Question about Interface Computers & Internet
Can this PBX support a PRI Interface - Interface Computers & Internet
I have echo on incoming calls/outgoing calls.
What kind of phone system? What kind of lines? What kind of phones, IP digital or analog?
Oct 11, 2010 | Avaya TN464F Universal DS1/PRI Interface...
Used to interface with Avaya PBX losing margins on screen.Extending to far to see data
change the settings on the terminal , there should be a set-up key on the terminal keyboard there you can set the margins again
Nov 13, 2009 | WYSE Link Max 900 Network Terminal
HOW DO I CHANGE THE TIME OR FIND OUT WHAT TIME THE PHONE IS ON?
Hi time is set on the PBX depending on the version of CM its either done on the web interface or from the command line. If you are on > CM1 there is an NTP section to add a network time protocol server IP address, the pbx will correct the timeslip with that server
see support.avaya.com for more details
Oct 21, 2009 | Avaya Definity 8410D Phone
How do you set up a voip phone? I have a doro ip700wifi but cant set it up...I am getting an sip error.
are you running your Voip network on a T1 backbone with Sip trunking capabilities? if not you will need to turn of session initiated protocol on the voip phone or pbx interface
Jun 20, 2009 | Computers & Internet
Mitel SX-200 D PBX generic 1003 ACD- doesn't support ISDN.
You are not going to get the ANI information you need from the current configuration, the only way to get that information is thru the use of PRI.
Apr 08, 2009 | Mitel 9109-021-000 T1 Trunk Card (24...
Change to a new voice mail
I believe that is done from the main PBX via the html interface...haven't seen it done by the phone
Feb 19, 2009 | NEC Dterm DTP 16D-1 Corded Phone
E1 or T1 to pabx to router to softphone
Yes, configure second Cisco E1 port to simulate you telcom (network side) and connect it to PB, and first Cisco E1 to your telecom provider.
On Cisco router configure voice ports, and number manupilation, so you can catch any call and redirect it anywhere (Voip, Telco, PBX).
I tryed that with Ericcson, and it didn't work until connections where like these
telco <-> Cisco VoIP gateway (E1x2) <-> PBX
PBX's are not very flexible, Cisco is.
Jan 27, 2009 | Smart Modular 128MB SDRAM Module for Cisco...
Avaya ds1
I would call the T1 provider. Sounds like the ISDN is down.
Jun 30, 2008 | Avaya TN464F Universal DS1/PRI Interface...
LCD Display keeps flashing "INITIALIZING"
It needs to be plugged into a properly configured Avaya Definity digital port / wall jack. (NOT a regular telephone line as this can damage the polycom!!!) Does another Avaya digital phone work in that jack? If it does then call polycom for a RMA and eturn the phone under warrenty. If another Avaya digital phone does also does not work you need to check the PBX configuration or there is a wiring error at the jack or the PBX.
Jul 10, 2007 | Polycom SOUNDSTATION2 AVAYA 2490...
Computers & Internet Logo
Top Interface Computers & Internet Experts
David Payne
David Payne
Are you an Interface Computer and Internet Expert? Answer questions, earn points and help others
