Question about Garden
The grease zero on the rear axle of my JX75 broke off, so I have no way of greasing it. Should I order a new part (what would that be)? Or just let it run de, the mower is 18'years old.
    Top Expert:
  • Garden Master
  • 77,939 Answers
Easy out the grease fitting and replace it, it is called a "ZERK" fitting.
Posted on Aug 09, 2017
  • 9 Answers
SOURCE: Scotts Classic 20" drive gear problem
In addition to lubrication problems, the plastic pinion gears can wear down or deform. This can cuase them not to engage, even if well-lubed.
I found some replacements at The parts number for the pinion gear is 30737-2, 30737-3 (left and right) for the Scotts Classic.
You can find the owner's manual, with part numbers, here:
Posted on Jul 14, 2009
SOURCE: Ford Explorer leaking rear differential fluid
Time to drain and replace the fluid. The gear lube does not last long in these rear differentials. Use Valvoline 85-140 weight semi-synthetic. It will slow or even stop the leak and prevent future wear. Only replace the seals if the leak gets bad. Hint: the fill plug is 3/8" socket wrench, the drain is 3/4" socket wrench. Attach a short length of vinyl tubing to bottle to fill the differential.
Posted on Oct 22, 2009
SOURCE: Broken rear axle on my Honda hydrostatic drive push mower
The last time I had a Honda mower in my repair shop I noticed that Honda doesnt do individual parts on its transmissions for mowers OR tillers.
You can fix this mower...but the transaxles are a bit expensive. Honda mowers do tend to be worth it though.
If the axle broke cleanly maybe someone would weld it back together?
I mean, the wheels dont turn that fast that balance would be an issue right? And I am sure the axle metal is cold rolled steel....which is to say it isnt thin cast material that would resist welding. If you take the transmission out of your mower and just take the parts to a good jobber maybe they would give it a try for 10-20 bucks? Dont expect a guarantee...but, for 20 bucks most shops wont even pick up a mower let alone try to fix it.
If this gives you another couple of years of service that would give you time to consider a replacement mower when the unit needs service again.
Good luck and be careful!
Posted on Jul 02, 2010
  • 2478 Answers
SOURCE: I have a Craftsman 17.5 hp 42 in.cut riding lawn mower that I've had for about 5 years now, and the rear end is starting to make a whinning sound..How do I grease, or oil the rear end?
It a sealed unit. No service needed. They said call service provider. You tear it apart, if you want. Remove axle from mower. The case unbolt in two pieces>
Posted on May 09, 2012
  • 4803 Answers
SOURCE: Vibration at 70 MPH.
Warped or out-of balance brake rotor? Also keep in mind that loose rear differential trailing arms that allow the rear differential to squirm around can also cause steering wheel shake.
Posted on May 19, 2012
How to install drive roller on my makita 9401 belt sander
DONT forget to order and replace also allways the sinter bearingbus on the machine because to protect you from a dissapointment because otherwise the belt will turns off and cant be (good) controlled again , replace the drive roller allways and clean the front roller axle if its only dirt on the front roller use a little sillicon grease film on the front behind can use a little bit more sillicon grease between the axle rings and new bearing bus. remove the dry grease in the driving gear space and renew the lubricant in it with a multipurpose grease .
Sep 04, 2014 | Makita 9404 4'' x 24'' Belt Sander
How to fit front wheel bearings Which brand to use for quality
If the car is front wheel drive a puller is required to dismantle the hub a rather involved job better left to a mechanic .If rear wheel drive do the following. ( Applies to front wheel drive also.) Chock rear wheels,loosen front wheel nuts, jack up car, fit safety stands,remove wheel , remove grease cap from axle. remove split pin or locking nut on axle ,Remove hub, with a punch drive out the grease seal ,the tapered cone bearings can now be removed, the 2 bearing cups still in the housing will have to be pressed out ,all old grease has to be cleaned out. the new cones must be repacked with high temp bearing grease . tap in the seal with the lip facing inwards , slide on the hub fit the outer cone to the axle , the spacer and nut goes on next, tighten the nut to seat the bearings , spin the hub make sure its free to spin, back off the nut one eighth of a turn fit a new split pin or lock tab. fit grease cap and road wheel.
