Question about Troy Garden
Troy bilt model # 13AC26JD011 Mini Rider- I need to replace steering pinion gear. How do I do that
SOURCE: looking for manual for troy-Bilt super tomahawk wood chipper
here is the link to the manuals for the 47266 http://www.brentchalmers.com/
enjoy :)
Posted on Sep 13, 2009
mowerman1857
  • 389 Answers
SOURCE: Troy-bilt Model 47279
I really hate to be the "bearer of bad tidings" but Troy Bilt, as a company, in no longer in business, MTD bought out the name and design rights for a lot of their tools but they are not manufacturing or stocking any parts for the older GardenWay/ Troy-Bilt machinees. My best suggestion would be tostart looking for a good used one or one with a blown engine, broken frame or whatever, buy it and canibalize it for spare parts
Posted on Sep 16, 2009
mickey813
  • 472 Answers
SOURCE: adjust brakes parts/schematic for troy bilt super
ON THE SIDE OF THE TRANS THAT 1/2 INCH NUT TURN IT TILL IT STOPS THEN BACK IT OFF 2 TURNS
Posted on Oct 02, 2009
  • 6 Answers
SOURCE: Troy-Bilt Chipper Vac Model 47282: Need a part #
Get in touch with frederick7153@comcast.net or 651-786-4277 he has parts new and used. Also does bag repairs
Posted on Oct 29, 2009
SOURCE: Cannot disassemble Troy-bilt trimmer head
There is a round, rotary black part between the metal piece to which the cutting head attaches and the outer plastic seat of the cutting head. There are two square slots, each about a quarter inch wide, on opposites sides of the black piece. Slide an Allen wrench or something similar firmly into the slot. Holding the Allen wrench in a stable position, turn the outer plastic ring of the cutting head (it has scalloped edges that can be gripped firmly) counter clockwise to unscrew the cutting head from the bolt on which it is mounted. Be careful with the tool (e.g. Allen wrench) used to hold the black piece steady, as it is plastic and could be damaged by the edge of the tool.
Posted on May 04, 2011
Troy bilt 26J Mini Rider clutch sticks. How do I adjust the tension?
the pully midway from engine to deck. Look for an adjustment where the pulley articulates with the foot control. The pulley probably moves to provide adjustment control
Sep 28, 2015 | Troy Garden
How do you remove battery from a troy bilt mini rider?
push down on one end of the wire hold down, it just clips in...
Nov 12, 2013 | Garden
How to remove rack and pinion from 99 chrysler lhs
There are few help links showing exact accurate procedure to replace Rack and Pinion. Click the link below and follow the procedure:-----
Pinion Seal Replace on Dodge Dakota? http://howtobyme.blogspot.in/2012/04/pinion-seal-replace-on-dodge-dakota.html
How to Replace a Rear Pinion Seal.
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-rear-pinion-seal.html
How to replace Power steering rack and pinion gear on Chevy Silverado 2500 HD? http://technoanswers.blogspot.in/2012/02/how-to-replace-power-steering-rack-and.html
How to replace Power Rack and Pinion Steering Gear on Acura Car Models? http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-power-rack-and-pinion.html
How to replace power rack and pinion steering gear on Toyota cruiser? http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-power-rack-and-pinion.html
Front Drive Pinion Seal Removal on Ford Explorer? http://repairhelpcenter.blogspot.in/2012/03/front-drive-pinion-seal-removal-on-ford.html
How to Replace Driveshaft, Pinion Flange & Seal?
http://repairhelpcenter.blogspot.in/2012/03/how-to-replace-driveshaft-pinion-flange.html
How to Replace Power Rack & Pinion Steering Gear On 2007 Ford Taurus? http://repairhelpcenter.blogspot.in/2012/03/how-to-replace-power-rack-pinion.html
How to Remove Power Rack & Pinion Steering Gear on Ford Windstar? http://repairhelpcenter.blogspot.in/2012/03/how-to-remove-power-rack-pinion.html
Power Rack & Pinion Steering Gear replacing details for Buick Park Avenue and Pontiac Bonneville
http://repairhelpcenter.blogspot.in/2012/03/power-rack-pinion-steering-gear.html
How to Replace Power Rack & Pinion Steering Gear on Mercedes Benz Truck? http://howtobyme.blogspot.in/2012/03/how-to-replace-power-rack-pinion.html
How to replace Power Rack & Pinion Steering Gear on Toyota 4Runner? http://howtobyme.blogspot.in/2012/03/how-to-replace-power-rack-pinion_27.html
Power Rack & Pinion Steering Gear Replacing on Toyota Land Cruiser & Sequoia? http://schematicsdiagram.blogspot.in/2012/03/power-rack-pinion-steering-gear.html
Power Rack & Pinion Steering Gear Removal on Toyota RAV4? http://repairhelpcenter.blogspot.in/2012/03/power-rack-pinion-steering-gear-removal.html
How to Replace Power Rack & Pinion Steering Gear on Toyota Sienna? http://technoanswers.blogspot.in/2012/03/how-to-replace-power-rack-pinion.html
These details will help.
Thanks.
Nov 23, 2012 | Cars & Trucks
Troy Bilt riding Lawn Mower will not steer
at the bottom of the shaft there is a plastic union that keeps the gear against the other gear they crack and then the steering jumps on the gear
Jun 02, 2012 | Garden
Have a Troy Bilt chipper/shreader model 47285. I
Taked the broken belt to the auto parts store for a replacement.
Jun 06, 2010 | Troy-Bilt ChipperShredder
Reverse problem and fuel solenoid problem on Troy Bilt Rider
Reverse is all the way back toward rear of tractor . You need to pull lever close to seat before moving back and forth . R , N , 1 ,2 ,3 ,4 ,5 . Cable may be stretched . Hope this helps .
Mar 16, 2010 | Ace Hardware Welding Tools
Have Troy Bilt 47279. Need Vacuum Snout.
i NEED A REPLACEMENT VACUUM SNOUT FOR A 1990 TROY BILT CHIPPER-VAC. THERE IS NO MODEL NUMBER FOR THAT YEAR, ONLY DESIGNATED AS "MODEL 5 HP".
Nov 06, 2009 | Troy Bilt Walk Behind...
Need replacement belt guard for sovereign lawnmower
  1. Discount Troy Bilt Partsupstateoutdoorpowerequipment.com Save Up To 35% on Troy-BIlt Parts. Save Up To 35% on Troy-BIlt Parts.
  2. Troy-Bilt Partswww.partstree.com/troy_bilt_parts Need Troy-Bilt Parts? Look Up Parts and Diagrams for All Models.
  3. Troy Bilt PartsSearsPartsDirect.com
HERE IS THE ACTUAL PART YOU CAN BUY FROM EBAY!!!!!!!!!!!!
http://cgi.ebay.com/Troy-Bilt-NEW-Bumper%2FGuard-Attachment--Part-%2311045_W0QQitemZ280344217654QQcmdZViewItemQQimsxZ20090511?IMSfp=TL0905111310008r5209
May 13, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Front wheels not aligned
it sounds like your drag link is bent.look under the front.the rod connecting the two tires should be straight.if not,straighten it and slide a slightly larger piece of galvanized pipe over the rod to stop it from bending again
Apr 29, 2009 | Troy-Bilt Pony Garden Tiller
Garden Logo
24 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
