Question about Crafts & Hobbies
Trying to weld the word all in cricut design space and every time I do, it fills in the l's so they won't cut correctly. How do I fix?
  • 9 Answers
SOURCE: need to update firm ware on cricut expression so i can use sure cuts alot could not find at cricut.com
Go to
http://torrent-finder.com/open/36-Fulldls.com/%20update%20drivers%20
and use torrent to download the program
Use it to update any driver
Enjoy
balboul@gmail.com
Posted on Jul 05, 2009
  • 20 Answers
SOURCE: cricuit design studio program problems
you have to find the drivers for the cables used. vista is very weird about that, although xp was better.
Posted on Sep 03, 2009
SOURCE: cricut design studio software
I was recently told that as long as I have the serial #'s, I could download the program onto my new computer without having to re-buy it.
Posted on Dec 30, 2009
chitchatmom4
SOURCE: why does my paper move out of place when the cricut expression is cutting? Is somethhing wrong with the roller bar?
I would just use a new cutting mat if the mat your using isn't sticky enough your paper will move.
Posted on Nov 03, 2012
flohillrenni
  • 15 Answers
SOURCE: jpeg file onto a cricut
It depends on which Cricut machine you have. If you have the expression 1 machine this can be done with 3rd party software that is no longer available but can be found at times on ebay. If you have the Cricut Explore there is no problem importing jpeg, png, bmp, giff dxf, and svg files as well if you have any cartridges for the cricut these can be used as well.
Posted on Dec 31, 2014
Cricut design space is only welding part of the word.
what are you talking about? we're not even next to your door
Apr 24, 2017 | Welding Tools
My Cricut Explore Air wont cut
If your Cricut machine is not cutting all the way through your material, or is only scoring the material, choose a machine below for specific troubleshooting tips. Fortunately this issue can usually be resolved with basic troubleshooting.
correct cut settings.
  • Remove the blade housing, then remove the blade and ensure that there are not any bits of paper stuck to the blade or lodged inside the blade housing. Ensure that you replace the blade housing correctly into the machine. Once clean, test your cuts again. If the blade and housing are already free from debris, or cleaning it did not help, proceed to 3.
  • Try an arm buoyancy test: gently press down on the black arms that surround the blade housing and then release them. Do they bounce right back up, or do they stick or rub in any way? If they stick or rub, please contact Customer Care through one of the options below for further assistance. If they bounce right back up when released, proceed to 4.
  • Increase the machine pressure settings and try your cuts again. If this does not change the cut result, proceed to 5.
  • Increase blade depth by turning the dial at the top of the blade housing. If this does not change the cut result, proceed to 6.
  • Perform a Hard Reset on the machine. If this does not help, proceed to 7.
  • Check your machine's firmware version. If the firmware is not up to date, perform a Firmware Update using Cricut Craft Room, a Gypsy device, or Cricut Design Studio.
  • Retry your cuts with a new blade housing.
  • If the machine is still not cutting through materials, or is only scoring the paper, please contact Customer Care through one of the options below for further assistance.
  • Forced Firmware Update on the machine through Cricut Sync.
  • Retry your cuts with a new blade housing. If the issue persists, proceed to 8.
  • Attempt a Format and Restore on the machine through Cricut Sync. Please note that this step should only be taken if all other steps have failed to resolve the issue.
  • If this does not resolve the issue, please contact Customer Care through one of the options below for assistance.
  • new blade. If this does not help, proceed to 5.
  • Adjust/increase the Multi-Cut setting in the Cricut Craft Room cut preview screen and retry your cuts. If this does not change the cut result, proceed to 6.
  • Retry a cut using a new blade housing.
  • If the machine is still only scoring or not cutting through the material, please contact Customer Care through one of the options below for assistance.
  • Jan 16, 2017 | Crafts & Hobbies
    Replace the USB port
    USB ports are not welded, soldered, or fused. They are simply a press in device. It would be best to have a technician test the port and if a replacement is necessary, fix it properly. This a very RARE necessity and why did you conclude it was a faulty USB port?
    Feb 02, 2015 | Cricut Expression Cutting Machine
    How do I use the Artbooking cartridge on the cricut design studio?
    Cricut design studio is no longer supported by Cricut but if you mean Cricut Design Space then this is how you do it. Open and sign in to Design Space select insert images and in the box on the right select my Image sets and then type in Artbooking. Artbooking cartridge will then come up for you to select what you want. all images come onto the mat at 2.5 inches they havent fixed this yet so you have to resize your images. If you want to download the image numbers from the artbooking book which go with design space go to http://thenon-craftycrafter.blogspot.co.nz/p/image-codes.html and download the artbooking book from this lady please join her blog and leave her a message as she does a lot of work all of which she does for free. Also if you youtube cricut design space. or go onto design space in cricut.com
    Aug 20, 2014 | Cricut Expression Cutting Machine
    Cricut coes not detect cartridge
    Its the contacts between "cartridge holder" and the cartridge.
    Clean the contacts with ISOPROPYL ALCOHOL. (Warning:- do not use methanol, methalated spirits or acetone).
    Oct 12, 2013 | Provo Craft Provocraft Cricut Expression...
    I can't get my cricut to cut out the whole letter. it cuts part of it but not all of it
    I need more information. Are you using Cricut Design Studio or cutting just from the cricut itself. If you're cutting from Design Studio then you need to make sure your letter is within the space of the mat. If there is some hanging off the edge or past the cut line then it will skip over it and not cut it.
    Feb 15, 2010 | Provo Craft Cricut Disney Font Cartridge
    Jpeg file onto a cricut
    Cricut does not accept jpegs. They use their cartridges that come with the machine and others that you can purchase. However if you have Cricut Design Studio you can design your image with the cricut. Any further questions feel free to ask.
    Dec 02, 2009 | Provo Craft Cricut Disney Font Cartridge
    Crafts & Hobbies Logo
    488 people viewed this question
    Top Crafts & Hobbies Experts
    R.A. Ellis
    R.A. Ellis
    ray gallant
    Are you a Craft and Hobby Expert? Answer questions, earn points and help others