Jul 27, 2014 | Cars & Trucks
How do I fix a rear wheel that's locking up on my Toro zero turn mower?
Replace axle or check to make sure everything is still good and greased
Jul 24, 2014 | Toro TimeCutter SS4260 - 22HP 42 Zero Turn...
How to replace front wheel bearing
pull wheel remove grease cap undo carter key remove nut pull off rest of hub take bearings frt and rear out of hub clean old grease from bearings check bearing for defect install in revers order remender to install new grease in new bearings lots of grease and u will need new seals for same front and rear
Jun 14, 2014 | 2006 Suzuki Verona
Greasing the axle
The front wheels don't use axles, instead they use roller bearings similar to auto wheel bearings. Scooter front wheel bearings are usually sealed bearings or shielded. If the bearing is stiff or ruff and a sealed bearing you must replace it. Sometimes you can revive a shielded bearing by soaking in carburetor cleaner rotating soaking rotating soaking until the bearing runs smooth. Then you repack the bearing with grease. To repack a bearing you must place some heavy grease in the palm of your hand. Hold the bearing at a 45 degree angle to your palm. Catch some grease between your palm and the inside of the bearing race. Force the grease between the race and the shield until you see grease coming out the other side. Do this all the way around the bearing The rear wheel are normally mounted to the trans-axle. The manufacturer considers this to be a sealed unit however you can open it. Remove the Allen head screws and split the axle case by move the slender side down the shaft until its open enough to apply grease with a gun. PUT LOTS OF GREASE. When you close the case most of the grease is going to be squeezed right out again. To prevent this i installed a Zerk fitting. WARNING Do not install a Zerk yourself. What i'm trying to do is to pressurize the case with grease in order to get the grease to where its needed. Do not use the scooter inside until you find its not dripping grease. Hope this helps
Jun 02, 2012 | Pride Go Go Elite Traveller Plus HD 4...
I took the ball bearings out cause the case was broke now i cant get everything back together and to get the tire on so i can drive what should i do?
I assume you are talking about a wheel bearing. The ball bearings are usually part of a sealed bearing unit. If that is so, you'll have to get a whole new bearing cartridge, pull out the race (part of the shell) from the old one, and set the new bearing back in. Is this a front or rear wheel? Is the "case" the axle housing, or just the bearing shell?
If your problem is just holding ball or roller bearings in place for re-assembly in a non-cartridge bearing, use the old bicycle mechanic's trick: load up the bearing race with grease, stick the bearings into the grease, then assemble the journal/axle.
Nov 19, 2010 | 1993 Buick Park Avenue
How to grease rear axle
No greasing at rear axle's, it's lube by the gear oil in the rear-end, just need to check that it's filled at level with gear oil.
Sep 24, 2010 | 2002 Ford Explorer
96 chevy blazer rear axle bearing/seal r/r
No. Did you run some emery cloth along the race (bearing surface) to make sure it was smooth and clean? If you leave any part of the old seal or debris on the hub surface, damage the seal when installing it, not liberally packing the bearing with grease or the seal did not seat right you can have issues like yours. Make sure the seal is installed flush and if everything looked good as far as the axle and surfaces, pack more grease in the bearing. When you think there is enough grease in it, put more in. Put the grease in the palm of your hand and with the bearing held flat in the other hand repeatedly tap the bearing on your palm until grease comes out both sides. Then put more on it when you seat it.
May 28, 2010 | 1989 Chevrolet S-10 Blazer
1993 Ford F-150 drum brake problem
It appears the rear axle shaft seal is leaking. You will need to pull the axle and replace the seal. Then check the rear end for adequate gear oil. The iron filings I am not to sure about. It sounds as if something came loose from the brakes or brake hardware and got chewed up in the drum. You will need to replace the brake shoes and maybe the brake hardware kit. Always change the shoes or pads on both sides when working on brakes, rear or front. If the inside of the drum is not perfectly smooth it will need to be turned or replaced. If this were brake fluid leaking from the wheel cylinder the master cylinder would be low on fluid and your brake pedal would go down much further than normal.
Jul 18, 2009 | 1998 Ford F150 Regular Cab
Jul 15, 2009 | Pride New Mobility Legend 4 Wheel Scooter
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
