Question about saniflo"" turboflush toilet"
My Watereasy macerator won't pump. It has power, the microswitch clicks, but the pump wont activate (and instead the unit overflows if flushed).
It stopped working when power came back after an unrelated powercut. I have dismantled and reassembled it and there are no blockages etc. Update: It turns out the issue was the power to the pump. There was enough residual current to power the LED in the pump switch, but not the pump itself. Rewired a faulty socket on that circuit and all working now.
  • 33 Answers
SOURCE: self activating and not pumping away. waste backing up into pan
self activating - the pipe work is blocked and the saniflo is trying to emty (microswitch activated). as the outlet is blocked so effluent will be forced back - in this case up into the pan. Messy job- drain down remove clean clear blockages refit.
Posted on May 10, 2010
  • 115 Answers
SOURCE: How do I know if the macerator is working if I
If you flush the toilet at least 3 times and water does not back up on the toilet then is working. In case the pump fails the pump will fill up about 3 to 4 gallons of water before it overflows or backs up. You can also try disconnecting the discharge pipe off the discharge elbow and place a bucket at the end of the discharge elbow and flush the toilet into the bucket, if water is discharged into the bucket then is working properly.
Posted on Aug 11, 2010
  • 1015 Answers
SOURCE: when flushed the toilet is filling up with water,
The first thing I would do is to make sure the discharge line is not plugged or the check valve hanging up in the closed position. Then I would remove the pump and check the impeller to see if it still firmly attached to the pump shaft and that the vanes are in good shape. If the impeller is damaged then it can be replaced. Otherwise if you know that all the drain lines are clear make sure that the impeller inlet in clear.
If you cannot find anything else wrong then you may have to replace the pump but I would try the least expensive thing first. Thank you and good luck.
Posted on Feb 26, 2011
male_28_cam
  • 1555 Answers
SOURCE: The coupling from the toilet
I won't suggest you to try to fix this problem yourself as you may do more damage to it. Kindly contact (904) 724-7211 or visit 8850 Corporate Square Court Jacksonville, FL 32216 for hiring an expert plumber.
Posted on May 26, 2011
SOURCE: The when macerator is filled the motor just turns but no water pumped out, no blockages ibn outlet pipe, could it be diaphram or microswitch, the other clue is if i kick the macerator not too forcibly
Sounds like it's jamed with something the macerator cannot process.
Posted on Feb 09, 2015
I have a Sanipro,it sounds like it pumps real weak and goes off quickly instead of emptying out everything. then it will come on again after aseveral seconds . Could it be the Condenser on the motor?
  1. Saniflo & Saniplus&... Repair Questions - Fixya
    www.fixya.com/.../p1064016-saniflo_saniplus_macerator_pump_002 Saniflo & Saniplus& Macerator Pump - Recent Questions, Troubleshooting & Support ... My saniflo does not flush properly always leaves the toilet paper behind.
Jul 20, 2015 | Saniflo SANIPRO Macerating Pump
I have a toilet with a push button flush mechanism (allowing half or full flush). The toilet has a macerator behind it. If you flush the toilet and the macerator jams, the push button stays stuck in and...
This seems like a problem with your cistern and not your macerator - I have a similar set up and if your push button is stuck you need to check the mechanism in the cistern - also you should have an overflow that drains into your loo within the cistern so you should check this for blockages as well.
Oct 08, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
We have a saniflo compact the toilet will flush 3 out of 5 times and the motor sounds fine but the other times when flushed it will sound like it is trying to flush and then just turns off at the end of...
This could be a problem with the capacitor that has gone bad or something stuck on the blade or impeller and is not allowing the waste to be pumped out. Typically when the capacitor has seized up or there is a clog on the drain pipe, blade or impeller; the unit will just hum and not pump the waste out and eventually back up on the toilet and overflow.
Sep 30, 2010 | Saniflo & Saniplus& Macerator Pump
Macerator keeps going off even when not flushed.
Water pressure makes the unit turn on and off. It will only activate on it's own when enough water pressure is present. Most likely it can be water leaking from the toilet tank into the bowl, and from the bowl into the pump. Or could also be that waste water is slowly draining back into the pump through the check valve on the discharge elbow, creating enough water pressure that it will make the unit kick on and off.
Aug 06, 2010 | Saniflo & Saniplus& Macerator Pump
How do I know if the macerator is working if I flush the toilet I acn hear the pump start and see the 22mm outlet pipe vibrating as water is pumped thru it. But I'm not sure if macerator is working. Does...
Jul 20, 2010 | Saniflo & Saniplus& Macerator Pump
Self activating and not pumping away. waste backing up into pan
Mar 13, 2010 | Saniflo & Saniplus& Macerator Pump
Saniflow plus works allright for w.c but will not work for shower
Thanks for the clarification - This rules out power supply to the unit, motors/pump and points more towards why the water would be pumped from the WC flush and not the basins ...
1. The Saniflo range of macerators have a pressure switch that engages when the water pressure inside the unit activates a microswitch that is encased in a waterproof container. It is possible that the water pressure from the shower and basins is not great enough to activate the internal switch.
So, I would propose two checks
a) If the unit previously worked for the shower and basins something has changed and it is most likely to be gunk inside the unit causing the switch to be less sensitive and only activate on the high pressure that the WC would provide. The fix would be to open up the unit and clean it - please let me know if you need info on how to do this
b) If this is a new install and the shower and basins never worked, you should check the fall in the pipework into the Saniflo is sufficient (should be 1 in 70 from memory - full install instructions are available from the Saniflo website)
c) It could be that if the unit has been in for a long time with a large number of operations that the microswitch is starting to fail and is not as sensitive as it once was (quite unlikely) - but always a possibility!
Replacement microswitches are freely available online and you should also be able to get the exact match spares from Saniflo
If this helps please leave feedback - if not please let me know and I'll try and help some more!
Good Luck :)
Feb 05, 2010 | Saniflo Sanibest Grinder Pump Only 013
My turboflush macerator does not take all the
indicates that the unit may need cleaning /descaling. alternatively the 22mm pipework (outlet) may be partially blocked
Dec 27, 2009 | Saniflo & Saniplus& Macerator Pump
My macerator turns off and stops working for 10 - 15 minutes
the macerator is over heating.check the maintenance opening and clean it ,but you may need a more powerful macerator,some are made only for flushing systems (as in toilets) a pro-longed use may be making it overheat.. good luck
Jul 02, 2009 | Saniflo & Saniplus& Macerator Pump
saniflo"" turboflush toilet" Logo
102 people viewed this question
Top Saniflo Plumbing Experts
jasbo
jasbo
Gil Shultz
Vernon Taylor
Are you a Saniflo Plumbing Expert? Answer questions, earn points and help others
