the entire rear outer tub half (which comes with the bearings already pressed into it). You will also need the tub seal that goes between the front and rear tub halves. Hope this helps.
Posted on Jan 08, 2009
Replace bearings in drum
If this is a front load washer, replacing the back drum bearings is probably not worth it cost and time. It usually requires a complete strip down and removal of the complete outer tub and drum assembly.Once removed the outer tub has to be split in half to remove the spin drum. Rear bearing is sometimes part of the back half of the outer tub so that half will need to be replaced and possibly the rear shaft on the back of the spin basket. I have done a few and it takes 2 techs and about 4 or 5 hrs to do the complete job. Only worth the time and parts if still under warranty.
May 12, 2015 | Washing Machines
How do you remove a rear hub on a 04 kia sedona?
Call Kia with your VIN to make sure yours wasn't affected by the recall. You may be able to have that rear bearing replaced for free at Kia.
HUBCAP & OUTER BEARING REPLACEMENT PROCEDURE: 1. Remove the two (2) cross-tip locating screws on the brake drum.
2. Remove the brake drum.
3. Remove cotter pin and cover set.
4. Remove nut, claw washer, outer bearing and hub assembly.
5. Inspect inner bearing area in both hubs for any sign of moisture, corrosion, grease discoloration or contamination. If "yes" discard entire hub and replace with new assembly. If "no" proceed with outer bearing replacement below: 6. Carefully remove the outer bearing race from the hub. If the hub assembly is damaged then replace the hub assembly as a complete unit. (If inner seal is damaged while removing the outer race replace with new seal.)
7. Clean all contaminated grease from outer bearing cavity of the hub.
8. Install a new outer race into the hub using an appropriate race installation tool.
9. Apply grease MS511-33 WBG2 or equivalent to the hub assembly and the new bearing(s) especially to the shaded areas.
10. Install hub assembly, new pre-greased outer bearing and new claw washer on spindle. (Or alternatively, install entire new hub assembly, as supplied). Ensure bearings are properly seated then tighten hub/spindle nut, torque nut to 20-25 lb-ft (27-33 Nm.) Verify hub spins freely without signs of binding or excessive play.
11. Install new cover set and cotter pin; never reuse the old cotter pin.
12. Install new hub cap with Loctite # 5910(TM) or equivalent sealant to prevent moisture intrusion.
13. Install the rear brake drum using tapered locating screws.
14. Install rear wheels and torque lug nuts to proper specification. (65-79 lb-ft) (88-108 Nm, 9-11 kgm)
15. Lower vehicle.
Dec 30, 2014 | Cars & Trucks
Removing the Drum from an LG WM1832CW Front Load Washer
Well, I assume you have removed the bolt that holds the motor to the tub shaft. After you remove all the motor system then you would only have the tub's hub shaft out of the back of the outer tub thru the bearings and bearing seal. It should easily slide out. If not, I would support the outer tub half on two saw horses or equivalent and hit shaft as hard as you can with a rubber mallet. Remember to have a system to catch the inner tub when it falls out.
Jun 11, 2017 | LG Washing Machines
I have a LG washing machine Wm2277hb. it needs outer tub bearings. what is a fair cost for thi service, or can i do it myself?
It would cost about $500 to $700 to replace the bearing. It is a big job because the drum has to be replaced because the bearing may have damaged the drum shaft so it's recommended to replace the drum assembly along with the bearing assembly. If you decide to do it yourself, you will need:
The rear tub assembly which includes the bearings The tub seal Drum assembly
Good luck.
Jul 09, 2011 | Washing Machines
Rear wheel bearing
If you have ABS then the wheel bears are not replaceable, and the entire hub needs to be replaced as a unit. The OEM part # is 4340250G11
If you do not have ABS then they are replaceable. The inner bearing is part # 0926225061, and the outer bearing is part # 0926220069.
The rear wheel bearings are pressed in the brake drum with a spacer in between.
Remove the rear brake drum and place it on a work surface.
Tap out the opposite side with a screwdriver/punch and a hammer. (i.e. tap out the inner bearing when the outside of the brake drum is facing you, and tap out the outer bearing when the inside/brae shoe side of the drum is facing you)
Tap in the new bearings making sure that the sealed sides are facing out.
Jan 08, 2011 | 2001 Suzuki Swift
LG WM2032 HW making noise, drum moves to much, belive the bearings are shot, but it also leaked the water out of the drum when is shut down. Can just the bearing going bad cause this are is there an...
You are probably correct. If the inner drum is loose and sloppy you probably have collapsed bearings and seals.
What can also happen is that the inner drum can make contact with the outer drum and wear through it. This could be the reason for the leak.
Unplug the machine at the wall. Remove the 2 screws under the rear of the top. 'Bump' the top to the rear to unclip it, and remove.
Remove the back panel to inspect the rear of the drum. This will expose the outer drum.
If the bearings and seals have failed, you have quite a large job ahead of you.
A holed tank is another level of expense. It may be cheaper to replace the machine...Get quotes.
Good luck....Nomess
Sep 06, 2010 | LG WM-2032H Front Load Washer
Rear bearing is going out (very loud on spin). Tech said it would be $900.00 to replace. Is it that hard to replace a rear bearing? Does the whole machine have to be disassembled, etc. About how much is...
rear bearing is generally included with the rear outer drum ***'y. seals and bearings are already pressed into it. it will require much disassembly of machine. hopefully, the motor rotor/stator/drum spider shaft is not damaged too.
Aug 13, 2010 | LG WM2487H Front Load Washer
How to replace the Bearing Ball on A front load LG Washer? The Bearing Ball on My Front Load LG Washer is Leaking Water and also the tank makes a loud noise while its running. I would like to know how to...
main drum bearing is pressed into the rear outer drum 1/2. you will need to replace that part. hopefully, the motor isn't damaged by the leaking water.
Jul 04, 2010 | LG WM-0532HW Front Load Washer
Replace bearing
Dec 02, 2008 | LG WM-1832C Front Load Washer
Bad bearings on front loading lg washer 1832cw
Nov 12, 2008 | LG WM1814CW Front Load Washer
Washing Machines Logo
29 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
