Acoustic solutions telly shows out of range when connected to ps3 had worked fine can anyone help
WHY TELLY SHOW THAT TELLY NOT RESPONDIN
Posted on Nov 20, 2009
My acoustic solutions tv wont display hdmi of my ps3 it say out of range?
First you can do is check the menu setting and double check also the connection of hdmi cable of you player to the television.
Sep 16, 2011 | Panasonic Televison & Video
Hi, ive just moved and my mum has given me her sony telly, which she brought in france! so i went to play my p3 and had no picture or sound through the hdmi point, is it because of french telly or do i...
Dear,
Your PS3 is not having problem because its from France; in fact it is having technical problem which is needed to be fixed. For that, you can either send it to the Sony repair center or fix it at home by yourself within no time with the help of Easy Sony PS3 Repair Manual.
This PS3 fix guide has numerous diagrams, and easy to follow instructions through which you can understand every step easily. PS3 repair guide contains all major problems and their solutions. Once you repair your PS3, you can use this guide to fix other people's consoles and earn money as well.
Jun 01, 2011 | Sony Playstation 3 (PS3) Console
MY PS3 is hooked up via HDMI and has always worked fine. All of a sudden i went to turn it on and there was nothing but black, it detected a signal, but it was just black.
Hi there, Have you switched cables or changed any of the video output settings on the ps3 or your telly? Just double check all the settings and that the cables are connected properly and are not damaged. If you have another cable try that to see if you still have a black screen or try on another telly with the same cable to see if it's the cable that the problem is? If you using a standard cable to try on another tv, you will have to reset the video output so it will work, to do this simply hold down the power button on the front of the ps3 until it powers off again and this will allow it work on a standard tv with standard cable, and to switch back to hdmi just connect with hdmi. Cable to HDTV and the ps3 will detect the cable and ask if you want to use these settings. Hope this helps
Feb 14, 2011 | Sony Playstation 3 (PS3) Console
Message stating check signal cable
Hi there, This could be a few possible issues. What you can try depending on your setup, is 1st to try and connect your ps3 to a different telly using the same cables if possible, like if you had it connected to hd telly with hdmi cable, use this setup on another telly to see if you have the same problem. If it's the same on the 2nd telly then it's the hdmi cable that's the problem, just replace and you should be good to go, but if it works on the 2nd telly then you will have to adjust some settings usually a resolution issue on the 1st telly. You can also try using an analogue cable that came with the ps3 to see if that works. If it was the analogue cable you were using anyway you may need to get a new one, but try on another telly 1st to be sure. It's most likely just a resolution issue but if you have the same problem on 2 tellys it's probably the cable then. Hope this helps
Jan 22, 2011 | Sony Playstation 3 (PS3) Console
Have ps3 that was working fine, unhooked it from one tv to another and proceeded with holding the power button 5 seconds til it beeped twice and still have blank screen
hi, if the ps3 was working fine on the other tv and you have not dropped it or anything like that then this would point towards their being a fault with the lead of the connection in the back of the telly.
what you should do is unplug it all again and refit all the leads in the back of the ps3 making sure they are pushed in far enough then plug the lead into the back of the telly making sure you push it in far enough, then switch the telly on and then switch the ps3 on if the telly dont change to the correct channel as soon as the ps3 comes on then you need to get the telly control and put the tv on the correct channel.
now depending on how many inputs the telly has would depend on how many times you press the button on the control, the button you need to press is going to be on of the following its either av, input,source,ext,aux, or a picture of a rectangle with an arrow running from left to right, now once you have found this button make sure your ps3 is on with a game in then press the button on the tv remote then wait couple of seconds it may say something like av1 on the telly if this dont show the ps3 then press it again it should then go to av2 and keep going until you see the game on the ps3 you need to keep going until your telly is on the right input channel.
once you have done this your ps3 should be working again.
let me know how you get on or if you need further assistance ok
May 25, 2010 | Sony Playstation 3 (PS3) Console
My playstation whon't show up on the tv,at first it was a blue screen i tryed retarting my ps3 and now it's just a blant screen,tryed swichting the connection as well
Hi, try switching the ps3 off then remove the lead from back of ps3 and also remove from the telly refit these then try again if you are still having problems you need to find the av button on your telly remote or source button depending on your telly hopefully this should solve your problem.
If not then the chances are their is a fault with the cable that runs from the ps3 to the telly this will then need replacing if its still under warranty take it back to where you brought it from and they will replace this for you.
Let me know if you need further assistance ok
Aug 05, 2009 | Sony Playstation 3 (PS3) Console
My acoustic solutions 32'' lcd will power up switch on to a black screen then none of the buttons work on the telly or remote
I have an acoustic solution TV and when I turn it on the sound is normal but the screen is black and green in colour. Is it worth getting it fixed?
Jul 21, 2009 | Televison & Video
How do we change PS3 settings from HDMI back to non HD?
switch it to standby then hold the power button for three beeps(not including the first power on beep)this should open a troubleshooting menu,pick option 2.If it doesnt give you the menu first time,switch it off at the back and repeat the steps again.Good luck.
Apr 21, 2009 | Sony Playstation 3 (PS3) Console
Acoustic Solutions 26'' HD TV cannot play PS3 blue ray films
I have recently brought the same TV and had the same problem but I've mangaed to find a soultion.
The automatic setting for Blu Ray on PS3 is Full HD (1080p) but the Acoustic Solutions TV is HD ready (720p). For PS3 games it will automattically change settings for you to 720p. This is why this works straight away but Blu Ray doesn't.
Solution
You need to plug in your PS3 using the scart contection, then on the ps3 menu go to settings > display settings > HDMI. You will then need to attach the HDMI cable and manually set up
HDMI by checking the 720p option and deselect 1080p.
That should then play Blu Rays too. You don't lose too much quality as 720p works nearly as well as 1080p on smaller TVs.
Rich
Feb 18, 2009 | Televison & Video
Ps3 sound setting for Acoustic Solutions tv
i had the same problem with my acoustic solutions astv 3619ws, you have to change the settings to:
linear PCM 2 ch. 44.1 khz
linear PCM 2 ch. 48 khz
linear PCM 2 ch. 96 khz
linear PCM 2 ch. 192 khz
you have to unselect all the other settings.
Feb 06, 2008 | Televison & Video
Televison & Video Logo
390 people viewed this question
Top Televison & Video Experts
Electro Med Services...
